Joined Dec 2006
Once that pinion gear has spun loose you might as well throw it away and apply a new one. Parkzone sells the pinions in a bag of 2 for $1.99---and it doesn't take a hard crash to spin one. You can roughen the motor shaft like said above, stick it in a vise and apply 800# of pressure to deform the shaft into an oval shape, use red,blue and or green loctite, epoxy, CA.......doesn't matter, the new pinion is still going to spin loose in no time. I average maybe 4 flights per pinion, and the pinions will spin in flight. You'll realize it when the plane quits moving forward but you can hear the engine! And that is why my PZ P-51 and FW 190 are in a pile on the floor collecting dust at the moment. You might want to go ahead and order one or two of the replacement "internal structures" @ $2 each because the battery tray area is going to start coming apart. When the front of the tray finally gives way (and CA doesn't seem to bond the plastic) while you are flying you'll realize that also, as the battery will slide forward into the gearbox and rest assured your FW 190 WILL make a 90 turn towards the ground and go straight in!
Somebody somewhere has found a metal gear, but you'll have to search a lot of forums to find it mentioned! Good Luck with your PZ plane. |
its a brasspinion, once it breaks free, it's usualy streached to far to ever fit again. new pinions, as mentioned above are cheap, but putting them on can be tricky without streaching the new ones. easiest to buy a new $11 motor and gear and forget the hastle.
If you have an RC car shop near by, you might try them, and see if they have a pinion that attaches with a set screw. |
Maybe its time to graduate
Hum... Rube about described my experience with the ParkZone Flyers to a "T". All that stuff got old as my skill level increased
Brings back old memories.......as I got to be a better pilot I hopped it all up to Lipo and I was flying wide open all the time. Basically .......I had outgrown the limited PZ parkies. All the battery tray issues ect caused me to ignore this stuff and I new it was time to move on to direct drive outrunners, balsa , bigger planes , better planes ect. What I found was in the end of fixng and fiddling with small planes of cheap materials I could buy bigger planes and better planes and have less worries. Sort of the evolution of a Parkflyer I guess. |
The Parkzone planes are not limited at all if you modify them to have rudder and put brushless motors and lipos in them. |
i have a Mega 16/15/4 that I could put in a gear box but I need to know a little more. |
If you wish to use the stock gearbox look for 28mm inrunner motors in the 2000kv range. My Wulf has the EFlite Six Series 2000kv motor and flies very nicely. Some say try the Typhoon motor but that did not work out well as the kv rating is too high for a 3-to-1 gearbox. You will need to remove the ridge in the gearbox to enable the brushless motor to install properly. Short work with a Dremel tool.
Gary |
Pitt Meadows. B.C. Canada
Joined Oct 2006
pinions
to all of you that have spun the plastic pinion gear in the PZ 190, I bought a replacement motor at my LHS that was for the PZ Cub, it's the same motor, comes with a metal pinion. Simply install in the 190 and off you go.
Cheers, Dave. |
| Thread Tools | |
| Can I extend the prop shaft on my GWS LPs motor? | Larry Richardson | Scale Electric Planes | 5 | Oct 04, 2004 09:38 PM |
| Kickback on Hacker B20 keeps knocking off prop, help. | sizam | Power Systems | 7 | Jan 28, 2003 03:19 PM |
| Prop shaft on 'moth | BotleRocketWar | Parkflyers | 1 | Jul 30, 2002 05:43 AM |
| How do I remove the brass pinion from the motor shaft on my SS? | RollTide69 | Foamies (Kits) | 3 | Dec 31, 2001 02:43 PM |
| Can i cut off the manual reset on my ESC? | emaij | Power Systems | 2 | May 02, 2001 08:17 PM |
