This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jan 19, 2008, 11:55 AM
wedge98 is offline
Find More Posts by wedge98
wedge98's Avatar
East Hartford, CT
Joined Sep 2006
Maiden was this morning and I am impressed!!! First off it was about 25 degrees out when I flew this morning so it was a very quick flight. Luckily there was some frozen snow to take off from so I had a nice and smooth runway. Takeoff was pretty eventful. I needed 1 click of rudder and 4 clicks or aileron to settle her out with a slightly rearward CG. It kept me busy for a minute or so but nothing I couldn't handle.
After getting her trimmed out I noticed I had too much elevator throw and I would like to up the aileron throw a little but overall the controls were great.
Flying characteristics were very very impressive. The plane was very stable and even under very slow flying conditions the plane had ZERO bad tendencies. Honestly GWS did a WONDERFUL job with this plane. I absolutely love it!!!!!
maiden equipment:
Loong-max 3s 1800mah 15C
Suppo 2217/09 1000KV
Suppo 40Amp ESC
APC E 9x9
wedge98 is offline Find More Posts by wedge98
Old Jan 20, 2008, 07:46 AM
jteplane is offline
Find More Posts by jteplane
Fly by Night
jteplane's Avatar
Phoenix, AZ
Joined Jan 2007
Originally Posted by Ceeray
Cowl: I totally reworked engine mounting. I can take some pics later... Shortening the cowling is easy, just cut it to lenght of your liking. But shortening cowl needs engine mount redone too.. at least mine did because I shortened it by almost 3cm (over an inch)
Spinner: spinner cap is from parkzone fw.
I took 2mm ply circle and sanded it near to right diameter using lathe (dremel) Then I glued a piece of blue foam onto it. After glueing I used dremel again and sanded the whole piece to the right diameter. Then I used light glassfibre and rolled it around the piece I made like toilet paper.. maybe 3-4 times and added 30min epoxy diluted with alcohol between each layer. I added baby powder into the epoxy mix and topped the whole thing with that crap.
24 h later I cut the piece into exact lenght and used lathe (dremel again) to sand it smooth. Then I removed almost all blue foam from inside to make room for 8b sized hub. Then I made 3 holes 120 degrees interval to accommodate blades. The I added one balsa disc which diameter was 2mm less than spinner base on the top of spinner base so that way the spinner cap would be aligned with it.
Spinner cap is held in place with a one screw on the top of the spinner, connecting with 8b hub.
I hope you catch the idea..
Ceeray,
Didnt shortening your cowl reduce the nose weight?
how do you get around this? or does it balance w/o it?
or did you add weight to the nose...
I commented on this earlier but was being ignored, just curious....
jteplane is offline Find More Posts by jteplane
Old Jan 22, 2008, 07:42 AM
Condre' is offline
Find More Posts by Condre'
Lexington, Ky
Joined Apr 2004
To shorten the cowl on my 190 I used a 105 gram motor. I later decided that the battery compartment is above the CG and that you might be able to balance the plane by enlarging the compartment so the battery can be pushed more towards the tail.
Condre' is offline Find More Posts by Condre'
Old Jan 22, 2008, 07:47 AM
Condre' is offline
Lexington, Ky
Joined Apr 2004
Oops, so the battery can be pushed towards the nose.
Old Jan 22, 2008, 01:50 PM
Chris F is offline
Find More Posts by Chris F
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
I also mount my ESC next to the motor and made a ply plate for a motor mount. Every little bit of weight matters.
Chris F is offline Find More Posts by Chris F
Old Jan 23, 2008, 08:56 AM
Condre' is offline
Lexington, Ky
Joined Apr 2004
I also did that.
Old Jan 23, 2008, 11:27 AM
jce is offline
jce
Find More Posts by jce
jce
Belgium
Joined Mar 2006
Hello
maybe a small picture ? Thanks
jce is offline Find More Posts by jce
Old Jan 24, 2008, 02:51 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
I got a couple of flights on my Butcher Bird today..
I really need to order that Parkzone spinner and pilot..
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 24, 2008, 07:00 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Nice low pass Tram!
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Jan 24, 2008, 07:12 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
It woulda looked much nicer if I hadn't slung the P-51 spinner I had on it off..
Old Jan 26, 2008, 07:37 PM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Just like WWII
So there I was - warming up and minding my own business. A big 3-D style plane is doing it's thing and was departing the area. Charlie got a little close to me, bumps my tail and we heard the "thunk" sound balsa over Monokote makes. Neither plane really faltered, just kind of "oops!" and remarked that we should not be trading paint like NASCAR. I flew out the remainder of my pack, no problem. I noted that I was a bit sluggish on landing, had to do a missed approach. When I did land, we noticed (shock - horror ) that 45% of the elevator and about 10% of the h-stab was missing. We didn't even notice the chunks floating down. The recovery crew did find all the bits and when I reconstructed the parts on the ground, you can cleanly see where the prop chopped it off.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Jan 26, 2008, 10:40 PM
wedge98 is offline
wedge98's Avatar
East Hartford, CT
Joined Sep 2006
took the FW-190 up for her second flight today. I reduced the elevator throw increased the aileron to 140% and added -40% expo. The result was absolute heaven. She flew wonderful and is by far the best flying warbird I have ever owned. Thanks again GWS for doing such an excellent job on this model
Old Feb 07, 2008, 06:19 AM
flypig is offline
Find More Posts by flypig
It's a gremlin, so what.
flypig's Avatar
peterborough
Joined Dec 2007
I'm sure some of us has tried a TP 2409-12, or 2409-18 in a 190.
how did it perform, and what battery capacities worked well. My twins have a
birthday coming up and they want pylon racers. I thought identical combos
would keep all our planes on a level flaying field.
Any thoughts on this or other inexpensive, but suitable motors would be
great.
Thanks Shawn
flypig is offline Find More Posts by flypig
Old Feb 07, 2008, 06:42 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
Jim
Uh-huh, and since when was someone flying the Butcher Bird actually minding their own business? Just kidding..
..that 45% of the elevator and about 10% of the h-stab was missing. Jim
A testament to the design. I really need to get me one of these.
camship
EDIT: Hey, I see an A-4 in that pic...
camship is offline Find More Posts by camship
Old Feb 07, 2008, 07:14 AM
Born to Crash is offline
Find More Posts by Born to Crash
Custom User Title:
Born to Crash's Avatar
N.J.
Joined Feb 2008
Hi, I've been out of the R/C scene for a couple of years and glad to see GWS has these larger planes finally out. Looks like I'll be ordering a Fw this afternoon.
I can;t wait !
Born to Crash is offline Find More Posts by Born to Crash
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
