This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jul 21, 2009, 07:36 AM
Fidy$Trainer is offline
Find More Posts by Fidy$Trainer
USA, GA, Atlanta
Joined Sep 2008
Originally Posted by GWS CHEN
GWAEO025AA is GWS-190 NPS white version in EPO, while GWAEO025B is painted NPS version in EPS.
It's hard to use water-based paint to paint the EPO kit.
Hope these would be helpful.
Chen
Chen,
What type of paint stick well to the EPO foam that you would recommend? Someone recommended an DupliColor Adhesion promoter for the water based paint.
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Old Jul 21, 2009, 09:41 AM
mcsarge is offline
Find More Posts by mcsarge
V=IR
mcsarge's Avatar
Virginia Beach, VA
Joined May 2005
Originally Posted by Fidy$Trainer
Chen,
I used WBPU (water based poly urethane) and the paint seems to stick really well. All I did was use some white filler to fill in the panel lines and some of the areas where the expanded beads had some gaps between and then sand the filler smooth. I then applied the first coat of WBPU and then sanded again. Another coat of WBPU and sanded again with finer paper. Then I gave it to my friend to paint with water based acrylics from Michael's (Apple Blossom paints, I think)
If I had to do it over again, I would have first cleaned the molded parts thoroughly with rubbing alcohol to remove any mold release. I have never used the adhesion promoter, so it might have been a good substitute for the WBPU. If that was the case, I would have done one more coat of the promoter after the final sanding.
Matt
mcsarge is offline Find More Posts by mcsarge
Old Jul 21, 2009, 03:48 PM
haiduk is offline
Find More Posts by haiduk
Pronounced "High Duck"
haiduk's Avatar
Marysville, WA
Joined Oct 2008
The Adhesion Promoter is amazing on the EPO, but you will still want to clean the release agent from the foam with alcohol before applying the Adhesion Promoter. I have used the WBPU in the past. The Adhesion Promoter makes for a much better base for the water based paints. It is also much lighter than WBPU.
Water Based paints do work very well on EPO if the foam is first prepped.
haiduk is offline Find More Posts by haiduk
Old Jul 21, 2009, 09:46 PM
USA, GA, Atlanta
Joined Sep 2008
Great for the heads up I use MinWax satin instead of the glossy, WBPU. I'll just use that before I paint. I use this to glass my planes as well with some fiber cloth but I don't think it's necessary hear.
Matt
Anyone have experience with GWS nano Retract Gear set on the 190? Does it fit or is it too small or big? What kind of servo was used? I saw somone else post they used retracts and they were a little too tall but not sure if these were the same ones.
Old Jul 22, 2009, 11:49 AM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Still waiting Jeff.........
Kevin.
Originally Posted by RCDad
Hi Jeff, Thanks for coming back to this. From you pictures I think the decals I got from Callie are not the same size as yours.
Here are the measurements of what I have:
2 11/16" wing cross
2 9/16" fuse cross
1 6/16" swastika
Could you measure yours to see if they are the same?
Kevin.
"Hey RCDad-
Did you ever get the answers you were looking for? Sorry, I totally forgot about your question..
If you didn't, let me know and I will measure mine..
Jeff"
RCDad is offline Find More Posts by RCDad
Old Jul 23, 2009, 02:38 PM
speedracer24 is offline
Find More Posts by speedracer24
Solidworks
speedracer24's Avatar
Stanfield,NC
Joined Apr 2007
Anyone recommend a good motor for this bird w/o breaking the bank or swinging a large prop?
speedracer24 is offline Find More Posts by speedracer24
Old Jul 23, 2009, 04:55 PM
RCDad is offline
Bay Area
Joined Feb 2004
I would recommend a SUPPO 2217-08 from lightflightrc. It goes for about $19 and would swing a 10x5 or 6 prop.
• 70g Outrunner
• Kv: 1100, Rm: 0.125, io: 1.0A, Poles: 14
• Max amps: 18A for 60sec
• Shaft is 4.0 mm
• Dimensions: 27.5mm x 30mm
I'm using a Suppo 28-14-08 because I wanted a bigger motor for extra weight up front. The bigger motor is $27 and it is out of stock.
Good luck.
Kevin.
Old Jul 23, 2009, 05:04 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
You get some new decals ordered up?
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jul 23, 2009, 05:18 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I have had very good results using The following combination:-
Motor http://www.unitedhobbies.com/unitedh...idproduct=6247
ESC http://www.unitedhobbies.com/unitedh...?idproduct=656
Batteryhttp://www.unitedhobbies.com/unitedh...idproduct=6293
The propeller I use is a GWS 10 X 8 HD. Thrust with this propeller was measured at 28.6oz with a static pitch speed of 51.8 mph.The current draw was 15.5 Amps. So an !800 mAh battery is enough to give 8-10 minutes flight including some part throttle flying for practice approaches.
Ken
kensp is offline Find More Posts by kensp
Old Jul 23, 2009, 05:19 PM
Solidworks
Stanfield,NC
Joined Apr 2007
• 70g Outrunner
• Shaft is 4.0 mm
Good luck.
Kevin.
Right now I have a Turnigy sk aerodrive 35-30/1100kv on it and I have tried 3 dif prop sizes 12x6 apc, 11x8 apc and a 13x6 or 13x8 cant remember and cant get over 140 watts. Batteries are fine. What am I missing here?
Old Jul 23, 2009, 05:46 PM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
that motor should work verly well.. you should pull more watts than you are though. what size battery are you running?
57sailplane is offline Find More Posts by 57sailplane
Old Jul 23, 2009, 06:53 PM
Hack73 is offline
Find More Posts by Hack73
Never look down
Hack73's Avatar
United States, MD, Elkton
Joined Jun 2007
Ken
Any videos of your plane with that setup?
Hack73 is offline Find More Posts by Hack73
Old Jul 24, 2009, 12:05 AM
Solidworks
Stanfield,NC
Joined Apr 2007
3s 2200 20c.
Old Jul 24, 2009, 01:14 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Sorry but I do not have video of the model flying with this set up.
Ken
Old Jul 24, 2009, 09:46 AM
RCDad is offline
Bay Area
Joined Feb 2004
Yes, thanks Tram for you PM. I wanted to check with you before contactig Callie. She is sending the correct ones out free of charge.
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
