Old Jan 31, 2007, 10:46 PM
jhamm is online now
Find More Posts by jhamm
USA, NY, Rochester
Joined Jan 2003
Magnum XL .52 FS on a 96oz warbird?
I am just finishing up a Model Tech P-51 and am putting a Magnum XL .52 FS on it.
Will this .52 motor power this plane. Weighs about 96oz.
jhamm is online now Find More Posts by jhamm
Old Jan 31, 2007, 11:19 PM
706jim is offline
Find More Posts by 706jim
Canada, ON, Thunder Bay
Yes it will, but don't expect vertical performance at 96oz all up weight. It will probably fly pretty much scale. Real Mustangs couldn't fly straight up either.
706jim is offline Find More Posts by 706jim
Old Feb 01, 2007, 07:20 AM
Robert Bauer is offline
Find More Posts by Robert Bauer
Dushore Pa. & Arcadia Fl.
Joined Jun 2002
If you are on a grass field I doubt if you will get it off the runway. I had mine on a 17% Giles that was much lighter and the performance was poor. I would go with a 70.
Robert Bauer is offline Find More Posts by Robert Bauer
Old Feb 01, 2007, 10:27 PM
Red Raider is offline
Find More Posts by Red Raider
USA, IL, Benton
Joined Jan 2005
I've been flying a World/Airborne Mustang for several years and I believe it is about the same size as your modeltech. I first flew it with a Saito 72 and it flew just fine- like a sport plane. I now fly it with a 91 Saito and it is really a blast. No lead needed to balance, just moved the battery back a little. I don't believe you would be satisified with a 52 four stroke.
Fred
Red Raider is offline Find More Posts by Red Raider
Old Feb 02, 2007, 05:50 AM
jhamm is online now
USA, NY, Rochester
Joined Jan 2003
Thanks Fred,
Problem I have is there is only 3 1/8" from the firewall to the spinner face??
The bigger motors seem to be longer than 3 1/8"
Old Feb 02, 2007, 10:05 AM
blizzardwarrior7 is offline
Find More Posts by blizzardwarrior7
In Massive Debt
Northampton Massachussetts
Joined Jun 2005
You have started multiple threads about this same topic. Check your other threads for responses also.
blizzardwarrior7 is offline Find More Posts by blizzardwarrior7
Old Feb 02, 2007, 01:46 PM
Joined Jun 2002
I have usually found that there is more than one way to skin a cat, and more than one way to mount an engine. Seek and ye shall find.
Old Feb 02, 2007, 10:17 PM
chashint is offline
Find More Posts by chashint
Dallas, Texas area
Joined Sep 2003
I posted this in another thread but it applies equally here.
On my Magnum 61 four stroke using 15% fuel and a MA 12x6 Smicitar I get 10000 sustained RPM and using a fish scale measure 5lb 5oz (85oz) static thrust.
The 61 is about 18% bigger than a 52, not sure that everything scales 1:1 but assume that it does and you are looking at 4lb 8oz (72oz) static thrust.
I would not be happy with the 61 four stroke on this plane.
chashint is offline Find More Posts by chashint
Discussion OS 52 FS on Ebay Thomas Cummings Engines 3 May 03, 2006 07:29 AM
Sold magnum xl 61 fs rcguru Aircraft - Fuel - Airplanes (FS/W) 1 Aug 12, 2005 09:56 PM
For Sale magnum XL 15 FS tsuitt Aircraft - Fuel - Airplanes (FS/W) 1 May 29, 2005 02:34 PM
Ebay - Magnum XL-52 4-stroke only a few minutes left! neilo Aircraft - Fuel - Airplanes (FS/W) 0 Feb 19, 2004 09:45 PM
Magnum XL .52 4 stroke emartin Engines 2 Jan 23, 2003 10:32 PM
