Old Jan 29, 2007, 09:26 AM
jbachman is offline
Find More Posts by jbachman
Joined Nov 2004
Need help with Eclipse 7 programming - Acro/Glid and Thottle/Ailerons
I'd like to use GLIDER setting for an electric powered 2M electric sailplane BUT don't like the way the throttle is only ON or OFF in the GLIDER MODE.
So I'm thinking about ACRO mode and having challenges figuring out how to get aileron's setup with differential.
Suggestions?
I'm posting this in both the Hitec Vendor area and sailplane forums.
jon
jbachman is offline Find More Posts by jbachman
Old Jan 29, 2007, 11:26 AM
sekollera is offline
Find More Posts by sekollera
Minneapolis, MN
Joined Sep 2004
You should be able to easily get differntial from ACRO mode. Read the manual, page 26
The Flaperon mixing function uses two servos to
individually control two ailerons, combining the aileron
function with the flap function. Both ailerons can be
raised and lowered simultaneously for a flap effect. Of
course, aileron function, where the two controls move in
different directions, is also performed. The down travel of
the left and right ailerons can be adjusted, so you can
also get a differential effect. (Left and right flap travel are
adjusted individually in the EPA menu.)
To take advantage of the flaperon mixing function, you'll
need to connect the right aileron servo to CH1 (AIL) and
the left aileron servo to CH6 (FLP).
This is required reading for Eclipse 7 owners and full-house sailplanes (see the Post #8 and the users guide attachment from Target):
http://www.rcgroups.com/forums/showthread.php?t=489377
sekollera is offline Find More Posts by sekollera
Old Jan 29, 2007, 12:33 PM
jbachman is offline
Joined Nov 2004
Thank you ...
This is precisely what I was hoping for ...
Discussion Need help on Eclipse 7 GLIDER / ACRO Programming jbachman Hitec/Multiplex USA 2 Jan 29, 2007 09:45 PM
Discussion Need help with Berg 7 in a carbon fuse... Quacker Castle Creations 21 Jan 03, 2007 01:50 PM
Discussion Need Help With Hyper 7 CRASH GORDON Off-road Cars 0 Apr 14, 2006 12:36 PM
Help! Help! Hitec Eclipse 7 programming... SpiritQuest Thermal 12 Jul 09, 2003 12:42 AM
Subject: Need help with CCPM and Hitec Eclipse 7 Radio. tom88 Electric Heli Talk 2 Aug 21, 2002 12:30 AM
