Old Sep 29, 2002, 03:33 PM
eparkflyer is offline
Find More Posts by eparkflyer
Random acts of Randomness
eparkflyer's Avatar
Joined Oct 2001
STEP-BY-STEP guide on how to build a $12 TX battery!
This is a STEP-BY-STEP guide to building you're own ~$12.00 1600mAh Transmitter battery for most Hitec (others?) radios.
(yes, it's kind of a joke... but the info is real)!
Step 1. Go buy everything!
eparkflyer is offline Find More Posts by eparkflyer
Old Sep 29, 2002, 03:34 PM
eparkflyer's Avatar
Joined Oct 2001
Biglots: 2x 4-packs of Panasonic 1600mAh NiMH cells $4.99each
(you can use any AA cells here, but this is a great deal)
Old Sep 29, 2002, 03:36 PM
eparkflyer's Avatar
Joined Oct 2001
Radioshack: 8cell AA-sized holder, #270-407A $1.69 (in stores).
(note: most Ratshack stores are changing around, and their
new "parts storage" areas don't have these in it. Ask the
employee, they will probably have them on an end-cap or in the
back)
Old Sep 29, 2002, 03:37 PM
eparkflyer's Avatar
Joined Oct 2001
This is what it looks like out of the package...
Old Sep 29, 2002, 03:38 PM
eparkflyer's Avatar
Joined Oct 2001
Take the cells out, and put them in the holder. (I told you it was
step-by-step! heheh )
Old Sep 29, 2002, 03:40 PM
eparkflyer's Avatar
Joined Oct 2001
as you can see (despite the crappy quality of my digital camera)
they're the same size as the hitec packs with the foam "padding".
eparkflyer's Avatar
Joined Oct 2001
Slide them in your Focus3 radio and use!
Old Sep 29, 2002, 03:41 PM
eparkflyer's Avatar
Joined Oct 2001
...unless you have a Flash4/5, then you just clip them in..
Old Sep 29, 2002, 03:43 PM
eparkflyer's Avatar
Joined Oct 2001
There you have it!
For $11.67+tax you have a TX battery that you can use all day.
Old Sep 29, 2002, 03:51 PM
eparkflyer's Avatar
Joined Oct 2001
oh yeah... one more thing..
This is what you should do to your Hitec TX battery...
(honestly, they need to be recycled)
Old Sep 29, 2002, 08:18 PM
fill is offline
Find More Posts by fill
Houston Texas
Joined Mar 2001
Thanks for the tip, that is a great deal on the Nimh cells. Your right, 600mah nicads and the Flash radio is for the birds. Seems like the money you pay for the radio, they could include the Nimh cells instead?
Philip
fill is offline Find More Posts by fill
Old Sep 29, 2002, 09:09 PM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
This ought to work in quite a few JR radios as well.
My JR Max 44 came with a battery exactly like that, except with shrink wrap over it.
Trizza is offline Find More Posts by Trizza
Old Sep 29, 2002, 09:34 PM
lotsofgadgets is offline
Find More Posts by lotsofgadgets
lotsofgadgets's Avatar
Shakopee, MN
Joined Sep 2001
Where are you getting the batterys at $4.99?
Dennis
lotsofgadgets is offline Find More Posts by lotsofgadgets
Old Sep 30, 2002, 01:40 AM
risto is offline
Find More Posts by risto
Electrics rule
risto's Avatar
Bielefeld, Germany
Joined Jun 2000
There is one catch though: the battery pack is always soldered, or at least welded. Self-made unit with the battery holder uses springs - can sometimes cause bad contact.
With normal no-fancy radio bad contact causes just to lose Tx power for a moment, for computer controlled radios it can be more dramatic, where you have to press some buttons after power-up (to confirm the PLL-frequency, or model or what-ever) before it powers up. Not talking abount a voltage loss in spring contact. Although it seems like a cheap alternative, it really is not very reliable alternative unfortunately.
Risto
risto is offline Find More Posts by risto
Old Sep 30, 2002, 05:53 AM
eparkflyer's Avatar
Joined Oct 2001
Risto,
Sure... It's not "as good" as making up a pack, but its quick, easy, and cheap.
I know a few people who have been using dry cell holders in their
Focus3's for years and none of them have had any problems.
I always keep a drycell AA holder on hand at all times so if the TX
batteries die, I can use it. $1.69 is worth not having to drive
back home from the field!
How to make an actuator ( step by step ) Paul Penney Scratchbuilt Indoor and Micro Models 209 Apr 20, 2009 03:42 PM
How I Finish My Planes- Step By Step J Morgan Foamies (Kits) 558 Jan 27, 2004 08:56 PM
I have a heat gun and some depron: Need a step by step guide to make an wing mortonj69 Foamies (Kits) 5 Feb 12, 2003 01:21 PM
Site with instructions on how to build battery packs? f2racer Electric Plane Talk 4 Jun 29, 2002 04:12 AM
How to solder - Step by Step Guide Patrick Plawner Beginner Training Area (Aircraft-Electric) 3 Apr 17, 2002 07:52 AM
