Lexington, Ky
Joined Apr 2004
I've had a 190 about a year and PZ has made more money off of me buying their spinners than GSW did off the plane. Recently when I was messing with my newest spinner I noticed that I could twist it so that the lugs move past the pop on location and lock the spinner parts together. Ever since then I have been wanting to ask if that is the way it is actually supposed to go together. That doesn't seem to work with the old spinner sections I have, but you may want to try that if that is not the way you are currently putting them together
GWS-190, fully dressed up
Hello together
After the unfortunate demise of my last GWS 190 (got shredded on the ground by a .61 armed Ugly stick ) I decided that the next one would be equipped with retracts and flaps. Additionally it should receive some extra work in respect to the surface finish and scale looks. And after 2 months of "off and on" work the 190 is finally ready for the roll out. Here some specs for the plane: Motor: Eflite Park 480, 30A ESC and 11,1V 2250mAh Lipo 11x7" APC E prop Specials: -EPF electric retracts with sprung Aluminium struts. -Workable flaps -The whole plane got covered with Japan paper and Acrylic floor polish. -Cowl shortened to scale lenght -PZ spinner, repainted And now the letdown: Weight ready to fly: 990 gramms or whopping 35 ounces. Pretty heavy, but the plane should be able to fly it...I just hope the flaps will allow me also to land it... Anyway, next weekend will show if and how it will fly. Greetings Robin |
Hi Condre'
No twist & lock function on my Parkzone spinner so I cut a thread into a small section of alloy tube and screwed it onto the prop adapter. I then epoxyed a small length of wood dowel into the other end & drilled a very small hole through the centre of the spinner. I then secured the spinner with a small screw. Just hope this holds! |
Usually plastic primer can be found in the automotive corner at every hardware shop or "do it yourself" outlet. It is used to prime plastic car parts the prior to painting....it does really bite the plastic and givves a perfectly paintable surface for every type of color. I am using this kind of primer for all my props and spinner if I am in need of oa different color. The paint job does even survive the occasional nose over or prop strike in the grass runway. Robin |
Tamiya also make a primer that is suitable for plastics or metal. Ken |
Well at long last the weather co-operated - the wind eased,the rain stopped and the sun actually came out. Time to maiden the FW190!
My brother was on hand to hand launch just in case I needed to make any quick adjustments. I shouldn't have worried as all it needed was a gentle toss and I didn't even need to adjust any trims. Wow, what a brilliant plane. Huge or tight loops on low rates and a decent roll rate. I especially liked doing a half roll at the top of a loop and bringing her back towards in a screaming dive. Flies most aerobatic manoevres at 1/2 power and has good glide for an easy touch down. 150 watts seems more than enough. Also nice and quiet so should be ok for those early morning park sorties. Well done GWS and thanks to all the previous posters foe making my 1st GWS build go smoothly. |
If you live in the USA try http://www.caliberhobby.com/gws190parts.html. If you live in Great Britain try J Perkins Distribution If you live elsewhere in the world try an email to service@gws.com.tw. Ken |
| Thread Tools | |
| New Product **** GWS-190: Unbeatable Butcher Bird **** | RAY GWS | Product Announcements | 4 | May 15, 2007 02:00 AM |
| Yippee! Balsacraft FW 190 'Butcher Bird' | W@CC0 | Scale Electric Planes | 116 | Feb 24, 2006 08:51 AM |
| the butcher bird(FW-190) | kase_kopf | Foamies (Kits) | 16 | Dec 16, 2005 02:47 PM |
| GWS Corsair tuff little bird | xmech | Parkflyers | 10 | Feb 13, 2004 10:34 PM |
| GWS PT-17 late bird maiden | sheerLuck | GWS (Grand Wing Servo) | 7 | Oct 05, 2003 09:50 PM |
