This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Aug 23, 2009, 05:27 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
ill save up some more and grab that turnigy motor , would that also be suitable for a depron f18 ? such as this one
http://cgi.ebay.co.uk/6mm-DEPRON-6-X...d=p3286.c0.m14
if so i might as well wait and order 2 and save on the excessive postage. lol .
scousethief is offline Find More Posts by scousethief
Old Aug 30, 2009, 12:24 PM
mtnflyer44 is offline
Find More Posts by mtnflyer44
Rocky Mountain High
United States, CO, Gunnison
Joined Nov 2006
Here is my FW190. She has approximately 40 flights. I had a real problem seeing the blue/gray factory paint against the blue sky. After several close calls; I finally lost her and broke the tail at the panel lines in front of the stabilizer.
I decided white might show up better, so I did a quick repaint with H20 and black painters chalk mixed with white acrylic.
I have enjoyed the FW190 and hope GWS will release something new for us by Christmas.
mtnflyer44 is offline Find More Posts by mtnflyer44
Old Aug 30, 2009, 12:34 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
i think you will like the white, mine is very close to yours, i used lots of yellow on the bottom, front of cowl , all
the way to the tail and large wing tip area( length of aileron).chuck.
chas650r is offline Find More Posts by chas650r
Old Aug 30, 2009, 09:35 PM
mcsarge is offline
Find More Posts by mcsarge
V=IR
mcsarge's Avatar
Virginia Beach, VA
Joined May 2005
Looks like you used screws to secure the cowling - care to elaborate on that? I am about to do the same, as I had my cowl get pushed into the prop with bad results.
Matt
mcsarge is offline Find More Posts by mcsarge
Old Sep 01, 2009, 10:12 PM
Rocky Mountain High
Joined Nov 2006
I had similar problems.
I discarded the black button for the cowl and the black receivers glued on the fusealage. Cut 3/8 inch hard balsa squares to replace the black receivers. Glued them on with foam CA. Used servo screws to attach cowl through the existing holes in the plastic cowl. Removed screws and put a drop of thin CA in the screw holes in the balsa squares so they will stay tight.
Have about 10 flights so far with no cowl problems.
Old Sep 12, 2009, 05:22 PM
Joined Jan 2006
Turnigy motor finally arrived today , in place with 30 amp esc and 2200mah lipo , seems very tail heavy , dug out some of the foam in the battery compartment to move the batt forward about and inch may have to move it more. Mau have to get a bigger prop the 9x6 maybe a little small ?
Old Sep 12, 2009, 05:35 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
what motor was that?
Old Sep 12, 2009, 06:01 PM
Joined Jan 2006
motor is a turnigy 1100 kv motor from hobby city , im guessing a 10x4 would be more suited to this motor ?
Old Sep 12, 2009, 06:08 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
what are the other numbers? such as tgy 35-36- 1100? or 30-35- 1100?
Old Sep 12, 2009, 06:09 PM
Joined Jan 2006
TURNIGY 28-30-azj 14A 1100Kv Brushless Outrunner
is the motor name.
Old Sep 13, 2009, 02:02 AM
GPT is offline
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
For the FW190 your best with a 10x6 to 10x7 prop. My Hyperion 3007 1050kv is happy spinning a GWS 10x8 HD prop not sure if the turnigy will be.
GPT is offline Find More Posts by GPT
Old Sep 14, 2009, 04:11 AM
Joined Jan 2006
Ordered a couple of different sized props , see if they make ay difference when they arrive.
Old Sep 14, 2009, 09:52 AM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
also if you run a differant brand of prop that can make all the differance in the world.. there is a major differance in my opinion between an apc electric prop and a gws hd prop..
57sailplane is offline Find More Posts by 57sailplane
Old Sep 14, 2009, 01:41 PM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
It sounds like your motor may be a bit on the lower end of power for this size plane.
You might try the APC slow prop 10 x 4.7 to keep the amps down for your motor.
Good luck,
Kevin.
is the motor name.
RCDad is offline Find More Posts by RCDad
Old Sep 14, 2009, 08:41 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
Good luck,
Kevin.
i agree with rcdad, the motor may be small, also dosent weigh much , adding to your tail heavy problem. imo i would not go less than 4.7 pitch with 1100 kv because your pitch speed will be to low. i use that same 10x4.7 apc sf on a pattern ship, and at 200 watts i get 8000 rpm ( 35 mph pitch speed). the fw190 at close to 2 lbs needs to fly on the faster side. you may have to go down to the 9x6 or 9x7.5 to get the needed pitch speed . just be sure to check your amp draw as sf props draw more amps than you might think. ( more than the same size apc e prop)
chuck.
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 03:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 09:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 03:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 11:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 10:50 PM
