Old Sep 25, 2002, 06:44 PM
JStory is offline
Find More Posts by JStory
United States, TX, Dallas
Joined Jun 2001
What gear ratio for a GWS Hybrid motor running on the Rare Bear Prop.
I just got a rear bear and want to run a EDF motor in my DX-A gearbox, will this work with the stock prop? If not what is the best gearing. I also want to use QC's and 7 cell nicad packs.
JStory is offline Find More Posts by JStory
Old Sep 25, 2002, 07:45 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I have no idea what the Rare Bear's stock prop or gear ratio is....... but I have run one of these "hybrid" IPS drives.
I went from an S2 (3.5:1) with the IPS motor to an A (5.9:1) for the EDF motor while keeping the same propeller (APC 7X4SF). Since the Kv of the EDF motor is almost twice that of the regular IPS motor, that makes some sense.
BEC is offline Find More Posts by BEC
Old Sep 25, 2002, 08:13 PM
E6 is offline
E6
Find More Posts by E6
E6
Alhambra,CA
Joined Feb 2000
I've seen it ran on my DXA, EDF, with a 7x6 and qualcomms. Locomoto thought this ran much better than his stock setup. I wouldn't recommend a larger prop with the A drive than the 7x6.
I've ran the above setup in other planes and get better results. I think the Rare Bear cowl is to big for this size prop.
I would go with a DXC, EDF and either a 8x6 or 9x6. That what I would think would work good for you.
Al
E6 is offline Find More Posts by E6
Old Sep 25, 2002, 09:12 PM
DesignGeek is offline
Find More Posts by DesignGeek
DESIGNOSAUR
DesignGeek's Avatar
United States, MI, Wixom
Joined Jun 2002
My bear is almost ready to fly--- I also though about doing the hybrid thing to it. I will be anxcious to hear how yours goes.
I was also considering running the stock prop with a dual drive, using the #1 gearbox 4-1 ratio or near that... I was thinking it might be able to spin it a bit faster. Have you seen any data for that prop? for comparison,I looked at the GWS three blade prop it's only shown with the 300 motor on thier prop tables though...
Rob
DesignGeek is offline Find More Posts by DesignGeek
Old Sep 25, 2002, 09:22 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
I'm flying a Mini IFOish with an EDF-50 motor in a DX-E gearbox with a 10x4.7 prop, which is the prop recommended for the DX-A. The performance is tremendous because the lower gearing (higher numerically) of the E drive allows the high Kv EDF-50 motor to spin freely to its most efficient speed. If the gearing and prop do not allow the EDF-50 to spin at a high speed, but rather load it up and cause it to strain, it will not live very long.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Sep 25, 2002, 09:46 PM
pohlmeyr is offline
Find More Posts by pohlmeyr
pohlmeyr's Avatar
United States, TX, Denton
Joined Sep 2001
I have obtained 7 oz of thrust using the EDF motor and the "D" Gear BOx using an 10x8 prop and the 300mah nimh 7 cell pack. It pulled 3.8amps right at first then dropped down to around 3 amps. Was getting around 7min flights on a tiny. I am still running this setup and have not burned up the motor yet, but then again i don't need it at full throttle all the time
www.kpohlmeyer.com
-keith
pohlmeyr is offline Find More Posts by pohlmeyr
Old Sep 25, 2002, 10:03 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
are you guys buying ips dx-e's and swapping pinions with a bare edf motor? or buying 4.8v dual ips (edf motors I think?) and taking one motor out? might be a better way to go, then slam the unused edf with pinion in a dx-e frame or save it as a spare...
opualuan is offline Find More Posts by opualuan
Old Sep 26, 2002, 02:24 PM
Joined Feb 2000
Or, you could simply buy replacement motors for the LPS-RLC-B or C, which are EDF-50 motors with 10-tooth gears, same as the IPS-DX-EXC motor gear. That's what I plan to do next time around.
