Old Feb 05, 2007, 11:05 PM
blehh is offline
Find More Posts by blehh
Joined Feb 2007
Help!
Is this an okay car??Need help..new to r/c
So i'm new to the forums and to gas r/c..i just bought http://cgi.ebay.com/ws/eBayISAPI.dll...1469&rd=1&rd=1
and i need to know if it's an okay buggy and if i need to do anything special before running it..what i need to run it...and any beginner tips...
Thank you all
blehh is offline Find More Posts by blehh
Old Feb 05, 2007, 11:44 PM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
just break it in properly .... find and buy plenty of spare parts as they arent easy to get
they arent bad alot of folks like them you should have fun with it .. follow the instructions break it in right and keep an eye on the temps
turbored21 is offline Find More Posts by turbored21
Old Feb 06, 2007, 11:43 AM
blehh is offline
Joined Feb 2007
Okay thank you
well what if it doesn't have instructions??how do you break it in??
and how do you watch the temp?
is there any videos that teach you how to use them?
Old Feb 06, 2007, 04:02 PM
Joined Oct 2006
hmm well heat cycle method is usually preferred go on tower hobbies and order a temp gun
First tank start the engine run it gently around till it reaches operating temperature "roughly 200 degrees F" run it for another min or so then shut it off let it cool completely
Second tank repeat above process
Third tank repeat above process
Fourth tank lean the high speed needle 1/8th of a turn "turn it in" and repeat above process
Fifth repeat
Sixth repeat
Seventh lean it again 1/8th and repeat
Eighth lean it 1/8th "should be tuned about right by now" and now your engine should be heat cycled completely and broken in
All the while using your temp gun to kep an eye on the temps dont let it get over 225 degree's or so dont go full throttle till the last 2 tanks and even then only for short periods of time 4-8 seconds if when you lean it the last 2 times the temps want to start to rise above 220-240 then you need to richen it back up just a bit turn the needle out 1/16th - 1/8th of a turn 220-240 is normal running temp for most nitro engines
anything above 250 usually means damage and shortened engine life is eminent
as for temps you can also use the water drop or "spit" test take a drop of water or spit and drop it on TOP of the cooling head if it takes longer than 5 seconds to boil off your fine if its boils away in 5 seconds or less shut the engine down and richen it up a bit
now for the low end which youll tune only when your happy with the high speed needle
to set the low once the high is set where you like it pinch the fuel line the engine should stall out it about 5 seconds if it takes longer its a bit rich turn it in...... if it revs way up and stalls really fast its a bit lean turn it out
there are videos for this on yahoo/google video just search nitro breakin /tuning youll find them
Old Feb 06, 2007, 05:03 PM
blehh is offline
Joined Feb 2007
Okay thank you so much
i think i found a video on youtube that's good..it's for traxxas so i don't know..but i will look some more.
thank you again.
Discussion Need Help With R/C Abbreviations!!! b17lover Electric Plane Talk 21 Aug 12, 2007 04:48 PM
Discussion Help! - New to R/C need motor help. tobymerriman Electric Ducted Fan Jet Talk 6 Apr 19, 2006 06:17 AM
HELP!!! New R/C Club aggie903 Beginner Training Area (Aircraft-Electric) 8 Jan 20, 2003 09:15 PM
