Espritmodel.com Heli Air
Old Jan 27, 2007, 03:27 AM
Cincinnati Cin N.Knty, Ohio, United States
Joined Sep 2004
Removing covering color from iron
Whats the best way to remove the color residue off a covering iron? Mine has a tint of red on it from the red I was applying on my plane earlier. Before I noticed it was on there I got some of it on my white covering I applied, is it possible to remove it from my white covering or is it there forever?
Chris
chris8105 is offline Find More Posts by chris8105
Old Jan 27, 2007, 04:36 AM
Downwind 1's Avatar
massachusetts
Joined Aug 2003
Alcohol
Downwind 1 is offline Find More Posts by Downwind 1
Old Jan 27, 2007, 04:46 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If married, girl friend, mum, nail polish remover.
eflightray is offline Find More Posts by eflightray
Old Jan 27, 2007, 06:40 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
Wipe with a cotton cloth while the iron is hot.
abenn is offline Find More Posts by abenn
Old Jan 27, 2007, 07:28 AM
ODB V September 2013
1987tc's Avatar
United States, OK, Weleetka
Joined Dec 2000
I use dryer sheets while the iron is hot. Cleans the iron right up!
1987tc is offline Find More Posts by 1987tc
Old Jan 27, 2007, 07:32 AM
Long-Time Member
James Frolik's Avatar
Cologne, Germany
Joined Dec 1996
I use Acetone on my iron. (Acetone is a cleaning solution.) It might work on the white covering too, but try it first on a piece of scrap white covering to see if it dulls the color any. I recently used some on silver color Ecospan to clean off the excess Ecofix residue (Ecofix must be applied to the surface to which Ecospan will be ironed on to) and the silver color did not dull or thin.
I have also used Acetone on foam and plastic. Since it is not a thinner, it doesn't, or shouldn't, melt these materials.
James Frolik is offline Find More Posts by James Frolik
Old Jan 27, 2007, 08:09 AM
die fliedermaus's Avatar
Kansas
Joined Jul 2002
Get the scratchy out of the kitchen sink and scrub it off.
die fliedermaus is offline Find More Posts by die fliedermaus
Old Jan 27, 2007, 08:35 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Aerogloss thinner. Wipe it on, wipe it off. Aerogloss won't attack the material on the iron, but it sure eats up covering goo.
You don't want anything abrasive because you're going to be sliding that thing over the covering and any rough spots will scratch the finish.
Doc Austin is online now Find More Posts by Doc Austin
Latest blog entry: Extreme Aviation Has A New Home
Old Jan 27, 2007, 09:14 AM
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
I use those iron socks and usually get a plane or two out of each one. These can be reversed after they get too dirty. I try to do the lightest colors first. I like how the socks seem to buffer the heat and protect the covering. -Steve
Griffin is offline Find More Posts by Griffin
Old Jan 27, 2007, 09:29 AM
Kansas
Joined Jul 2002
As far as plastic scrubby scratching metal, I don't think so.
If anything it will burnish the iron.
Old Jan 27, 2007, 01:28 PM
Joined Sep 2004
Thanks for the info guys. I will pick up some socks for the iron.
Old Jan 27, 2007, 07:42 PM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I've used dope thinners and acetone with great success. now I wipe the whole covered model with it after covering..brings up a sheen and gets rid of any bits of glue.
Old Jan 27, 2007, 08:15 PM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
Don't know if it's still available but I use a product called Ironex. Made especially for cleaning irons. I hope its still available as I'm running low.
BM
BillM is offline Find More Posts by BillM
Old Jan 27, 2007, 09:38 PM
junkman
United States, AL, Madison
Joined May 2004
Candle wax works too! Try it while the iron is still hot. I wouldn't use colored candles.
DC
Douglas Cheatwo is offline Find More Posts by Douglas Cheatwo
Old Jan 27, 2007, 10:07 PM
Jaded Flyer
mcharles13's Avatar
United States, FL, Clearwater
Joined Aug 2004
wow i've apparantly been doing this the wrong way. I just wipe it while it's hot on an old pair of jeans.
mcharles13 is offline Find More Posts by mcharles13
Removing Dried CA from Wing Covering??? Jagzilla Parkflyers 5 Mar 13, 2005 09:29 AM
Removing Surplus cord from Qualcomm Charger boomerace Parkflyers 2 Mar 17, 2002 11:34 PM
Removing Extra Cord from Qualcomm Lithium Charger boomerace Power Systems 0 Mar 17, 2002 12:08 PM
Removing covering film cwalsh Electric Plane Talk 2 Jan 08, 2002 04:55 AM
Removing CA fog from Oracover Kevin Murray Electric Plane Talk 6 Sep 07, 2001 07:51 AM
