Old Sep 25, 2002, 09:09 AM
Slope Nut is offline
Find More Posts by Slope Nut
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Bomb drop diagrams?
I am building into my CL-415 waterbomber a bomb drop into the hull at the CG. New Mexico is high desert so I wont be flying off water all that often anyway, which is the reason I am putting a bomb drop in.
I plan on having the hull doors swing out at the CG so I can drop baking soda to simulate a water drop run (my friend has an OV-10 with CA firefighting scheme on it so he is going to lead me in!).
Any help with bomb drop diagrams would be great. I just need to open two doors with one servo.
Greg
Slope Nut is offline Find More Posts by Slope Nut
Old Jul 05, 2009, 08:54 PM
paulrink is offline
Find More Posts by paulrink
United States, CA, Hayward
Joined Jul 2009
Will it work on a 1/12 nitro plane?
paulrink is offline Find More Posts by paulrink
Old Jul 05, 2009, 08:57 PM
paulrink is offline
Joined Jul 2009
Does the size plane has to have the same size servo ?Or could you use a micro servo?
Old Jul 05, 2009, 09:00 PM
paulrink is offline
Joined Jul 2009
I want to put bomb drop on my spit fire that is 1/12 scale.Please email me directions on how to do it? I have not baught a printer yet.
Old Jul 05, 2009, 09:47 PM
Shpook is offline
Find More Posts by Shpook
What's that button do?
Shpook's Avatar
Hollywood, FL
Joined Feb 2008
Paul, this thread is almost 7 years old. Slope Nut hasn't posted in almost two years. I don't think you're getting an answer from him.
As to your questions, use our forums' search function. There is a wealth of knowledge here, and you're almost guaranteed to find your answer.
Shpook is offline Find More Posts by Shpook
Old Jul 05, 2009, 10:33 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
simplest bomb release is a pull-pin type.
The servo pulls a string attached to a pin. the pin is fed through 2 eye bolts in th ebelly of the plane trappung 2 eye bolts in the "bomb" (which would be something similar to a plastic easter egg with fins added)
The next step in complexity is adding a spring to the pin so its a little easier to "load" the bomb and keep th e pin from comming out before you actuate the servo to pull it.
Adding the simplest spring requires the spring from a pen and a wheel collar.
I will do a drawing in "Paint" to show how these are set up.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Feb 08, 2011, 01:49 PM
CasualFlyer23 is offline
Find More Posts by CasualFlyer23
Rohnert Park, CA
Joined Jul 2010
thanks for showing a good and simple way to make a bomb drop i was looking for an easy way to put one on my pkz trojan and havent found a way that i like yet but ill try this way out
CasualFlyer23 is offline Find More Posts by CasualFlyer23
Old Feb 08, 2011, 02:05 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Casual, also have a look below, (just scroll down), and you should see the 'Similar Threads' list. There are some more 'bomb drop' threads around.
Just noticed they are rather old ones, try a search on 'bomb drop' in the thread titles, there has been many, there are also commercial units available now.
Edit - just did the search, 79 threads were flagged up.
eflightray is offline Find More Posts by eflightray
FS: GWS A-10 with Bomb Drop - Foam Wheels - Ready To Fly with Servos and ESC LESLIEx317537 Aircraft - Electric - Airplanes (FS/W) 12 May 07, 2004 06:41 PM
any ideas for a bomb drop for Corsair 67bigdog Parkflyers 5 Dec 31, 2003 07:11 PM
Yippee! GWS A-10 with Bomb Drop. LESLIEx317537 Parkflyers 19 Nov 28, 2003 10:25 PM
E-Starter battery/bomb drop Flybyguy Foamies (Kits) 7 Sep 20, 2003 04:05 PM
TigerMoth Bomb Drop D W Parkflyers 6 Oct 26, 2002 08:38 PM
