Old Feb 12, 2007, 04:45 PM
Stuntman is offline
Find More Posts by Stuntman
Upside down Miss Jane....
Stuntman's Avatar
Georgetown, Newcastle, Australia
Joined Aug 2002
Help!
How to remove sigg sticks-it/balsa lok, etc - any tips out there
I am doing a model restoration and the wing was covered in one of those coverings that require balsa-lok, Sig sticks-it, etc to be applied to the balsa in order for the covering to stick.
The covering is off but I am left with this uneven, rough and annoyingly rubbery finish that needs to come off before recovering.
But how. Sanding is an exercise in frustration as the paper just clogs. I am using a heat gun to slowly melt and strip with a scraper but its not overly succesful either. I am just to about to try a dab of paint stipper to see if it will soften it enough so it can be scraped back cold but this may also affect any glue joints so not overly keen for this method either. -
Is there a way Are there any tips out there that can help me in my quest?
cheers, Shawn
Stuntman is offline Find More Posts by Stuntman
Old Feb 12, 2007, 07:42 PM
the-plumber is offline
Find More Posts by the-plumber
the-plumber
Joined Feb 2003
Coverite's "Ironex". will remove Balsarite, and butyrate dope thinner will remove Sig 'Stix-It'.
Do stay away from GooGone and Goof Off type products - the oil residue(s) will leave you in a worse predicament than you already are.
DAMHIKT.
the-plumber is offline Find More Posts by the-plumber
Old Feb 12, 2007, 08:11 PM
Stuntman is offline
Stuntman's Avatar
Joined Aug 2002
Thanks for the tips. Will hopefully make the process easier and less time consuming.
cheers, Shawn
Discussion How To Remove Warp In Balsa?... James Frolik The Builders Workshop 6 May 24, 2007 09:46 PM
Discussion How to remove oil from balsa for covering??? bigbear3721 Fuel Plane Talk 8 Jan 25, 2006 08:52 PM
Help! How to remove covering off balsa KOMET 44 The Builders Workshop 3 Apr 28, 2005 06:37 PM
Got my Soarstar, any tips on how to build? f2racer Foamies (Kits) 2 Sep 06, 2001 10:56 PM
