Old Feb 08, 2007, 05:36 PM
tommyt is offline
Find More Posts by tommyt
Born to be free
tommyt's Avatar
undefined
Joined Sep 2004
Need easy g/m^2 to oz/yd^2 conversion
I am looking for a easy program or online conversion for g/m^2 to oz/yd^2 and vice versa.
Maybe even a chart that gives me the common weights of composite fabrics in metric and US weights.
Thanks in advance,
TommyT
tommyt is offline Find More Posts by tommyt
Old Feb 08, 2007, 05:49 PM
reinking is offline
Find More Posts by reinking
Joined Jun 2005
From: http://www.onlineconversion.com/foru...1110473881.htm
Re: ounces/linear yd -> grams/linear meter
by Robert Fogt on 03/10/05 at 16:04:10
To calculate the conversion factor, you start with the basic units.
For this:
ounces/yard to grams/meter
You would use this formula:
(ounces to grams)/(yard to meter)
You need to know this:
ounces to grams
yards to meters
1 ounce = 28.349523125 gram
1 yard = 0.9144 meter
Now calculate:
ounce/yard * (28.349523125/0.9144) = gram/meter
Your conversion factor is 31.0034154910324, which we can just round to 31.
23.75 oz/yd * 31 = 736.25 g/m
reinking is offline Find More Posts by reinking
Old Feb 08, 2007, 11:12 PM
flybike is offline
Find More Posts by flybike
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
mm not exactly.
Just use google.com! Type in oz/yd^2 to g/m^2 or vice versa g/m^2 to oz/yd^2 and hit enter. It does it for you.
1 oz / (yd^2) = 33.9057475 g / (m^2)
1 g / (m^2) = 0.0294935247 oz / (yd^2)
Hans
flybike is offline Find More Posts by flybike
Old Feb 09, 2007, 02:13 AM
rjimenez is offline
Find More Posts by rjimenez
Granada, Spain
Joined Jun 2004
Hi Reinking
The conversion factor given by flybike (33.9) is right. The difference with the value you gave is that 31 is useful to convert oz/yd into g/m, but not oz/sqyd into g/sqm.
Rafael
rjimenez is offline Find More Posts by rjimenez
Old Feb 09, 2007, 12:35 PM
reinking is offline
Joined Jun 2005
Use the logic presented to compute oz/sqyd into g/sqm or simply take the reciprocal of the value shown in the example I posted.
Last edited by reinking; Feb 09, 2007 at 01:25 PM. Reason: Answered the wrong question :-)
Old Mar 25, 2016, 10:42 AM
CTucker is offline
Find More Posts by CTucker
Joined Mar 2016
1 oz / yd^2 = 28.349523125 gram / (0,.9144 meter x 0.9144 meter) = 33.905747 g / m^2
CTucker is offline Find More Posts by CTucker
Old Mar 29, 2016, 10:11 AM
R&G is offline
R&G
Find More Posts by R&G
R&G
Composite Technology
Stuttgart
Joined Oct 2005
We´ve found this tool quite useful: http://www.compositesconsultants.com/cats/tools.php
R&G is offline Find More Posts by R&G
Old Mar 29, 2016, 05:18 PM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
simple answer is to multiply or divide by 34 depending on which way you are doing the conversion.
and for more involved conversions this is the tool that everyone should have: http://joshmadison.com/convert-for-windows/ no installation needed, just stick it somewhere easily accessible like the quick launch bar. as downloaded it won't do weight per area conversions but you can add custom tabs to it for anything you want.
ZAGNUT is offline Find More Posts by ZAGNUT
Old Apr 28, 2016, 01:01 PM
tegist is offline
Find More Posts by tegist
Joined Jan 2016
For those interested in the theory of units conversion from a retired physicist: (this would be a lot easier with real equations. If enough are interested, I could generate this in a pdf with those equations.)
No matter what we're converting, it all amounts to multiplying by the correct value of 1. The trick is to know what that is, and which way you go: divide or multiply.
Assuming you understand English and metric units, you can get get to anything by starting with some relationships that define the relationships between the two:
1 lb = 454 grams
(The physicist in me cringes: Pounds measure force, and grams measure mass. So, we'll all agree that we're talking about the force of gravity on 454 grams being one pound. I'll now step of the soapbox.)
1 in = 2.54 centimeters
The other thing to remember is DON'T FORGET THE UNTIS! Without them you can get lost.
So, let's convert oz/(yd*yd) to g/(m*m). As an example, I'll convert 1oz/yd^2 to gm/m^2
Since a pound is 16 ounces, we have 16 oz = 454 gms, or
1 = 454gms/16oz
So, 1oz/yd^2 = 1oz/yd^2*(454gm/16oz)
= 1oz/yd^2*28.375gm/oz
Now we note that:
1 yd = 36 inches, or
1 = 36in/yd
Adding that into the mix we get
2 oz/yd^2 = (1oz/yd^2*28.375gm/oz)/(36in/yd*36in/yd)
= 1oz/yd^2*0.02189429gm-yd^2/in^2
Finally, we need to convert square inches into square meters. Look at the definitions above, we see that
100in = 254cm = 2.54m (from 100cm = 1m)
or 1 = 100in/2.54m
So, 1oz/yd^2 = 1oz/yd^2*0.02189429gm-yd^2/in^2*(100in/2.54m*100/2.54m)
= 1oz/yd^2*33.936218gm-yd^2-m^2/in^20m^2
If we cancel out all the units, we get
1 oz/yd^2 - 33.93621gm/m^2 (Gee, that looks familiar)
Finally, we get our conversion factor:
1 = 33.93621(gm-m^2)/(oz/yd^2)
And now we see why units are important: If I want to convert oz/yd^2 to gm/m^2, I want the oz and yds to go away. If I multiply by my factor of
the oz/yd^2 units cancel and I get the answer in gm/m^2. If I want to convert gm/m2 20 oz/yd^2, I divide and get the answer it oz/yd^2
Morale of the story: The statement "The conversion factor is 33.93621" doesn't have much meaning. What we want to say is "The conversion factor is 33.93621(gm-m^2)/(oz/yd^2)." That works.
tegist is offline Find More Posts by tegist
Old Apr 28, 2016, 05:05 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by ZAGNUT View Post
.................http://joshmadison.com/convert-for-windows/ ..............................
Wow! That is a good one Zagnut.
It even runs in my Linux Mint 17.2
Very convenient and quick.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Apr 28, 2016, 08:41 PM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
Yep, I use it often and I love the custom tab to stuff like cloth conversions, wingloadings etc.
flyonline is offline Find More Posts by flyonline
3.2 oz micro ME109 frankenfoamy Scratchbuilt Indoor and Micro Models 9 Oct 15, 2005 08:49 PM
Kevlar Cloth 2.1 Oz /YD For Sale glider34 Aircraft - Sailplanes (FS/W) 11 May 20, 2005 05:15 PM
My new And-Now is HEAVY 8.2 oz :-( Mike Hall Parkflyers 2 Sep 22, 2002 06:14 PM
Need Help W/ These 2 Planes! darenm Parkflyers 10 Apr 23, 2002 11:17 AM
Looking for motor/gearbox with 1.5 to 2 oz of thrust fritts Parkflyers 5 Nov 13, 2001 01:10 PM
