Old Jan 26, 2007, 01:12 PM
skyranger912s is offline
Find More Posts by skyranger912s
Joined Jan 2007
Build Log
Manzano Laser/Peter Rake Thomas Morse Scout Prototype Buils
Seems I have been given the opportunity to follow in the footsteps of a number of very excellent modellers, most of whom are better qualified to be doing this than me. At least that's what Peter and Charlie told me when they offered me the chance to proof build this prototype model. No truth to the rumors that all the over slaves had died of overwork and underpay then....
So we'll start with a little bit of history about the fullsized Tommy......
The Thomas company was founded by a young Englishman, W. T. Thomas, who emigrated to the United States and obtained a position with Glenn Curtiss at Hammondsport, New York. He was later joined by his brother Oliver, and they set up the aircraft firm of Thomas Brothers at Hammondsport, where an experimental pusher biplane was constructed in 1910.
The firm then moved to Bath, New York, where a number of types were built; one of these gained the world's altitude record in 1913. Shortly before the outbreak of war in Europe, B. D. Thomas--no relation--joined the concern; he had worked for both the Vickers and Sopwith companies in England. His first design was the T-2 tractor biplane , twenty-four of which were supplied to the British Admiralty in 1915.
After a second move, to Ithaca, New York, the firm began to produce aero engines, one of which was installed in their next design, the D-2 tractor biplane. During 1915 two seaplanes and the D-5 landplane were built for the U.S. Navy and Signal Corps respectively; further seaplanes and a flying boat appeared in the following year.
In January 1917 the firm merged with the Morse Chain Company of Ithaca, and the concern was reorganized as the Thomas-Morse Corporation. The first Thomas-Morse aeroplane was a trim little single-seater biplane, the S-4. Its 100 hp. Gnome Monosoupape 9-B rotary engine was partly enclosed by a circular open-fronted cowling, which was faired into the flat-sided fuselage by triangular fillets. The staggered wings were constructed of wood, wire-braced and fabric-covered; the top plane was flat, the lower plane had slight dihedral. There was a semicircular cut-out in the trailing-edge of the top wing, which carried the ailerons; these were operated by vertical rods. Single-bay wooden interplane struts, braced by wire, were fitted; the center section struts were slightly splayed outwards. The fuselage was a wooden wire-braced box girder, with a rounded top decking; the whole structure being covered with fabric. The neatly shaped empennage was of wood and fabric construction. Wooden vee struts formed the undercarriage legs. the wheels were sprung with rubber cord.
As it could be easily converted into a seaplane, the S-4 was offered to both the U.S. Army and Navy. The prototype was tested at Hampton, Virginia, and as a result of these trials fifty modified machines, known as S-4Bs, were ordered shortly after the United States entered the war.
This order was increased to 150 to cope with the increased need for training aeroplanes. Meanwhile a similar model with twin floats, the S-5, was put into production for the Navy Department.
The last fifty machines ordered had shorter-span wings and were designated S-4Cs. Further orders were placed for this version, with the 80 hp. Le Rhône 9-C rotary, built by the Union Switch and Signal Company of Swissvale, Pennsylvania, in place of the Mono-Gnome; the fuselage of the Le Rhône 'Tommy' was slightly shorter.
In all 447 Le Rhone versions were delivered, and they were widely used as advanced trainers. The final model in the series was the S-4E aerobatic trainer; it had shorter tapered wings and a mounting for a synchronized gun.
Specifications:
Thomas-Morse S4c Scout
Dimensions:
Top Wing span:
26 ft 6 in (8.07 m)
Bottom Wing Span: 25 ft 6 in (7.77 m)
Top Chord: 5 ft 6 in (1.67 m)
Bottom Chord: 4 ft 3 in (1.29 m)
Gap Between Wings: 4 ft 6 in (1.37 m)
Length: 19 ft 10 in (6.06 m)
Height: 8 ft 1 in (2.46 m)
Weights:
Empty: 961 lb (435 kg)
Gross: 1,354 lb (614 kg)
Performance:
Maximum Speed:
100 mph (160 km/h) @ Sea Level
Service Ceiling: 15,000 ft (4,572 m)
Fuel Capacity: 27 gal (102 lt)
Powerplant:
One Gnome Mono 100 hp (74 kw) 9-cylinder Rotary type
or
One Le Rhône 9-C 80 hp (59 kw) 9-cylinder Rotary type.
Armament:
Synchronized machine gun.
Oh well, enough waffle.......
With brand new 10 megapixel camera on standby the first task is to open the box.........
skyranger912s is offline Find More Posts by skyranger912s
Old Jan 26, 2007, 03:19 PM
PETERRAKE is online now
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Welcome aboard mate. None of the other builders actually died due to overwork, I just nagged them into early retirement. That's why we're reduced to second grade labour mate.
Seriously, whilst we need this one finished by the end of the week, you take your time and enjoy the build. Openning the box is always a good starting point. You'll find step two is harder, getting the bits out of the polythene bags.
