This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jun 24, 2009, 09:27 PM
speedracer24 is offline
Find More Posts by speedracer24
Solidworks
speedracer24's Avatar
Stanfield,NC
Joined Apr 2007
I have a question for you guys, I an running a Turnigy 35-30 1100kv motor with an E-Flite 40 amp esc powered by a 2100 3 cell Li-Po. I have tried an 11x8e APC, 12X6e APC and a 13x8e APC and for some reason I am only getting like 100 watts(or less) going down from the 13x8. Am I missing something here? What do you guys think could be the issue?
Thanks.
Chris.
speedracer24 is offline Find More Posts by speedracer24
Old Jun 24, 2009, 10:26 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Thanks.
Chris.
I Just used MotoCalc to look at your set ups and found that with those larger props you are only running at 45-55% efficiency.
Try a smaller propeller such as the GWS 10 x 6 for thrust or the GWS 9 x 7.5 for speed. These propeller will allow the motor to rev out and give efficiencies of around 75%.
Ken
kensp is offline Find More Posts by kensp
Old Jun 24, 2009, 11:44 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Originally Posted by plane pain
hi all.
been following this thread for sometime and finally brought a gws fw190 the other week, been flying a hobbyzone supercub and art tech p51.
i've got a few more things to do but its almost there, this is my first attempt at airbrushing aswell as putting together a gws kit. Will probably stick with gws kits for a while now as im really impressed with how easily they go together and the end result.
a parkzone p51/spitfire pilot had to defect to the otherside for this build.
should be ready for its maiden by the weekend.
cool paint, nice job. i also was impressed by ease of build,fit and finish. no headaches here. im just missing the swastika. wish they were inc. in kit. anyway good luck with maiden, chuck.
chas650r is offline Find More Posts by chas650r
Old Jun 24, 2009, 11:48 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
Originally Posted by fredo21
In addition to making the UC stiffer you might try setting a bit of toe-in on the main wheels. This aids stability on the ground.
Stuart
stuart , thanks for the input, i will try some to-in . chuck
Old Jun 24, 2009, 11:59 PM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
reply to speedracer24
hmmm somthing is fishy here. i ran motor calc also and i also cam up in the 55% range nothing much lower than that. each were pulling around 150watts after losses..
i agree the smaller props will work better for you. that 11x8 should work for you though.
which turnigy is it that you have the black SK or the orange xp.. the reviews show them to have differant kv as i have not tested them yet..
what is the C rating on your battery. how old is the battery.. do the cells balance out.. i am sure you have thought of this but you never know..
anyways later andrew k..
57sailplane is offline Find More Posts by 57sailplane
Old Jun 25, 2009, 12:05 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
haiduk, thanks for further info on flaps and gear .chuck.
Old Jun 25, 2009, 08:12 AM
Hack73 is offline
Find More Posts by Hack73
Never look down
Hack73's Avatar
United States, MD, Elkton
Joined Jun 2007
I think something is wrong with MotoCalc lately. I used it several months back and got good results. Using that same data again, nothing matches up and efficiency doesn't go above 40~50%.
Hack73 is offline Find More Posts by Hack73
Old Jun 25, 2009, 08:29 AM
plane pain is offline
Find More Posts by plane pain
the ground is hard
england
Joined Jun 2009
i chopped up the open black lined cross that comes with the sticker pack and used that.
plane pain is offline Find More Posts by plane pain
Old Jun 25, 2009, 09:23 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
good idea, thanks, chuck.
Old Jun 27, 2009, 01:50 PM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
You can also get them from early releases of the GWS262 kit, before GWS started peeling them off and throwing them out, before shipping the kits.
WTFLYR is offline Find More Posts by WTFLYR
Old Jun 27, 2009, 07:31 PM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Ok, why did GWS omit the swastika on the decal sheet? No speculations please.
Kevin.
RCDad is offline Find More Posts by RCDad
Old Jun 28, 2009, 05:37 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
P.C. And concerns of negative impact on sales.
JimNM is offline Find More Posts by JimNM
Old Jun 28, 2009, 07:30 AM
mcsarge is offline
Find More Posts by mcsarge
V=IR
mcsarge's Avatar
Virginia Beach, VA
Joined May 2005
Kevin.
I read about this before, I think it is because in some countries you are not allowed to include them at all. I think it we Germany. Not exactly speculation...
Matt
mcsarge is offline Find More Posts by mcsarge
Old Jun 28, 2009, 07:35 AM
Big Fran is offline
Find More Posts by Big Fran
I need a bigger Hanger!
Big Fran's Avatar
Philadelphia, PA
They still have them on their ME-109 decal sheet.
Fran
Big Fran is offline Find More Posts by Big Fran
Old Jun 28, 2009, 08:16 AM
WTFLYR is offline
WTFLYR's Avatar
West Central PA
Joined Dec 2008
Kevin.
This has been brought up before. Some countries do not allow the display of the swastika, even on models, simply for historical accuracy. GWS would have to specifically manage and ship different versions of of the kit with different sticker packages, to satisfy the requirement.
On the 109, this is speculation, but the release is older, and in essence probably does not get the attention of a newer release such as the 262, due to "grandfather clause" obscurity. The world is more politically correct in recent times, than when the 109 was released.
BTW, the 109 decal set is excellent for scale detailers, and actually has many of the small text warnings that were placed on various areas of the full size plane. I'd buy a few, if my LHS had them, or if they were stocked reasonably priced at a reputable online dealer.
On the 262, what upset me was seeing them torn off. A new label release without them whatsoever would have been fine, but to see that you "could" have had them is irritating. I'm not a nazi either, just a scale detailer.
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Kit/Scratch Built 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
