This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Feb 01, 2013, 10:35 AM
nigelsheffield is online now
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
Yeah, she's nice as long as speed is up.
I let someone who had never flown rc planes b4 toss a pilon racer with a nitro engine years ago, I told him to run a bit and then throw it hard and level, we were in a small ish field with trees all around, he ran all the way across the field and threw it right at the trees with the wings almost vertical, how I managed to fly out of it I still dont know to this day lol.
WHen I asked him why he said he was waiting for it to lift out of his hand or me to tell him to let it go but he could not here me shouting due to the nitro engine.
Was very funny but I always make it very clear what I want from people if I ask them to throw my planes now lol.
nigelsheffield is online now Find More Posts by nigelsheffield
Old Apr 29, 2013, 08:23 PM
fvega is offline
Find More Posts by fvega
fvega
United States, VA, Newport News
Joined Jul 2007
what control throws are most folks using?
fvega is offline Find More Posts by fvega
Old Apr 30, 2013, 12:15 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
lots on the ailerons and rudder . very little on the elev.
chas650r is offline Find More Posts by chas650r
Old Apr 30, 2013, 09:34 AM
2RK is offline
2RK
Find More Posts by 2RK
2RK
United Kingdom, England, Hampshire
Joined Jun 2011
As per the manual, but only 50% on the elevator.
2RK is offline Find More Posts by 2RK
Old May 08, 2013, 01:27 PM
Joined Oct 2007
As manual to start but after trimming and moving cog back some, lots on ailerons and rudder but hardly anything on the elev, I would suggest using lots of expo on elev till you get the right amount of movement to suit your flying style.
Old Dec 11, 2013, 11:01 PM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
well i flew mine the other day with just a 3s 2200, havnt done that in a long time. i bet anything that the planes that are tip stalling are way to tail heavy with to much elevator control. my elevator berly moves up and down i would have to double check when i get home but i am pretty sure no more then a 1/16. i set my throws and cg so it flyes like a big plane not a foamy so the turns and loops and what not are smooth and take sky to do. i did move the battery back to far and it got to flying like foamy and acted funny so i had to be real light on the sticks. once landed i moved battery foward and she calmed down. hope this helps
it still the best flying electric i own.
later andrew K
57sailplane is offline Find More Posts by 57sailplane
Old Feb 27, 2014, 10:15 PM
semperfi1970 is offline
Find More Posts by semperfi1970
semperfi1970's Avatar
Joined Feb 2012
Originally Posted by 57sailplane View Post
um,
realy havnt seen a problem with landing this thing without flaps, when i load this thing up for long flight times i use a 4s 5000mah pack and the plane weighs in at 56 oz. its hard on the heavier gear i use as it bends it on taxi but still lands well, need to put even heavier gear in.
when i land with all this weight i am realy pulling back on the stick and cloping the plane it realy holds in the air nicely.
later andrew k
57sailplane, where in gods name did you fit a 5000mah 4s battery in the FW190? I am starting to build one in EPO and plan on using a 4s 1800mah if it fits that is. I was wondering what motor you are running? I am to assume the FW190 will fly very much like the GWS P-40.
semperfi1970 is offline Find More Posts by semperfi1970
Old Mar 01, 2014, 10:08 PM
Joined Nov 2008
well its hoged out to the max in the battery compartment. its been a long wile since i have flown this bird.. with that big battery you realy have to touch here in. the extra heavy gear installed still is way flimsy with that battery. if you look back through this blog at the pics i think its in here. the motor is a red and blue tunigy 850kv that i run a 9x9 on. there are a lot better choices these days though.. for power and speed. found it here you go..
later andrew k
Old Mar 02, 2014, 08:07 AM
Joined Feb 2012
My FW190 is the EPO version and surprisingly light for how chunky the fuse is. I have yet to decide what motor to run in it, I was leaning towards a 480. I will have to see how the plane balances out with various motors and batteries. Here is the plane so far.
Old Mar 02, 2014, 08:53 PM
richard9999 is offline
Find More Posts by richard9999
richard9999's Avatar
Sydney, Australia
Joined Jan 2007
Very nice, don't forget the top of a Dove deo for a fairly scale spinner. It mounts on an HK 30 mm collet spinner. My FW-190 is a Tian Sheng (now discontinued), but about the same size.
richard9999 is offline Find More Posts by richard9999
Old Mar 02, 2014, 09:29 PM
Joined Feb 2012
The Butcher Bird is coming along nicely for me. I am far from done but here it is so far. I ended up taking a motor out of a 1200mm Dynam P51 for the GWS bird. The motor looks to be a 15 size motor. I will be running a 11x7x3 blade prop on it. To start I will run 3s, just may end up on 4s. The motor took the bigger P51 vertical, wonder what it will do for the little FW190
Old Mar 03, 2014, 04:34 AM
CaseySP is offline
Find More Posts by CaseySP
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Brilliant!!
CaseySP is offline Find More Posts by CaseySP
Old Mar 03, 2014, 06:36 AM
Sydney, Australia
Joined Jan 2007
It wasn't my original idea - some guy whose wife used Dove , but you can buy the Dove Deo in Oz. I have a lathe, so drilling the holes in the cap and shaft of the collet spinner holder was quite easy, but there may be other ways of attaching the Dove cap if you don't. For painting the white spirals, spray the cap all white, apply auto pin striping tape, spray black and remove the tape. The Hobbyking masking tape, cut down thin, might be even better.
Old Apr 06, 2014, 05:38 PM
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
well it's been a while since i've been in this part of rcg, in fact i started my re-addiction to rc with gws (beaver and then spitfire) back in 2003, anyway to the point lol. when i was in the garage earlier today looking for some fence paint i had stuck past i came across three boxes that i had totally forgotten about since the house move, as you can see the area where the other boxes weren't covering it is a little dusty lol
iirc i got this bird round about christmas 2007, and since then it was in my 'to build' pile then lost in the garage loft lol, so with the new season on it's way and as i have just about everything needed equipment wiseit's time to do this bird some justice i'm pretty much decided to do her up as 'red 23'
i've still to get a motor so i've some reading to do to see what has been working well
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Apr 06, 2014, 08:22 PM
Sydney, Australia
Joined Jan 2007
All I would say, as a great lover of the FW-190, is that a paint scheme where the underside is notably different to the upperside might be better. Especially if you fly in grey skies, it is easy to loose orientation with the camo, and these things fly fast.
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
