This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Feb 07, 2008, 08:53 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Originally Posted by flypig
Any thoughts on this or other inexpensive, but suitable motors would be
great.
There is a guy flying the GWS AT-6 (approximately the same size/weight) and this is what he said ---
I bought the painted version and fly it with a TP 2409-18T brushless motor and GWS 25A ESC., JR receiver and servos, 3S-1650 lipos (8C). AUW is currently 20.6 oz
With this setup it flys Fastest with a GWS 9075 and Strongest with GWS1060. It flys quite well a GSW 9050 but needs full throttle most of the time so flight times are no better than the 1060 which can be flown easily at 1/2 throttle. The 9075 really rocks when you get the itch to fly FAST. Overall I tend to use the 1060 because it's strong and fast. Flight times of 12-15 minutes.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Feb 07, 2008, 01:13 PM
flypig is offline
Find More Posts by flypig
It's a gremlin, so what.
flypig's Avatar
peterborough
Joined Dec 2007
And now I press enter, presto 6 new combos.
Thanks for the response JAMESDR
Shawn
flypig is offline Find More Posts by flypig
Old Feb 07, 2008, 02:22 PM
Kometfreak is offline
Find More Posts by Kometfreak
Joined Sep 2002
flight report
I have about four flights on mine now. The landings are very scale indeed, it noses over consistently when landed in a three point attitude with full aft stick in tall grass. Nice slow flight and predictable, will snap stall when inverted if you get too slow.
Good step up from a trainer.
Kometfreak is offline Find More Posts by Kometfreak
Old Feb 18, 2008, 09:19 AM
monsieurouge is offline
Find More Posts by monsieurouge
Joined Jun 2007
Hello All!
(i'm french sorry for my english! )
do you know where the landing light are positioned on FW190 ?
(i don't find it on photo).
someone has installed lights on its GWS190 ?
Thank's!
monsieurouge is offline Find More Posts by monsieurouge
Old Mar 09, 2008, 07:24 PM
Draven is offline
Find More Posts by Draven
Fly Low Fly Fast
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
nevermind
Draven is offline Find More Posts by Draven
Old Mar 11, 2008, 04:51 PM
pdemon is offline
Find More Posts by pdemon
The simplest, the better!
pdemon's Avatar
Italy, Europe
Joined Apr 2002
Hi guys
here is my FW190, fresh from the airbrush . It has been fun to finish the model and I' m happy with the result... only the legs of the Robart retracts are too thin to be scale
A nice flyer indeed!
Regards
PG
pdemon is offline Find More Posts by pdemon
Old Mar 11, 2008, 07:28 PM
kdahlhaus is online now
Find More Posts by kdahlhaus
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
Very, very nice PG.
kdahlhaus is online now Find More Posts by kdahlhaus
Old Mar 12, 2008, 03:07 AM
pdemon is offline
pdemon's Avatar
Italy, Europe
Joined Apr 2002
Thank you kdahlhaus
I dusted off the airbrush after several years and it's been a very rewarding experience. It's now flying with a HXT 35-30C on 3S 2500 Robbe lipos and
a three blade GWS 9x6, but that huge cowl masks a great part of the blades, so I'm now looking for a 10" or 11" prop...
cheers
PG
Old Apr 06, 2008, 04:45 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
I'm on my first GWS foam plane and read an earlier post that suggested using wire wool to sand the foam prior to painting. Whilst this worked a treat it has left the foam a dirty grey colour. Will this just wash off with a little dilute washing up liquid or will I have to use something stronger (which won't melt the foam)?
Any thought on glassing and adding carbon rods either side of the nose or other areas. I've bought the slope soarer version without uc as plan to fly at my local park where the grass is usually too long for uc. The cowl looks flimsy and I might try to find a container to line it - tuppaware anybody? Has anybody had success in this area? Finally, would you suggest a light sand for the cowl to provide better key for the paint?
Andy
headlessagain is offline Find More Posts by headlessagain
Old Apr 07, 2008, 06:37 AM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Andy
I've used steel wool to smooth out the surface on several foamies. Yes, you can wash the foam to clean it up after sanding. If you want to really smooth the surface, you might try a layer of water based polyurethane mixed with talc/baby powder. It fills in the pores and when you buff it out with really fine emery paper or steel wool, it makes a great finish. Also-buffing the cowl with steel wool makes the paint stick better.
My cowl is one of the original and has it's share of beating. I would lightly line the inside of a new one with epoxy and glass cloth.
Jim
Old Apr 14, 2008, 06:01 PM
El_Luz is offline
Find More Posts by El_Luz
El_Luz's Avatar
Joined Aug 2006
Spring Break
I just want to share my first flying experience this Year! Still one of my favourites! The perfect choice for the first steps after the winterbreak!
I like my new Canon DSLR!
El_Luz is offline Find More Posts by El_Luz
Old Apr 15, 2008, 02:28 AM
pdemon is offline
pdemon's Avatar
Italy, Europe
Joined Apr 2002
Great shot, el_luz! If not for the antenna, it could be the real one!
After a few flight, I've added a bomb/tank release mechanism to my FW: it works very well. the bomb itself is made of soft foam and has a vacuformed nose filled with talc powder: a real challenge to put the bomb on the spot
Old Apr 25, 2008, 05:28 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Now finished construction and shortly ready for maiden.
United Hobbies TR 28-30B 14A 1050Kv Brushless Outrunner
motor puting out 150 watts @ 15.5 amps on 3 cell lipo using 9x6 prop. Already pulled out wing mounting from fuse so looks like I'll have to beef up with some light ply. Here are some shots before I crash it!
Old Apr 25, 2008, 07:31 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Looks good! Another PZ spinner.
Jim
Old Apr 26, 2008, 03:54 AM
Chris F is online now
Find More Posts by Chris F
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Jim
And pilot
Chris F is online now Find More Posts by Chris F
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
