This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Aug 06, 2008, 03:37 PM
Chris F is offline
Find More Posts by Chris F
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Originally Posted by Condre'
I didn't get a response to this when I brought it up a while back. What prop adapters are people using that work with the PZ spinner and non stock motors on the 190? I can't find any that have a long enough threaded shaft for it all to fit together.
I changed my motor to one of these and the spinner fits the threaded prop shaft perfectly.
http://www.hobbycity.com/hobbycity/s..._(Eq:_AXi_2814
Chris F is offline Find More Posts by Chris F
Old Aug 08, 2008, 09:27 AM
Condre' is offline
Find More Posts by Condre'
Lexington, Ky
Joined Apr 2004
Great suggestion, but I already have two motors that are essentially just like that one.
Unfortunately, they didn't come with a prop adpter like that.
Condre' is offline Find More Posts by Condre'
Old Aug 11, 2008, 02:30 PM
Draven is offline
Find More Posts by Draven
Fly Low Fly Fast
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
i have a kokam 1500mah 11.1v lipo, and a 25a ESC. Whats the best motor for this combination that is cheap from hobbycity? its going to be the power system for the FW-109
Draven is offline Find More Posts by Draven
Old Aug 11, 2008, 06:31 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I have one of these http://www.unitedhobbies.com/unitedh...idProduct=6247 on the way for fitting to my GWS-190 using a GWS 10 x 6 X 3 blade propeller on three cells. Roger Lombard reports exelent results with this set up on his GWS-40 (rating No 9 on the web page) and the GWS-190 is lighter and a better flier.
I have tried this three blade propeller on both my GWS-190 and GWS-40 but it draws a lot of Amps so I am hoping for a lower Amp draw with the hexTronik DT750.
Ken
kensp is offline Find More Posts by kensp
Old Aug 11, 2008, 06:41 PM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
thanks for telling me the 109 is better. i was about to order a p-40!
how bout this one?
http://www.hobbycity.com/hobbycity/s...less_Outrunner
even though the 710kv one has 1000g thrust!
Old Aug 11, 2008, 10:10 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
thanks for telling me the 109 is better. i was about to order one!
how bout this one?
The suggested propellers for the TURNIGY 28-30-azj are a bit too small for the GWS-190.
You will need a 9 or 10 inch diameter with a 6-8 inch pitch for the GWS-190 to get enough thrust and pitch speed. This size propeller will overheat the TURNIGY 28-30-azj motor.See the comment by Jari-Pekka Willman (No 17 on the web page)
"don't use 10x4,7 or bigger clo
I tried a gws 10x4,7 prop with this motor and fried it after 7 min of flight. I fly at 150ft and motors draws more amps if they are closer to sea level(air is thicker, more work to do to get the motor spinning -> draws more amps) If you are around 5000ft it will draw close to 15 amps. Now buying another one and propping down to 8x6 and trying the 9x4,7 as well."
Most of the comments apply to E3D models. These models use a lower pitch propeller and do not do a lot of flying at Wide Open Throttle. Warbirds do, so you will need a motor that will not overheat under these conditions.
In the around US$10-12 price range the Tower Pro 2515-8T Is rated for 10 x 6 to 12 x 5 propellers so I would think that it would be a better motor .
Ken
Old Aug 11, 2008, 10:37 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
It's a 1-9-0..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Aug 12, 2008, 07:14 AM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
Originally Posted by Tram
It's a 1-9-0..
sorry i get them mixed up
http://www.horizonhobby.com/Products...source=froogle
Old Aug 12, 2008, 07:52 AM
wedge98 is offline
Find More Posts by wedge98
wedge98's Avatar
East Hartford, CT
Joined Sep 2006
think about it this way: the 109 came first, had less firepower, and was not as able to take abuse as the 190
so the 190 came second, had more firepower, and was sturdier.
also it was the ME109 / BF109 vs the FW190
Or you could just spend a ton a time reading about the WW2 planes and get all you need to know from that.
Now what model flies better well that hard to say unles you own them all. I have the 190 and it flies great!!!! I've also heard the GWS T-6 was good as well but I have yet to build that kit and I have no idea about the P-40.
wedge98 is offline Find More Posts by wedge98
Old Aug 12, 2008, 07:57 AM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
im not too bad on history about ww2 planes? 1/3 the books in my dads book shelves (he has about alot!) are about ww2 fighters and bombers. When they have an episode of dogfights or just plain history im always there. And i have flown both in il2 1946 online. Yes, the 190 is faster and more agile but the 109 had more firepower with those MK 108 cannons
Old Aug 12, 2008, 09:56 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
GWS FW190 with GWS BL3008 equipped with EP1060HD prop already make her able to vertical take off by hand lunch!
Just saw one flyer bought one from GWS China shop and tested!
May be we should ship the kits with BL motor and ESC plus Li-Po pack at combo deal for lonely birds who can't get GWS supplied in their country?
GWS4CEO is offline Find More Posts by GWS4CEO
Old Aug 12, 2008, 10:24 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
This pack of combo special should be also considered to apply on P40 and many other GWS War Birds!
Old Aug 12, 2008, 02:12 PM
molders is offline
Find More Posts by molders
molders's Avatar
East Yorkshire UK
Joined Dec 2005
The FW 190 had MK 108 30mm cannon as well. The Bf 109 had a cannon firing through the spinner but pilots very seldom used it because it filled the cockpit with cordite fumes.
The MK 108 was preferred by the RLM because it was made from pressed steel and needed no machine tools in its manufacture. With so much "slave" labour employed there was inevitably a lot of saboutage in machine shops. The 190 was used to break up large "virmot" [4 engined bomber] formations but they had to employ so much armour that they required Bf109's as Top Cover.
molders is offline Find More Posts by molders
Old Aug 12, 2008, 09:40 PM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
this will be my paint scheme! i just bought a different TX just to have retracts on this baby! W0000000T!!!
http://images.google.com/imgres?imgu...icial%26sa%3DN
Old Aug 12, 2008, 10:03 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Here is the Butcher Bird head and swastica. Print them out on paper first to try for size as shown in photo No 2. Then print it on white sticky backed plastic film. I use Photo Impressions to print out as that program allows me to adjust the size of the printout.
Ken
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
