This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old May 05, 2007, 04:58 PM
metalbuggy is offline
Find More Posts by metalbuggy
"Cracking Toast Grommit!"
metalbuggy's Avatar
Sanford, NC
Joined Feb 2005
Thank you very much Mr.Lin!
I'll stop with the 'eat your hat' stuff.
Thumbs-up to GWS!
metalbuggy is offline Find More Posts by metalbuggy
Old May 06, 2007, 06:46 AM
BenziT is offline
Find More Posts by BenziT
Singapore
Joined Mar 2007
With the improved in the quality in the foam used by GWS.. is there a "real" need to glass the plane ?
BenziT is offline Find More Posts by BenziT
Old May 06, 2007, 10:07 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Glassing serves two purposes - strength and making a nice surface. The newer models are significantly stronger than the older ones especially around the wing saddle. And the new model's foam has tighter cells making a smoother surface. So I guess there is no "need" to glass anymore, but folks will to make a superior model. I'll still be top coating mine with a WPBU spray to harden the surface against incidental hanger rash. And I may try to prep the surface with a WPBU and talc mixture to fill in any foam pores.
Jim
jamesdr is offline Find More Posts by jamesdr
Old May 06, 2007, 11:51 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
I've never glassed any of my GWS models, nor ever felt the need to, but I buy Jim's point about coatings to reduct hangar rash and since Molders drew my attention to it I've been using Johnsons Klear which is a "brush on" polycrylic floor wax, sold in the US as "Future" and I find that works very well. Puts on a pretty hard satin finish but adds little weight. I find that two coats work best one before decals and if you're using pastels or any other "weathering" medium before that too and then a final coat to seal everything up. I haven't tried it as a"fixer" for inkjet printed decals but it might work there also. Little article about it here http://armorama.co.uk/modules.php?op...icle&artid=227
Roger Lombard is offline Find More Posts by Roger Lombard
Old May 06, 2007, 12:23 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Roger
Thanks! Another technique. I Googled "Future Floor Wax" and found several articles form modelers on the stuff. I now have a burning desire to go to the store and try it out.
Jim
Old May 06, 2007, 08:55 PM
BenziT is offline
Singapore
Joined Mar 2007
Thanks for your reply James and Roger.
Well, I managed to get hold of minwax. Tried it on some light fabric cloth ( Organza ) . It sticks really well. However, the fabric does not seem to add much strength.
I have to get some FG then.
Good luck to me
Thanks again !
Old May 06, 2007, 08:56 PM
BenziT is offline
Singapore
Joined Mar 2007
The fabric I used was this
http://en.wikipedia.org/wiki/Organza
http://www.denverfabrics.com/pages/s...al/organza.htm
Old May 07, 2007, 08:31 AM
sebsoupe is offline
Find More Posts by sebsoupe
sebsoupe's Avatar
Bourg-en-Bresse, FRANCE
Joined Mar 2005
Hello
where can we find a pilot for our GWS FW190???
thanks,
sebsoupe
sebsoupe is offline Find More Posts by sebsoupe
Old May 07, 2007, 12:25 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Glassing..
The one down side to the GWS foam planes is that they are very easy to dent. These dents accumulate to make a rather shabby looking plane.
My E-starter is only a few weeks old, but the foam around the battery tray is pretty ugly. Even with a coating of water based clear coat.
The other issue with them is cleaning.. I fly off a grass field, and the grass will make a lovely mess of the bare foam.
So with these issues in mind, I have been debating the glassing process on my 190. I expect to have the plane for a long time, so why not spend a little more time to make her nicer?
My current thought is to only glass the bottom of the wing and fuse and a bit around the battery hatch, and just clear coat the rest. I picked up the lightest weight glass at the LHS, but it is 2 oz.. So don't want to glass the whole thing with this.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old May 07, 2007, 12:32 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
GWS glue..
On another subject. I have used nothing but the GWS glue on this build. I am having issues with very slow cure times! I used it as a contact glue when joining the wings. It grabbed pretty well when I first touched them together, but even after 3 days it still dribbles fresh glue out of the joint. It is finally strong though.
I also used the glue for the spar. I highly recommend you use an epoxy for this joint. Talking to another builder that also used the GWS glue on the spar he reports the same issues. It will not cure, and keeps puking out more glue from the ends of the tubes, center section, and sometimes middle of the wing. I did not think I put too much glue in either! (I also do not recommend Sumo or Gorilla for the spars as the foaming tends to make an ugly joint that can be tough to clean up.)
The GWS glue seems to work best on smaller joints.
I do like the GWS glue, but I have learned a little more about its use.
-Wayne
Site Sponsor
Old May 07, 2007, 12:58 PM
The Bandit is offline
Find More Posts by The Bandit
The art of Crashing
Joined Dec 2006
-Wayne
2oz. is pretty heavy. I would have your LHS special order some .75oz or go online and order some. I glass the majoirity of my planes, for the finish and durability. With practice, you can get your planes to come in at weight most of the time. Or just go down in battery size. I think the trade-off is worth it.
The Bandit is offline Find More Posts by The Bandit
Old May 07, 2007, 03:42 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Wayne,
GWS glue is a contact cement. In order for it to set up properly, you need to apply glue to the surface, and let it air dry for about 5-10 minutes. What I typically do is put a generous amount of glue on one side, press the parts together briefly, then set them aside for 10 minutes. Once the glue feels "tacky", it's ready to go. A word of caution, you only get one shot to line the parts up correctly. If you can still move the parts around after assembly, then you need to pull them apart and let the glue set up a few more minutes.
I use GWS glue as much as possible. It's free (comes with the kit), and I have several tubes lying around (I only open a new tube when I finish one off, so I have several tubes from my many GWS kits). I generally only use epoxy on the spars and control horns.
Oh, and as The Bandit said, 2oz cloth is way too heavy. Try finding some in the .5 - .75oz range.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old May 07, 2007, 04:16 PM
sebsoupe is offline
sebsoupe's Avatar
Joined Mar 2005
Hello!
paint is not dry yet ...
Bye,
sebsoupe
Old May 07, 2007, 09:26 PM
BenziT is offline
Singapore
Joined Mar 2007
Any online shop to get the FG ?
Old May 08, 2007, 03:34 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
One of Taiwan's flyer posted his FW-190 cowling melt like this:
GWS4CEO is offline Find More Posts by GWS4CEO
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
