This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jan 06, 2008, 10:31 AM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Glad to hear it went well. You reall have me wanting to work on mine but I have soo many other planes in progress I'd like to get one or two of them done beofre starting another one.
Steve
Vintauri is offline Find More Posts by Vintauri
Old Jan 06, 2008, 11:44 AM
wedge98 is offline
Find More Posts by wedge98
wedge98's Avatar
East Hartford, CT
Joined Sep 2006
After a long time of owning the kit I'm finally making my FW-190 while I wait for parts for my AP/FPV ship.
I've decided I want to build her beefy like all my planes so I'm going with a little strong motor than normal. Here are the specs:
battery: either a 3s 15C 1600mah longg-max or a 3s 25C 2250mah longg-max
motor mount: GWS stick aluminum mount
motor: Suppo 2217/09 70g 950KV 5-15A op 16A max swinging a GWS 10x6 HD
motor static numbers: 10.8V 15.1A 162Watt 8340RPM 47.4 mph 938gr(33.03oz) thrust.
If this setup is not fast enough I'll swap the motor out for a higher KV and bump up the pitch speed
RX: Corona RD620
servos: Hextronics 9g
BESC: Suppo 40A
Wing is gluing as I write this. The project may take some time because I will switch back to my AP/FPV plane once the parts come in but I'll throw some pics up as it goes along.
wedge98 is offline Find More Posts by wedge98
Old Jan 06, 2008, 12:42 PM
Rad Racer is offline
Find More Posts by Rad Racer
Hi Wattage Electrics - Cool
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
Wedge98
I used a Scorpion 3008-28 motor in my FW-190. This motor produces 300watts.....a little over powered but you just need to throttle back.
The power setup specs for this plane are:
Batt - 2100ma 20c 3s
Controller - CC25
motor mount - see photo
Prop - APC 10x4.7sf
motor - Scorpion 3008-28
motor specs - full power, static
10.83v, 28.09A, 304W, 8655rpm, ~42oz thrust
rec - CC/Berg 4L
servos - (4)HS-55
AUW - 21.5oz w/o batt || 26.6oz w/batt
Wayne
Rad Racer is offline Find More Posts by Rad Racer
Old Jan 06, 2008, 12:46 PM
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
Steve
Steve,
We have flown the FW a couple more times this morning. What a great plane.....it flys great. Get yours built, so we can get together for a little flying this winter.
Wayne
Old Jan 08, 2008, 08:03 AM
monsieurouge is offline
Find More Posts by monsieurouge
Joined Jun 2007
Hxt 35-30
Hello !
i have a 30-35 Hxt motor 1100Kv, do you think i can use this motor on FW-190 Gws ??
with a 1800 3s lipo ?
thank's!!
monsieurouge is offline Find More Posts by monsieurouge
Old Jan 08, 2008, 08:29 AM
jteplane is offline
Find More Posts by jteplane
Fly by Night
jteplane's Avatar
Phoenix, AZ
Joined Jan 2007
Originally Posted by monsieurouge
Hello !
thank's!!
should be fine, I would prop it about 10x5.5
jteplane is offline Find More Posts by jteplane
Old Jan 08, 2008, 01:31 PM
Chris F is offline
Find More Posts by Chris F
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Hello !
thank's!!
That should work fine
Sorry jetplane, I didn't see your post but I agree about the prop too
Chris F is offline Find More Posts by Chris F
Old Jan 08, 2008, 01:55 PM
BUCKSHOTRC is offline
Find More Posts by BUCKSHOTRC
Joined Jul 2007
I Have The Fw 190......love It,
went To A Dualsky 250watt Motor,30 AMP ESC,VAMPOWERPRO 25/50 C 3S 2200 LIPO,Air Commander & Sonic Combat Module....
she'a Butcher
I Liked It So Much I Bought Another
May Add Retracks To It....
BUCKSHOTRC is offline Find More Posts by BUCKSHOTRC
Old Jan 08, 2008, 02:03 PM
Chris F is offline
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
she'a Butcher
Why not add a retractable tailwheel and flaps too.... like mine
Old Jan 10, 2008, 02:26 PM
Ceeray is offline
Find More Posts by Ceeray
Finland
Joined Jul 2004
Had a fun winter day...
Check out for other vids from same publisher, Timpska. He is our designated cameraman..
Winter flying
Ceeray is offline Find More Posts by Ceeray
Old Jan 10, 2008, 04:03 PM
Joined Jul 2007
Yup,
Gonna Start My New One Soon,ordered A Cowl/canopy/gear Combo..been Flying It With No Cowl...,can't Find A Cowl Substitute....( Bottle Bottom).
I'm Going To Refinish The Old One After I Build The New One,this Is My Sonic Combat Plane.
Old Jan 14, 2008, 12:58 PM
Condre' is offline
Find More Posts by Condre'
Lexington, Ky
Joined Apr 2004
I would put some kind of support for the tail wheel wire in the rudder. If you don't, the wire will wallow out a hole in the foam and rudder movement will suffer.
Condre' is offline Find More Posts by Condre'
Old Jan 14, 2008, 01:59 PM
wedge98 is offline
wedge98's Avatar
East Hartford, CT
Joined Sep 2006
Thanks for the advice. I do use a version of support though. a ton of 15 minute epoxy in the hole . In practice the rudder stays strong with no problems after many many flights.
I finished up the FW190 this morning. I decided to over prop her a bit so I'm running a APC E 9x9 prop. Maiden will happen when the weather clears up. So far I really like the plane.
Old Jan 14, 2008, 02:07 PM
Chris F is offline
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Winter flying
Hi Ceeray, great video! Your 190 looks fantastic, especially with the 3 bladed prop. I read your post where you said you made the back part of the spinner with blue foam and fibreglass. Could you describe how you did it? It looks great.
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
