Old Feb 11, 2007, 06:11 PM
Ed Heyman
Ed Heyman
Guest
n/a Posts
AstroFlight Model 110D Charger
This message from "Ed Heyman" <EHeyman@tampabay.rr.com> brought to you by EFLIGHT!
I recently purchased a well used AstroFlight Model 110D Charger. The box has a sticker on it that says "NEW! NEW! NEW! Now You Can Charge Nickel Metal Hydride Cells" so I Know it is old. I down loaded the manual for the current Model 110 Deluxe from the AstroFlight web site and would like to know the differences between the current model and the one that I have. Thanks.
Ed Heyman
--- StripMime Report -- processed MIME parts ---
multipart/alternative
text/plain (text body -- kept)
text/html
*** Any complaints or problems? Send an email to monitor@ezonemag.com
*** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm
*** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm
Old Feb 11, 2007, 08:11 PM
Doug Ingraham
Doug Ingraham
Guest
n/a Posts
Re: AstroFlight Model 110D Charger
This message from Doug Ingraham <dpi@rapidnet.com> brought to you by EFLIGHT!
> I have. Thanks.
The real differences are:
1) No discharger.
2) No fan.
3) Pushbutton to start the charge where the 110DX starts charging when it
sees the battery connect.
The 110D also has a slow rate of charge which if I remember correctly has
a 10 hour timeout while the fast rate has a 1 hour timeout. There is also
a test mode which can be activated by pressing the the start button when
the power is connected to the charger. Dont charge batteries with the
test mode because it pretty much turns the charger into a constant current
source with no timeout. It will ruin batteries. I use the charger in
this mode for cutting foam cores on my Feathercut.
There are pretty much no common parts between the 110D and the 110DX as it
was a complete redesign.
Doug Ingraham
Rapid City, SD USA
Ed Heyman
Ed Heyman
Guest
n/a Posts
This message from "Ed Heyman" <EHeyman@TampaBay.rr.com> brought to you by EFLIGHT!
Thanks Doug.
Ed Heyman
----- Original Message -----
To: <eflight@ezonemag.com>
Sent: Sunday, February 11, 2007 7:32 PM
Subject: Re: [EFLT] AstroFlight Model 110D Charger
> EFLIGHT!
>> I have. Thanks.
> 1) No discharger.
> 2) No fan.
> Doug Ingraham
> Rapid City, SD USA
For Sale AstroFlight Model 115D Charger iker3 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 30, 2006 04:00 PM
For Sale AstroFlight Model 110 Charger Gunny Aircraft - Sailplanes (FS/W) 2 Feb 07, 2006 08:35 AM
F/S: NIB AstroFlight Model 110D Charger J R Purcell Aircraft - Electric - Airplanes (FS/W) 2 Nov 30, 2002 08:13 PM
FS: Astroflight Model 112D charger tripster Aircraft - Electric - Airplanes (FS/W) 3 Jan 11, 2002 08:46 PM
FS: Astroflight 110D Charger bitzerj Aircraft - Electric - Airplanes (FS/W) 4 Oct 11, 2001 05:22 PM
