Old Feb 11, 2007, 09:48 AM
Joined Feb 2007
first flight a disaster!! please help!!
Hi Everyone!
Unpacked and setup my brand new esky Robins 22 today.
Waited a while and accidentally flew the heli straight up into the ceiling! *&*%$£&* hell!!
The top rotors broke and the body has a few tears but nothing major - also the stabiliser came off but I refitted it easily.
I have replaced the 2 top rotors and set it up again.
Things are not good!!
1/The heli sits for ages with the red led on constantly
2/The transmitter leds show red and amber with no greens( the aerial is fully out)
several questions;
am I likely to have damaged the rotor drive mechanism or are they robust? Is anything else likely to have been damaged inside ( wiring ?)
is nothing working because the NEW batteries supplied in the box are discharged so the transmitter is not powered enough to communicate to the heli?
Is the body easy to remove so I can repair it more easily.?
Please advise a newbie who is feeling stupid but desperately wants to get flying!!
GAZZA
hgee is offline Find More Posts by hgee
Old Feb 11, 2007, 10:42 AM
FLYING MAKES MY ARMS SORE
switchback7's Avatar
Joined Jan 2007
Hey, reckon you should have at least one green light on you tx, the cells supplied are crapola, cheap alkalines are good for 30+ flights, not sure about the red light, i'm assuming you doing the start up sequence correctly?
switchback7 is offline Find More Posts by switchback7
Old Feb 11, 2007, 10:55 AM
Joined Feb 2007
Hi
Thanks for reply- I reckon the transmitter batteries are the problem - I also think my transmitter settings have been changed - can you tell me the default settings for a right hand throttle
thanks
Gazza
Old Feb 11, 2007, 11:32 AM
Joined Jan 2007
Um.... not sure what you mean, reverse switches? Plus I have mode 1
Old Feb 11, 2007, 12:33 PM
Joined Feb 2007
I have the throttle control on the right side - I am told this is mode 2.
I have switches below the throttle (normal/reverse)and also sliders in other places.
Can someone tell me where to go to see what the standard settings for my transmitter should be?
thanks
Gazza
Old Feb 11, 2007, 12:46 PM
Joined Jan 2007
Ail = Rev Or Up
ele = Rev
Thr = Nor Or Down
Rud = Nor
Old Feb 11, 2007, 12:52 PM
Joined Feb 2007
thanks for the info!
I have now got the bird working with fresh tx batteries!
I am finding the control tricky!!
Getting set up for stable hover seems difficult!
Any tips would be appreciated!
cheers
Gazza
Old Feb 11, 2007, 01:00 PM
Joined Jan 2007
You need to get it about 3ft off ground for full stability, its own downdraft interfears below this (ground effect) but don't forget large objects close by will cause some instability, u just got to practise dude all part of the fun, recommend an ally rotor head to save your wallet/sanity
Question First Gas Plane? Please help yankee flyer Fuel Plane Talk 23 Aug 02, 2005 11:42 AM
Hello guys my first time here please help a newbie out :) jondaviskorn Beginner Training Area (Aircraft-Electric) 25 Jul 07, 2005 02:29 PM
New Sokol-- First Flight DISASTER Acer High Performance 24 Jan 10, 2003 02:53 PM
