Old Jan 28, 2007, 04:55 PM
PeteW is offline
Find More Posts by PeteW
Joined Jan 2007
PicoZ - Any tips for new owner
Just got my PicoZ. Looking for advice as to whether it is acting normally. It goes up and down ok but it seems to have a mind of it's own apart from that. The main problem is that it doesn't really move forward. It seems to just move almost randomly. The trim and the right stick appear to have no/little effect. When the PicoZ is not flying, should moving the trim or the right stick actually move the rotor blades? At the moment they don't.
Just wondering if it is broken.
Any tips appreciated.
Pete
PeteW is offline Find More Posts by PeteW
Old Jan 28, 2007, 06:43 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
First off, you have a heli known as the "PICOZ" and not the "PICOOZ" which what you have is a copy at best.
Nevertheless, the original article of this wonder micro heli by SILVERLIT known as the "PICOOZ" came with little stick-on weights so, you can make the heli tilt it's orientation forward and the thrust vectoring will make the heli float forward. Now you need to turn it by either with the tail boom rotor motor by moving the right stick either Left or Right "or" you can just keep the right stick TRIM at one point and using throttle you can actually turn the heli as when you throttle down the torque on the main rotor reduces matching up with the tail boom rotor motor's thrust.
Good luck!
carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Jan 28, 2007, 07:22 PM
Micro Sizer is offline
Find More Posts by Micro Sizer
Micro Sizer's Avatar
MN, Bloomington
Joined Jan 2007
Take a peice of packeging tape and fold it 3/4ths of the way down with around 2-3 inches of it and with the extra tape on bottom tape it in front all around...Bang foraward motion.
Micro Sizer is offline Find More Posts by Micro Sizer
Any Tips for a new flyer? haddorh Micro Helis 6 Jan 23, 2005 02:11 AM
Hello... any tips for a newbie pilot and a slow stick owner? snowball1288 Parkflyers 9 Dec 06, 2004 08:32 AM
any suggestions for a new zagi motor? Barrett Foamies (Kits) 4 Sep 10, 2001 06:06 PM
Any Tips for a Micro Fan Nacelle? James Frolik Electric Ducted Fan Jet Talk 1 May 31, 2001 01:18 AM
New Zagi 400x builder, any tips for me? slowflyer Foamies (Kits) 16 May 09, 2001 04:28 PM
