This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jan 14, 2008, 03:58 PM
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Ceeray - What do you do to shorten your cowl?
I am stuck between making mine shorter and thus trimming back the firewall and motor stick to accomplish that or turning it into a D model..
Tram is offline Find More Posts by Tram
Old Jan 14, 2008, 08:57 PM
Joined Jul 2007
I Have 2 ,love The Plane,added A Dualsky 250 Watt Motor,may Do A 350 & Retracks On The Next One.
BUCKSHOTRC is offline Find More Posts by BUCKSHOTRC
Old Jan 15, 2008, 10:45 AM
Fly by Night
jteplane's Avatar
Phoenix, AZ
Joined Jan 2007
Just butin' in here, but I went the "D" model route. This way I eliminated any tail heavy issues I had, and no extra nose weight was required. Seems that shorting this planes nose would make it even worse. (IMO)
jteplane is offline Find More Posts by jteplane
Old Jan 15, 2008, 12:59 PM
Finland
Joined Jul 2004
Cowl: I totally reworked engine mounting. I can take some pics later... Shortening the cowling is easy, just cut it to lenght of your liking. But shortening cowl needs engine mount redone too.. at least mine did because I shortened it by almost 3cm (over an inch)
Spinner: spinner cap is from parkzone fw.
I took 2mm ply circle and sanded it near to right diameter using lathe (dremel) Then I glued a piece of blue foam onto it. After glueing I used dremel again and sanded the whole piece to the right diameter. Then I used light glassfibre and rolled it around the piece I made like toilet paper.. maybe 3-4 times and added 30min epoxy diluted with alcohol between each layer. I added baby powder into the epoxy mix and topped the whole thing with that crap.
24 h later I cut the piece into exact lenght and used lathe (dremel again) to sand it smooth. Then I removed almost all blue foam from inside to make room for 8b sized hub. Then I made 3 holes 120 degrees interval to accommodate blades. The I added one balsa disc which diameter was 2mm less than spinner base on the top of spinner base so that way the spinner cap would be aligned with it.
Spinner cap is held in place with a one screw on the top of the spinner, connecting with 8b hub.
I hope you catch the idea..
Ceeray is offline Find More Posts by Ceeray
Old Jan 15, 2008, 01:08 PM
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Thanks Ceeray. Your 190 looks like it flies well with the 3 bladed prop. I might give it a go.
Chris F is offline Find More Posts by Chris F
Old Jan 15, 2008, 09:14 PM
Tram's Avatar
Florence, Al
Joined Oct 2000
Stock built 190..
I think I might built another and spend some more time on it..
I've been flying this one a BUNCH before I painted it so it's got all the "wear" on it..
Jeff
www.CommonSenseRC.com
Old Jan 15, 2008, 10:29 PM
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Jeff,
Stock 190 looks great!
Cheers--Stacker
stacker is offline Find More Posts by stacker
Old Jan 15, 2008, 11:06 PM
Tram's Avatar
Florence, Al
Joined Oct 2000
Ok, another shot..
I did a lil' to the wing.. I think I may just leave it and go flying..
I need to order a Parkzone spinner and pilot and I'll be set..
Mr. Lin - Why can't you produce a scale spinner and pilots for these planes????
Look how many of YOUR 190's are flying with PARKZONE spinners?
Old Jan 16, 2008, 12:09 AM
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Jeff, yours looks good . I think Mr Lin has shares with Parkzone
Old Jan 16, 2008, 09:20 AM
Lexington, Ky
Joined Apr 2004
You're right. I've been through about five PZ spinners. PZ has made more money off my 190 than GWS. Another improvement that GWS could make to this plane is to include a plastic part that covers maybe the outermost one inch of the wings. I guess it's just my poor pilot skills, but after about 100 landings, the wing tips on my 190 are showing a little wear.
Condre' is offline Find More Posts by Condre'
Old Jan 16, 2008, 09:55 AM
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Condre'
Congrats on making the Century Landing mark!
Jim
jamesdr is offline Find More Posts by jamesdr
Old Jan 16, 2008, 10:44 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Try these DuBro plastic wing tip skids. These work wonders on protecting your wingtips.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old Jan 16, 2008, 08:39 PM
kensp's Avatar
Darwin Australia
Joined May 2002
I have fitted some of these wing tip skids. https://www.unitedhobbies.com/UNITED...idProduct=3771
Ken
kensp is offline Find More Posts by kensp
Old Jan 17, 2008, 04:59 AM
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Old Jan 17, 2008, 05:00 AM
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Ok, another shot..
Nice shot of your 190 in the air Jeff The tail wheel looks good too
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Electric Planes 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
