Old Feb 11, 2007, 06:50 PM
Woodbutcher is offline
Find More Posts by Woodbutcher
Early aviation nut ....
Woodbutcher's Avatar
Auckland, NZ
Joined Jul 2005
Build Log
Peter Rake IPS Farman Sport monoplane
O.K. - here we go with another of Pete's IPS series designs. This one's a Farman Sport monoplane, the original of which was intended to compete in the 1926 Coupe Zenith. Pete did a Speed 400 design for this plane a few years ago, and there is a build thread of it here
This version is 24" wingspan x 9.5" chord which gives a 228 sq.in. area. If I can hold the weight to 7 oz., that will give me about 4.42 oz./sq.ft. loading.
So far, I plan on using the following electronic kit for the build:
GWS IPS with "A" gearing
7 x 6 GWS prop
2 x Bluebird 303 servos
450 mAh 3 cell LiPo battery pack
GWS Li480 ESC
GWS Naro receiver
The ESC (15A!) & battery pack are definitely overkill, but are all I have available at present. Battery pack weighs 36gr, so it shouldn't be too bad - only 10gr heavier than the 300 mAh packs I usually use.
I did the wing first, as there's a lot of it (comparatively speaking). So far, so good. Now on to the fuselage .....
Greg
Woodbutcher is offline Find More Posts by Woodbutcher
Old Feb 11, 2007, 08:32 PM
SKY KING is offline
Find More Posts by SKY KING
SKY KING's Avatar
Isle of Rhode, US
Joined Sep 2004
Interesting plane.
Looks to be the original flying barn door.
I'll bet you could lose a 10th of an ounce if you removed 2/3rd's of the ribs!
SKY KING is offline Find More Posts by SKY KING
Old Feb 11, 2007, 10:44 PM
Auckland, NZ
Joined Jul 2005
That wing weighs 43 grams (1.5 oz.), motor, servos, battery, receiver & ESC account for another 90 gr (3 oz near enough). Hmmm - only 2.5 oz left of the weight budget if I'm going to stay under 7 oz. Fortunately those are the major weight items in the plane, so hopefully it will all work out in the end.
Old Feb 12, 2007, 03:25 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
You will find the undercarriage and struts make up most of the rest.. the actual woodwork will be sub an oz I would say.
Don't worry about going up to 8oz. It will still fly well on 3s LIPO.
Old Feb 12, 2007, 10:17 AM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
Or elect to go with one of Elec's little 24 gram outrunners on 3S.
Looooeeee! is offline Find More Posts by Looooeeee!
Old Feb 12, 2007, 12:22 PM
Auckland, NZ
Joined Jul 2005
I might give one of those a try when I make the aileron version, Loooeee. They aren't available here as yet - where'd you get yours?
Old Feb 21, 2007, 12:34 AM
Auckland, NZ
Joined Jul 2005
It's been a week or so since I updated this log. I plead pressure of work, getting to grips with a new camera, and being distracted by building an R/C Pistachio version of the Farman for next Monday's indoor group meeting.
However, all is not lost. Wings, tail group & basic fuselage are done, as are the wheels. Next up is R/C gear installation, dummy motor & nose construction.
Old Feb 25, 2007, 05:27 AM
Auckland, NZ
Joined Jul 2005
There's been lots happening these past few days, but not much to show for it, as most of the effort has gone into planning gear placement, cable runs, varying battery locations, etc.
I tried making a paper template to simplify cutting the cockpit & nose sheeting to shape, but it didn't work out properly. As you can see from the pics I wound up making 2 seperate sections instead of 1.
Old Feb 25, 2007, 10:16 AM
PETERRAKE is online now
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Greg,
Looks good mate. Very pretty servos too.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Feb 25, 2007, 11:56 AM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
"Woodbutcher" , huh?!
I like to think of myself as a reasonably tidy builder, but that's wonderfully precise work, much nice than I can do. It always shows in the small-scale jobs. If I did a Speed 400 version twice the size, the build photos might look about as good as your IPS version.
Work in Progress is offline Find More Posts by Work in Progress
Old Feb 25, 2007, 12:30 PM
Auckland, NZ
Joined Jul 2005
Yep! That's what my old woodwork teacher called me, anyway. He also gave me the single most useful homily I've ever heard - "If you make a F@#k-up - make a feature out of it ...
But it's mostly Pete's design which makes for a good fit. All I do is cut the bits out as per plan.
Old Feb 25, 2007, 05:51 PM
Heli Bouncer
Looooeeee!'s Avatar
Joined Feb 2001
Well I really don't have one, yet. I'm pretty sure that United Hobbies carries a clone or a rebadged one under their own Hextronic line of small outrunners. At least it looks the same as the Elec motor, and they get some rave reviews by rewinders and other modders of small motors.
Old Feb 26, 2007, 03:44 AM
Auckland, NZ
Joined Jul 2005
Thanks, Loooeee - I'll try one & see.
Old Feb 26, 2007, 03:20 PM
Norfolk, England
Joined Sep 2001
Greg,
Would one of these be any use? http://robotbirds.com/catalog/produc...roducts_id=158
I had been planning to use it in my Hergt Monoplane but the bulk of the fuselage makes me suspect that the baby AXI might be better. If it looks useful, you're welcome to it.
Pete
Old Feb 26, 2007, 03:35 PM
Auckland, NZ
Joined Jul 2005
Pete,
Looks interesting, and certainly worth a try. Yes, please! Email me with cost & I'll send the funds over.
Greg
Build Log Peter Rake IPS Nieuport Mono 65Chevelle Scale Kit/Scratch Built 139 Feb 08, 2009 08:18 AM
Discussion Peter Rake IPS Hergt Monoplane prototype build jofrost Scale Kit/Scratch Built 82 Jul 26, 2007 04:35 PM
Peter Rake's Farman Sport maiden flight! tim hooper Scale Kit/Scratch Built 27 Feb 07, 2004 03:37 PM
Peter Rake IPS Sopwith Pup build! Trizza Scale Kit/Scratch Built 58 Jan 29, 2004 08:46 AM
