Old Feb 14, 2007, 11:31 AM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
Help Please! Sorted-see my last post!!
I did have a problem but have managed to sort it out.
electriceye is offline Find More Posts by electriceye
Last edited by electriceye; Feb 14, 2007 at 12:23 PM. Reason: Sorted my problem out!
Old Feb 14, 2007, 12:00 PM
tommy321 is offline
Find More Posts by tommy321
Glow Free Since Aug, 2005
tommy321's Avatar
Ottawa, Ontario, Canada
Joined Aug 2004
Are you sure your crystals are correct?
I just looked up at greathobbies.com and they show Channel 69 Crystals as 75.570MHz. (not 35MHz)
The receivers and transmitters also tend to be fairly brand specific when it comes to crystals. Are you sure your receiver crystal is compatible with the ESky receiver?
tommy321 is offline Find More Posts by tommy321
Old Feb 14, 2007, 12:06 PM
littleport2003 is offline
Find More Posts by littleport2003
United Kingdom, Leighton Buzzard
Joined Sep 2004
I used to use a 6EXA with one of these esky RXs, and never had a problem, the only thing I can think it might be is that you have the servos plugged into the RX the wrong way, unplug them, rotate the black connector 180 degrees, and plug back in, if that doesn't fix it, switch them back again, and wait for some more replys.
About the crystals, here in the UK we use totally seperate set of channel numbers for 35mhz, you can get channels 55 - 90.
littleport2003 is offline Find More Posts by littleport2003
Old Feb 14, 2007, 12:10 PM
Kiss the Sky
Dorking, Surrey, UK
Joined Jul 2006
Wow thanks for the quick response-As you have been so kind I will have to admit to my error-Had RX crystal in TX and vice versa ( I was kinda hoping I could get away without admitting that!) Sheesh!!! All ok now thanks, just got to fathom out all this Expo programming etc!!! Many thanks again, I feel really dumb!!!
Old Feb 16, 2007, 06:36 PM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
electriceye
re spit tiled pdf
check your PM.
Gramps
chaosMurphy is offline Find More Posts by chaosMurphy
Old Feb 18, 2007, 09:17 PM
Joined Dec 2006
Get back to me on PM and/or here, your choice.
If this file gets in the 'way' here I will pull it off.
Enjoy,
Gramps
Old Feb 19, 2007, 04:30 AM
Kiss the Sky
Dorking, Surrey, UK
Joined Jul 2006
Many Thanks-I will post it in the plans section in case there are others who want to use it also-I have saved it to build when I have another project out the way.
Help I can't see my plane any more! Mr B.... Thermal 7 Nov 01, 2007 11:37 AM
Thanx Everyone...My last post for awhile ratman Electric Plane Talk 5 Oct 01, 2002 07:56 PM
Twinstar 4 Sell - See my other post kjkish Foamies (Kits) 0 Apr 26, 2002 01:04 PM
might have put my last post in wrong area Razor real slow kushal_22 Foamies (Kits) 1 Mar 27, 2002 06:20 PM
