Old Oct 01, 2002, 03:07 PM
ElectriFan is offline
Find More Posts by ElectriFan
Redmond, WA
Joined Apr 2002
Will it charge the batteries with the holder?
Good point, Risto. One should also be aware of the cons and make an informed decision for their needs. To those who are concerned about contact loss (one would really have to heave the radio around for it to happen, IMO), one can solder the connector+wires from the original pack to the new one. Heck, if one wants to get fancy, one can even create a new pack from the NiMHs and wire+connector from the old one.
Thanks eparkflyer.
ElectriFan is offline Find More Posts by ElectriFan
Old Oct 06, 2002, 08:47 AM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
Originally posted by eparkflyer
Risto,
I always keep a drycell AA holder on hand at all times so if the TX
batteries die, I can use it. $1.69 is worth not having to drive
back home from the field!
Why not just make up a charging lead for your TX battery? I made one up and just charge it with my Super Nova or Astro 110. I just pop the battery out, charge it up, then put it back in the TX.
JoeR is offline Find More Posts by JoeR
Old Oct 06, 2002, 12:50 PM
eparkflyer is offline
Find More Posts by eparkflyer
Random acts of Randomness
eparkflyer's Avatar
Joined Oct 2001
I have both...
but when I'm at the field, I want to be charging my plane
batteries and not have to worry about TX batts!
btw, I have been using the 1600's with a cell holder in my Flash
5x almost daily for the past week, and its still at 9.8v...
I would have had to charge my hitec pack about 5 times by now!
eparkflyer is offline Find More Posts by eparkflyer
Old Oct 06, 2002, 01:16 PM
wildbill95823 is offline
Find More Posts by wildbill95823
NON PayPal Member
Sacramento Metro, California, United States
Joined Nov 2001
Thanks,EPARKFLYER
I have seven transmitters I want to up grade
to NIMH cells.
GREAT TIMING & Thanks, Bill
wildbill95823 is offline Find More Posts by wildbill95823
Old Oct 06, 2002, 02:07 PM
CharlesD is offline
Find More Posts by CharlesD
CharlesD's Avatar
United States, IN, Indianapolis
Joined Aug 2001
I still want to know where you found the 1600's for $4.99.
CharlesD is offline Find More Posts by CharlesD
Old Oct 06, 2002, 02:44 PM
Mauilvr is offline
Find More Posts by Mauilvr
Almost a Pilot
Mauilvr's Avatar
NorCal
Joined Oct 2001
BigLots - He stated that in the second post of the thread. You may not be familiar with or have one of these stores near you. Great deals!
http://www.biglots.com/
Mauilvr is offline Find More Posts by Mauilvr
Old Oct 06, 2002, 03:59 PM
eparkflyer's Avatar
Joined Oct 2001
They're not the.. *cough* cleanest stores around... but someone
told me about the 1600's... so thats why I got them
Old Oct 06, 2002, 06:58 PM
daveh is offline
Find More Posts by daveh
daveh's Avatar
Northwest Ohio
Joined Apr 2001
This may be a dumb question, but what the heck,
Can I recharge my new sub $12 batt pack the same way as the stock pack, by plugging in the charger cord to the side of my Flash 5 and plugging into the wall socket???
Dave
daveh is offline Find More Posts by daveh
Old Oct 08, 2002, 11:48 AM
daveh is offline
daveh's Avatar
Northwest Ohio
Joined Apr 2001
Well, is it plug and charge with the stock charger?
Old Oct 08, 2002, 11:53 AM
eparkflyer's Avatar
Joined Oct 2001
You could...
but at 50mA, it will take about 2 days for a full charge, and you don't want to overcharge them.
I use my Super Turbo to charge the packs...
Old Oct 08, 2002, 02:46 PM
Mauilvr is offline
Almost a Pilot
Mauilvr's Avatar
NorCal
Joined Oct 2001
I checked both the BigLot stores near me - neither had the batteries in stock.
Old Oct 09, 2002, 10:52 PM
Kevin Graehl is offline
Find More Posts by Kevin Graehl
Kevin Graehl's Avatar
myspace.com/graehl
Joined Mar 2001
you don't need to worry too much about overcharging these batteries
i have put some of those batts in my cordless phone which doesn't have a trickle charge and after about 5 hours they start heating up-
so what; they still last at least 2 times longer than the orininal 600 mah ones.
i'm sure the lifespan is reduced but something you don't really matter
you shouldn't be concerned about the new batteries blowing up or leaking as a result of using the wall charger and forgeting to unplug it -just don't leave i pluged in for more than two days (50mah x 48 hours =2400mah's gone into the battery
but a little overcharge isn't going to kill you
these little batts were designed to take a little abuse(not too much though)
this is just my opinion though.
i know it sucks to dish out 8.99 for an 8 pack of AA's at the store
Kevin Graehl is offline Find More Posts by Kevin Graehl
Old Oct 09, 2002, 11:02 PM
eparkflyer's Avatar
Joined Oct 2001
2400mAh assumes you have 100% efficiency, which you don't... but I'd say it's ok to leave them plugged in UPTO 48hours..
..and I pay $12 for 16 AA's at home depot (name-brand) and it's still too much when you can get these 4 for $5!
Old Oct 10, 2002, 07:17 AM
MSB is offline
MSB
Find More Posts by MSB
MSB
MSB's Avatar
Brooklyn, NYC
Joined Nov 2001
Online?
Anybody online have good prices on these? I'm bored of the 600 mAh Hitec packs too...
- Mark
MSB is offline Find More Posts by MSB
Old Oct 10, 2002, 07:42 AM
MSB is offline
MSB
MSB
MSB's Avatar
Brooklyn, NYC
Joined Nov 2001
Ebay!
OK. I found some cheap 1600 NiMH's on Ebay. Pack of 16 for 28.95 shipped. Don't know if the batteries are any good (not those fancy "digital" :-) Panasonics), but I can do a few cycles and see how they hold up.
Thanks for the original post, eparkflyer!
How to make an actuator ( step by step ) Paul Penney Scratchbuilt Indoor and Micro Models 209 Apr 20, 2009 04:42 PM
How I Finish My Planes- Step By Step J Morgan Foamies (Kits) 558 Jan 27, 2004 09:56 PM
I have a heat gun and some depron: Need a step by step guide to make an wing mortonj69 Foamies (Kits) 5 Feb 12, 2003 02:21 PM
Site with instructions on how to build battery packs? f2racer Electric Plane Talk 4 Jun 29, 2002 05:12 AM
How to solder - Step by Step Guide Patrick Plawner Beginner Training Area (Aircraft-Electric) 3 Apr 17, 2002 08:52 AM
