Old Feb 14, 2007, 02:09 PM
Plat3au is offline
Find More Posts by Plat3au
Dallas, TX
Joined May 2006
Help!
Zagi XS Pro Kit -- I Need Help Pushing The Limits
Ok, here’s the current power setup:
Zagi XS Pro Kit 48” (chopped down to 40”)
Mega 16/15/3 w/ Heat Sink
E-Flite 40 amp ESC w/ BEC
Kokam 3s1p 2000 mAh 15c LiPo (+1 spare)
5.25 X 4.75 APC Prop
Specs:
Flying Weight: 25 oz
Current Draw: ~30 amps
Results:
Top Speed: 80-90 MPH
Problem:
It takes too much time to build up that speed and the vertical climb rate is poor. So basically, I want more power.
Now I've talked to several guys at the local hobby shop and they all say different things. One said I'm using the wrong prop but I've metered a dozen different props (including the one he suggested - APC 5x5) and the 5.25 X 4.75 gets me the most bang without exceeding the 30 amp limit that the motor and battery have. Another guy said that I need to buy the Mega 16/25/3 motor w/ 7x7 APC prop, which I'm sure would throw off the cg on my zagi but no big deal if it would do the trick. And yet another guy recommended that I toss the E-Flite 40 amp ESC and get the Phoenix 45 or 60, then run my two lipos in series making a 6s1p 2000 mAh 15c LiPo. But I'm not sure if that would blow up my zagi or not. Sounds a bit hot.
Has anyone tried any of these suggestions or can you think of other ways to get this baby doing unlimitted vertical?
Any help would be greatly appreciated.
~Brad
Plat3au is offline Find More Posts by Plat3au
Old Feb 14, 2007, 03:19 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
Maybe try something along these lines?
http://www.rcgroups.com/forums/showthread.php?t=641614
Challenger413
If using the CC45 at 5S or the CC60 at 6S, you have to de-rate the controller by 20%.
Challenger 413 is offline Find More Posts by Challenger 413
Sold Zagi XS Pro Kit Yardbee Aircraft - Electric - Airplanes (FS/W) 2 Oct 01, 2006 02:33 AM
Zagi.. STOCK AVEOX ESC.. Need help ASAP Tram Foamies (Kits) 1 Dec 18, 2001 08:29 PM
Need help powering a 12 oz Zagi for indoor flight GHarvey Parkflyers 9 Nov 03, 2001 08:37 AM
need help with clipped Zagi 400 BigBadWolf_600 Power Systems 2 Jul 10, 2001 03:03 AM
Need help flying a Zagi!!! I'm in AZ Josh C Beginner Training Area (Aircraft-Electric) 10 Jun 30, 2001 02:05 AM
