Old Feb 07, 2007, 09:48 PM
Auric is offline
Find More Posts by Auric
Joined Jan 2007
I need some help with a BEC/ESC LiPo Setup for my easyglider
I have purchased an easyglider and plan on using the stock 400 brushed motor. I will have 6 servos in the plane:
2 x Hitec HS-81 Micro Servo U
2 x Hitec HS-55 Economy Sub Micro Servo
1 x HS56 with Karbonite gears
1 x HS85 with Metal gears
I will also be using the Futaba R319DPS Synthesized 72mHz PCM Receiver.
I want to run everything off of one 2S, possibly 3S, LiPo (Lithium Poly) battery.
Here are my questions taking into consideration I know next to nothing of how to implement a BEC/ESC.
1) If I use the stock 400 brushed motor, how should I setup the ESC/BEC? Setup specifications and actual product names would be a big help.
2) What if I was to go with a 400 brushless 4D, 6D, 8D motor, what setup should I use?
3) Which exact LiPo battery would you recommend? How many volts, mAh, and a 2S or 3S?
Thank you very much for helping me with this, I have been scouring these message boards and have been entirely unable to find out how to do this.
Auric is offline Find More Posts by Auric
Discussion Need some help with Hitec ESC rtn9105 Hitec/Multiplex USA 2 Aug 20, 2007 05:15 AM
need some help with upgrading my SS. PCola-Flyer Parkflyers 18 Sep 27, 2003 05:49 PM
Need some help with my GS400 ESC VWtechie Power Systems 0 Feb 18, 2002 12:51 PM
Need some help with my Starlite. Lucas in Alaska Parkflyers 10 Jan 30, 2002 10:45 AM
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
