Old Sep 30, 2002, 01:41 PM
Commando is offline
Find More Posts by Commando
Ft. Collins, Colorado
Joined Aug 2002
Hard start versus soft start electric motors
I have just installed a Mega 30/4 with a 2/1 planetary gearbox on a Rascal 40 conversion. I am using a Jeti/Hacker 30 Optical ESC. The prop. is an APC 16x12 electric. When I advance the throttle, I get a really sudden "hard start" on the motor, with a loud "clack." It runs fine, but I worry about damage to the gear box or motor from the hard start. I have tried lowering the trim for the throttle on the transmitter, and I have also put in 50% negative exponential on the throttle, but nothing seems to prevent the sudden and loud "hard start." Anybody have any ideas? Do I have a unique problem or is this something to be expected? Maybe I shouldn't worry about it, but I am accustomed to quiet, gradual "soft starts" on several other (smaller) controller/motor/gear systems.
Commando is offline Find More Posts by Commando
Old Sep 30, 2002, 01:57 PM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
So you have the Jeti/Hacker master controller? If so you need to change the timing on it for the mega motor, they come set for Hacker motors as default. that may be your problem.
Steve H. is offline Find More Posts by Steve H.
Old Sep 30, 2002, 04:55 PM
Commando is offline
Joined Aug 2002
Change timing for Mega motor
Hi Cue -
Thanks for the suggestion. I did set the timing for a Mega motor, but your suggestion makes me think I should recheck it --- just to make sure I picked the correct beep-tone sequence.
Old Jul 07, 2016, 02:40 PM
Robert Boudreau is offline
Find More Posts by Robert Boudreau
Robert Boudreau's Avatar
United States, CA, Tracy
Joined Nov 2014
Could anybody help me setup a HSD 150amp ESC to soft start, it came set to soft start, somehow I changed it to hard start & it's makes the motor bang when starting. I think I cane get to startup but what to do after I enter it?
thanks.
Robert Boudreau is offline Find More Posts by Robert Boudreau
Old Jul 09, 2016, 02:17 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Not sure what brand etc. that ESC is but the directions may be available somewhere in PDF. If the ESC has soft start feature you can probably reprogram it for soft start using your transmitter throttle lever and following directions and listening for beeps very carefully. Remove prop before attempting to re-program ESC.
E-Challenged is offline Find More Posts by E-Challenged
Old Jul 09, 2016, 02:40 PM
kc8qpu is offline
Find More Posts by kc8qpu
kc8qpu's Avatar
United States, SC, Moore
Joined May 2007
I am not positive, but I thought I had read someplace that if you are running a gear box you should use soft start.
kc8qpu is offline Find More Posts by kc8qpu
hard start vs soft start...?? sharkman Power Systems 4 Jul 07, 2016 02:38 PM
CC Phoenix 10....hard or soft start question kokamo Power Systems 5 May 21, 2005 08:57 PM
Jeti Advance 70A Hard Start shv2sail Power Systems 0 Sep 30, 2004 10:12 AM
ESC hard/soft start? Will it help? Dr Kiwi Power Systems 2 Sep 08, 2004 04:02 PM
Himaxx hard start WSEN Power Systems 2 Aug 28, 2004 02:13 PM