Genuinely though mate, it is important that you get pleasure from the build. Then, just possibly, you might feel inclined to repeat the experience.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Jan 26, 2007, 04:14 PM
AlFonz is offline
Find More Posts by AlFonz
Kingsville, Ontario Canada
Joined Dec 2006
Com'on open the box already, I'm waiting here with baited breath. Actually am interested to see if the lower wing incidence called for is 3deg. pos., whilst the upper is at 0deg.(negative decalage).
There is a wide difference of opinion on this and after many posts, the people discussing it more or less came to the conclusion that it didn't make a huge difference if the decalage was positive, negative or neutral so long as the incidence wasn't too large. I hope this post is in keeping with the topic as I've built a similar type with the aforementioned set up, and was wondering what to expect on the maiden. I'll stop talking now and start listening (reading) and enjoy the ride.
Alan
AlFonz is offline Find More Posts by AlFonz
Old Jan 26, 2007, 05:28 PM
Norfolk, England
Joined Sep 2001
Alan,
You don't need to wait for the box to be opened, I can answer that one for you - IT ISN'T. Both wings are at the same angle of incidence, roughly 1 degree. Now, before anyone says it isn't enough, the plan built version flew extremely well.
It also has a similar amount of positive incidence on the tailplane.
Pete
Old Jan 26, 2007, 09:06 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
sky...
Welcome and hope you like the build. The nice thing about posting in here is it motivates you to keep going. Cause if you don't keep posting there are plenty of us to nag you
charlie
portablevcb is offline Find More Posts by portablevcb
Old Jan 26, 2007, 10:07 PM
AlFonz is offline
Joined Dec 2006
Thanks for the reply Peter, you the Man. I'm happy with that answer. Since mine is glued up, I won't change it unless I rekit it.
Alan
Old Jan 31, 2007, 11:15 AM
dpoles is offline
Find More Posts by dpoles
Crash and Build
dpoles's Avatar
United States, NY, Ithaca
Joined Oct 2001
The Tommy is HIGH on my build list, my desk is about 100 yards from the old Tommy Morse factory.
I will buy this kit when it is released.
I saw one all naked at the Fantasy of Flight museum near Orlando last week and took these pics.
dpoles is offline Find More Posts by dpoles
Old Jul 16, 2009, 09:15 PM
invid66 is offline
Find More Posts by invid66
Which means "what" to me?
invid66's Avatar
United States, FL, Havana
Joined Jun 2007
So what happened next? The story ended right in the middle of the first chapter.
invid66 is offline Find More Posts by invid66
Old Jul 17, 2009, 02:14 AM
Norfolk, England
Joined Sep 2001
Absolutely nithing, that was the guys ONLY post. However, the model has been proofed and is in Charlie's listings.
Pete
Old Jul 17, 2009, 11:08 AM
invid66 is offline
invid66's Avatar
Joined Jun 2007
OOOhhh. I know its proofed I've got one sitting on the closet shelf waiting for me to finish my DH-6 and F2B. I was just looking for more building info
Old Jul 17, 2009, 12:42 PM
Norfolk, England
Joined Sep 2001
Have you checked out the link at the bottom of this page, plenty of info there.
Old Jul 18, 2009, 09:35 AM
pipescs is offline
Find More Posts by pipescs
Lester, Al
Joined Mar 2005
Yanks Museum
Thought these might motivate you. It is being restored to fly at the Yanks Musem in Chino California
Not much help to a modeler at this scale as it mostly shows the construction.
Best of luck on the project.
I'm off to cut the grass and the HUNNYDO list.
pipescs is offline Find More Posts by pipescs
Old Jul 18, 2009, 10:30 AM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
These are great!!
I have a 1/6 scale Tommy Morse 3/4 drawn but got stuck on several points. These photos help.
Martin
Martin Irvine is offline Find More Posts by Martin Irvine
Old Jul 18, 2009, 11:21 AM
pipescs is offline
Lester, Al
Joined Mar 2005
I have around twenty or so large format shots of the one in Chino. If anyone wants them drop me a PM here with your email address and I will send
I will be on travel with my job next week to the Tucson area so it will be the week after next when they go out.
I have to send from my work as I have dial up here at the house
Peter Rake Thomas Morse Scout S4C "Tommy" JIMA Scale Kit/Scratch Built 155 May 22, 2011 09:32 AM
Discussion Guillow's Thomas Morse Scout E-conversion started craab Scale Kit/Scratch Built 44 Jan 06, 2011 02:40 AM
Guillow's Thomas Morse Scout finally gets built Aubard Scale Kit/Scratch Built 34 Jan 17, 2005 09:19 PM
Peter Rake's Bristol Scout finally ready LawrenceHare Scale Kit/Scratch Built 11 Apr 05, 2004 05:10 PM
Peter Rake 50" Camel prototype wanted AerodromeRC Scale Kit/Scratch Built 8 May 28, 2003 11:36 PM
