Old Feb 13, 2007, 03:39 PM
grampi is offline
Find More Posts by grampi
Joined Jan 2005
What's the best rate to charge lipos at?
I just received my DN charger and it has adjustable charging rates. What's the best rate to use, and is there a rate I don't want to use? Thanks.
grampi is offline Find More Posts by grampi
Old Feb 13, 2007, 03:42 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
I am not trying to be rude, but if the instructions are un-readable, read some of the sticky posts above at top of page. Knowledge is everything with these types of batteries. Be careful.....
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Feb 13, 2007, 03:57 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
The best rate is C or below. The rate you don't want to use is more than C. If you don't know what C means you need to find out in a hurry.
Steve
slipstick is online now Find More Posts by slipstick
Old Feb 13, 2007, 04:00 PM
Motions is offline
Find More Posts by Motions
Motions's Avatar
Tallahassee, FL
Joined Nov 2005
I charge mine at .5C and I never have to balance. If you want some really good info on lipos, check out this page http://www.bladebusters.com/batteryguide.html
Motions is offline Find More Posts by Motions
Old Feb 13, 2007, 05:59 PM
dmiller746 is offline
Find More Posts by dmiller746
I havent decided yet
Indiana
Joined Jun 2006
2100mah = charge rate of 2.1 amps. 1300mah = charge rate of 1.3amps. slower is "better" and faster is not good
dmiller746 is offline Find More Posts by dmiller746
Old Feb 13, 2007, 09:10 PM
J Stumbler is offline
Find More Posts by J Stumbler
J Stumbler's Avatar
Buckeye Country
Joined Feb 2007
Here is a link to some good nuggets regarding general lipo usage, including charge rate.
Lipo Nuggets
I hope that helps.
J
Commonsenserc.com
J Stumbler is offline Find More Posts by J Stumbler
Old Feb 13, 2007, 09:31 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
RTM
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Feb 14, 2007, 12:14 PM
grampi is offline
Joined Jan 2005
So since my battery packs are 1320 mah, that means I should keep the charge rate at or below 1.3 amps?
Old Feb 14, 2007, 12:50 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Correct.
mw
Old Feb 14, 2007, 01:23 PM
Motions is offline
Motions's Avatar
Tallahassee, FL
Joined Nov 2005
.6-.7 amps would be even better. Your packs will last much longer.
Old Feb 14, 2007, 02:38 PM
grampi is offline
Joined Jan 2005
How long will it take to charge a pack at this rate? Also, I need to know if I understand how this DN charger works. It will charge 4 batteries at the same time, but can they all be 3 cell packs?
Old Feb 14, 2007, 03:18 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
It can charge 4 cells at one time not 4 batteries. It can charge two 2 cell batteries, a 1 cell and a 3 cell etc.
If you charge a 3S 1320 at 1200 mA it will take approx. 90 to 100 minutes. If you charge at 600 mA it will take approx. twice as long. There is really no reason not to charge your 1320 at 1200 (1.2A) or even 1400 (1.4A) as this is a multi channel balancing charger.
In years past I also believed that charging at less than 1C would help LiPolys to last longer. Now that 10C and greater LiPolys are common I now longer have such beliefs. I routinely charge at 1C plus however 1C is the recommended max. of most LiPoly vendors.
http://www.rcgroups.com/forums/showthread.php?t=535274
Charles
Old Feb 14, 2007, 03:33 PM
Motions is offline
Motions's Avatar
Tallahassee, FL
Joined Nov 2005
I charge multiple batteries at once at C which leaves the cells perfectly balanced. I don't have a need to quick charge and rather have all packs done at once rather than swapping every hour.
It comes down to preference and experience.
Old Feb 14, 2007, 03:40 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
A very good tutorial on batterys can be found at www.batteryuniversity.com/partone.htm
This is quite lengthy and thourough but well indexed so you can choose the sections you are interested in. An extreemly good source for reliable information from the CEO of Cadex Electonics Ind.
Rodney is offline Find More Posts by Rodney
Old Feb 14, 2007, 03:47 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
I was going tpo jump in here and chastise grampi for not reading the DN Power manual. That is until I read it. Wow!
For example, this extract:
"6. The charger can charge for four batteries at one time at best. If it charges for more
than four batteries at one time, it will most probably damage the charging
batteries. Therefore, when a pile of three batteries and a pile of two batteries are
charged at one time, some battery of one pile must be parallel-connected with
some battery of the other. If the voltages of the two batteries are six to one, the
charging batteries may be damaged. This kind of implementation is not
recommended."
And other statements are even more confusing.
"4. if the charger clews it is charging in series-wound form and alarms when it is
charging in parallel connection form, there maybe two reasons:"
Bill
ebill3 is offline Find More Posts by ebill3
Question What's the best sub-$40 power supply I can get for charging lipos? birdlives1955 Batteries and Chargers 13 Aug 22, 2007 10:42 AM
What's the best way to charge lipo 'chunks' vaportrail Electric Heli Talk 16 Aug 29, 2004 02:52 AM
What's the best P-38 kit out there? slowflyer Scale Kit/Scratch Built 20 May 14, 2002 07:33 PM
What's the best all round sub $60 400 sized engine? AlexP Power Systems 6 Aug 02, 2001 09:21 AM
What's the best E-prop? mrtim Power Systems 3 Jul 20, 2001 07:57 AM