Old Sep 26, 2002, 03:50 PM
BEC is offline
BEC
BEC
BEC's Avatar
Joined Jan 2001
Yeah, now that Balsa Products has the LPS-RLC motors as spares you can do a couple of combinations "from scratch". I'm planning to do an IPS-E ratio drive this way to try on the Gym-E and/or TM.
Just be careful with numbers of teeth and tooth pitch (the RLC-C gear pitch doesn't match any IPS spurs). The LPS "B" motor/pinion can serve as the basis for a hybrid "E" drive and the LPS "A" motor/pinion can serve as the basis for a hybrid "B" drive. To get a hybrid "A" you need to either move a 14T pinion from an existing "A" motor or get a 4.8V IPS-D drive and get two motors with the correct pinion installed already. That's how I built my current hybrid "A" drive for the Wing-E.
Watch out here, too: the S1 IPS-D drive pinion has the right number of teeth but different tooth pitch.....
Isn't mixing and matching parts like this fun?
Old Sep 26, 2002, 04:35 PM
Joined Feb 2000
So you're saying that while the RLC-B and RLC-C motor pinions each have 10 teeth, that the C pinions don't fit the IPS-E spur but the B pinions do? In other words, the pinion and spur gears are matched only for each other, and that a 10-tooth pinion from one is not identical to a 10-tooth pinion from another? That's good to know before buying the wrong ones!
Old Sep 26, 2002, 05:10 PM
BEC is offline
BEC
BEC
BEC's Avatar
Joined Jan 2001
Yes, that's EXACTLY what I'm saying. Based on the info on the Balsa Products site - specifically this page :http://www.balsapr.com/catalog/parkFlyers/LPS.asp - the "B" pinon has 0.3mm pitch and the "C" pinion has 0.25mm pitch.
This is in addition to the EPS and IPS S1 and S2 which have 0.4mm pitch gears. One must be very careful in mixing/matching to avoid frustration.....
Old Sep 26, 2002, 06:06 PM
JStory is offline
Joined Jun 2001
The rear bear prop is a 3-blade 8x6 or maybe its a 9x6 anyways will a "E" gearbox and a EDF motor run fine on it?
Old Sep 26, 2002, 06:14 PM
fourleaf is offline
Find More Posts by fourleaf
Senior Member
Des Moines Municipal, Iowa, United States
Joined May 2002
RB prop is 3 blade 9x7, if I understand correctly. I might have the pitch wrong, but it is a 9 inch diameter.
fourleaf is offline Find More Posts by fourleaf
Old Sep 26, 2002, 09:14 PM
Joined Feb 2000
Thanks, BEC. I had not dug deep enough to see the schematic page with all of the details including pitch of the gear teeth. I've always liked the products and service that I've gotten from Balsa Products, and now there's an even better reason to business with them. I really appreciate retailers who work hard to inform the customer of the minutest details about their products.
By the way, has anyone had any experience with the RLC gearboxes? If so, do you like them better than the original IPS gearboxes? Any comments would be welcome.
Old Oct 01, 2002, 08:47 PM
DESIGNOSAUR
DesignGeek's Avatar
Joined Jun 2002
Flew the bear in stock set-up last night- I am impressed with it already. I wouldn't mind if it would have a bit more grunt- I would like to get larger diameter loops with it.
Should I be looking for a combo that yeilds more prop diameter, or greater pitch X rpm?
What gear ratio for the Feigao 12mm 5866 RPM/V motor? rcmann Power Systems 11 May 07, 2005 05:08 PM
What gear ratio for Feigao 1308415s for use on a FFF 3DX? TeamTEOR Power Systems 1 Oct 09, 2004 09:43 PM
What gear ratio GWS 400 for my Mustang? splatman Parkflyers 6 Feb 11, 2003 02:43 PM
FS: Planetary Gearbox with 5:1 Gear Ratio for GWS IPS and N20 Motors GoEFlight Aircraft - Electric - Airplanes (FS/W) 4 Jun 12, 2002 09:12 PM
Good gear ratio for N20 motor silencer Parkflyers 5 Jul 18, 2001 11:39 AM
