Vila Real, Portugal
Joined Nov 2004
The building process is going slowly.
With a L shape plastic profile (10mmX10mm) I made a spray rail. It might be bigger than it should since: For the 123cm (48) version we have a spray rail that goes down 6,35mm (0,25 - 1/4) so for the 61,5cm (24), well more correctly 66cm (26) - my plans have grown in the printer... - version it should go down 3,43mm (0,135 ). In my case I have 4mm (0,157) instead of 3,43 (0,135) - A in the image and 10mm (0,393) for B in the image. I hope that doesn't alter the boat riding. The whole thing was fixed by epoxy glue and then covered with fiberglass. This approach make my spray rails very resistant to impact and protect the upper side of the boat, which was built very light and more fragile with 1,5mm (0,381) balsa cover. I didn't make stracks because I have read that this model doesn't need them. I also made a cockpit to close the boat. The windscreen must be cleaned...and the rear part finished, I know. You can see the boat with all the electronics already installed. I was thinking that the boat was very heavy and want float!!! (I'm a man from the airplanes remember?!). Well at this stage I made an experience putting it in the water and it floats!!! There isn't much more height to put in, almost just the painting job. Is the water line correct? I also try the boat with the motor almost stopped and I could made 2 meter turn (6,5 foot turn) very easy. I'm considering a system of water refrigeration of the motor and speed controller, does anyone have suggestions for me?
| Thread Tools | |
| Build Log Building the......WILD THING | rc-eflyer | 3D Flying | 150 | Mar 09, 2009 07:23 PM |
| Video Wild Thing | RickC2009 | Electric Plane Talk | 1 | Jul 07, 2006 07:05 PM |
| Sold Wild Thing biplane (Horsefly Hobbies) - KIT (NEW) | bkahuna | Aircraft - Electric - Airplanes (FS/W) | 4 | Jun 09, 2006 10:25 AM |
| .35 on The Wild thing | rcmatt455 | Racing Boats - Internal Combustion | 2 | Sep 08, 2004 12:10 PM |
