Old Jan 25, 2007, 02:50 AM
Zimm is offline
Find More Posts by Zimm
Joined Jul 2004
Guillow,s cessna 172 video
Here is my latest electric conversion video. http://www.rcgroups.com/forums/showt...53#post6798191
weight is 10 ounces.
video is in DIVX format.
Zimm is offline Find More Posts by Zimm
Old Jan 25, 2007, 02:52 AM
Zimm is offline
Joined Jul 2004
some pic,s
Old Jan 25, 2007, 04:37 AM
Tipsy_WA is offline
Find More Posts by Tipsy_WA
Tipsy_WA's Avatar
Perth Western Australia
Joined Oct 2002
Nice Vid...hope to see it at indoor soon.
It seems you almost hit that car.
Tipsy_WA is offline Find More Posts by Tipsy_WA
Old Jan 25, 2007, 12:22 PM
SVX is offline
SVX
Find More Posts by SVX
SVX
SVX's Avatar
Joined Oct 2002
Very nice!! I wasn't able to down load the video but those pics are beautiful. Any details as far as power system? Did you use any of the Kit wood? 10 oz. seems really light for a guillows.
SVX is offline Find More Posts by SVX
Old Jan 25, 2007, 11:08 PM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
Terrific video!
I don't know what it is about the larger models but a .40-.60 size(or larger) Cessna like this I could care less about. But This! Truly wonderful.
Is this the 36" span? Steerable nosewheel? Ground handling looked good.
Beautiful finish!
Bravo, Robert
willin is offline Find More Posts by willin
Old Jan 25, 2007, 11:12 PM
Chris F is online now
Find More Posts by Chris F
The Revegetator
Chris F's Avatar
Melbourne Australia
Joined Jun 2006
Great looking Cessna, nicely flown and great camera work too! I'm also keen for some details. I like the Magpies and Galahs too
Chris.
Chris F is online now Find More Posts by Chris F
Old Jan 25, 2007, 11:16 PM
bryguy17 is offline
Find More Posts by bryguy17
Joined Dec 2006
thats a beautiful plane....very well done finish on it
bryguy17 is offline Find More Posts by bryguy17
Old Jan 26, 2007, 12:07 AM
N827TM is online now
Find More Posts by N827TM
Mansell Models
N827TM's Avatar
United States, UT, Layton
Joined May 2004
Zimmerman,
Nice job with your Cessna. Did you do a build thread? I have a Cessna 172 I have partially built. I am wondering what you are using for your setup? Power sytem battery, radio gear etc. Also what covering you used? I am at the electric fly festival this weekend at AZ and it is great. Pat Trittle is here and I have had a great chat with him. He also has some nice scale birds.
Tom
N827TM is online now Find More Posts by N827TM
Old Jan 26, 2007, 01:07 AM
shim is offline
Find More Posts by shim
Brunei Darussalam
Joined Mar 2003
Zimmerman,
I hope you will also be posting a build thread for it.
How did you finish it, balsa or covering? What about painting?
Please also share about the controls and power system.
Thanks.
shim is offline Find More Posts by shim
Old Jan 26, 2007, 06:29 AM
Zimm is offline
Joined Jul 2004
Thanks for everyones interest,
i was really happy with the weight, i built one three years back and it was to heavy around 18 ounces,
had to fly real fast and it always tipped stalled.
i managed to save the weight, by replacing some of the balsa . and some of the plastic, and no epoxy only CA.
I used a much lighter film than i normally use, and it is not see throw, it also made covering much easier, it did not crush and distort the fragile frame. I can not remember what it was called it was the first time that i used it,i will look for the label.
The setup was
Hacker B-20-31S 2900KV 41 grams
2.5 :1 gearbox
3S 400 mha hyperion 35 grams
3x 3.6 gram sevos
APC 7x5
12 amp speedy 8.5 grams
run time 10 min only putting back 220 mha
max amp 5.5
I was flying on maybe 10 to 15 % throttle, no deans plug, JT instead I did not take a lot of pic this is all that i have.
I just received a new kit that i am starting soon. it is a bonanza 35V 33" from Acme Aircraft Company.
I hop too make this one around 8 ounces.
I think, if you can save every gram it all adds up and can help in keeping models lighter.
The paint was applied with a airbrush Color scheme was from the cover box, very 60's
Ailerons, elevator, nose wheel steering, no rudder.
The radio is Spektrum the receiver is a little lighter 15 grams the new receivers soon to be released are 3.6 grams.
Old Jan 26, 2007, 11:37 AM
Rekitter is offline
Find More Posts by Rekitter
Rekitter's Avatar
Oakland, CA
Joined Nov 2002
Hi:
I have to tip the hat to you on this build. You did a fantastic job on this conversion. It looks like a real cessna. Thanks for sharing your process and hope that you do some more. You obviously have a lot of skill at this.
Alex
Rekitter is offline Find More Posts by Rekitter
Old Jan 26, 2007, 07:39 PM
Zimm is offline
Joined Jul 2004
Making the wing secure and easy accesses to the battery
I used plastic screws and magnets.
on the plans it shows a hook like release under the wings for the struts, this works fine if you don't need access to the battery.
the magnets hold good and are not heavier at 0.2grams each.
You only undo two screws and the wing is off.
The elevator Rod is 2mm carbon with a pin drilled threw, for horn.
Old Jan 26, 2007, 07:43 PM
glue_sniffer is offline
Find More Posts by glue_sniffer
Balsa is love....
glue_sniffer's Avatar
Los Gatos, CA
Joined Aug 2004
I finally got the whole Divx thing to work, and I'm glad I did - fantastic video! She looks really rock solid in the air, which is saying a lot considering the size. Well done!
-Sky
glue_sniffer is offline Find More Posts by glue_sniffer
Old Jan 26, 2007, 07:54 PM
Zimm is offline
Joined Jul 2004
Sky,
I am about to start the bonanza I have tried the 3 bladed prop on the motor/gearbox and it works great! Hope to have it finnished soon,
may make a video of the Bonanza and cessna flying together?
Old Jan 26, 2007, 11:19 PM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Great job!
I'm curious - you said you did not use the Guillow's plastics?
Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
GUILLOW'S CESSNA 172 SKYHAWK conversion to electric. reznikvova Parkflyers 25 May 03, 2008 12:56 AM
Video Guillow,s cessna 172 video Zimm Electric Plane Talk 15 Dec 10, 2007 03:08 PM
Video New cessna 172 video slow flying Zimm Electric Plane Talk 2 Feb 06, 2007 06:28 PM
Video! Guillow's SE5-a with CD-ROM AteIier-U Parkflyers 5 Sep 24, 2004 10:41 PM
RFFS for Guillow's 24" Cessna 170 mkirsch1 Scratchbuilt Indoor and Micro Models 6 Jan 22, 2003 07:26 AM
