Espritmodel.com Heli Air
Old Jan 24, 2007, 04:35 PM
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Flybarless electric Raptor 90...
Those wacky Germans are at it again... Ron Sebastian, one of the very capable "new breed" German pilots, and who was heavily involved in the design, prototyping and early testing of the e620SE electric Raptor, has done this very interesting "one of" Raptor 90 conversion, that is absolutely nothing short of elegant in its simplicity. He got rid of the flybar and instead installed two CSM SL720 gyros, which have some special "tweaks" via the standard PC application. More about that in a minute. Here's some pics:
What Ron did for the conversion was to simply do a new set of lower frames, a couple of spacers for the skids, and a motor plate. Ron used the big blue Pletti and a specially made 12T pinion, with the 95T main gear. He also used a CC Phx HV 110 controller and two 6s-4900 FP Evo 20 packs, in a 12s configuration. The 100% h/s is around 2200, which he has dialed down to about 2000, and is rock solid. He's using 710mm NHPs and has 10-11 degrees of pitch. Performance was "scary", according to Ron. He's never flown anything with that much power. With that big a disc size, spinning at 2000 rpm and 11 degrees of pitch, it has to be pulling close to 5000W, and without the FB drag, a lot more of those watts are getting to the head.
He's using the standard R90 washout, but he used red Loctite to "glue" it to the main shaft. I think just using it with the standard hub and the guide pins would have the same efect, which is to keep the swash from rotating. The innermost link holes are used on the servo arms. If you look carefully in the 2nd to last picture, you can see that he is using two of the multiplex digital servos to move the pitch arm. With one there was too much "groaning" and the response wasn't "crisp". I'd probably try using a stronger servo, like one of Jeff's Ace 1015s, with 200 oz/in of torque, but Ron says this was an easy "fix" and it is MUCH more responsive.
As you can see in the last couple of pics, he's using three SL720s. One is for the normal tail function, and it drives a 9254. The other two are mounted in each axis for pitch and roll, and have the "tweaks" that he and Colin Mill have been working on. The beauty of this setup is that no CCPM mixer is required, as it uses the standard Raptor mechanical mixing. Colin, I hear, is close to finishing up his new eCCPM mixer, which he will include in a complete package as a direct competitor for the uber-expensive V-Stab system.
Ron said so far he's only had a quick first test. For one thing, the motor is surgig, so he needs to dial down the goernor gain setting. He also needs to fine tune the gyro gains and maybe tweak the PC settings a bit more. I haven't played with the SL720 before, but as I undestand it you can adjust a great many things, with the included PC application. Between Ron and Colin, they've got a pretty optimized set of "tweaks", but these were for Raptor 50s. The tweaks need to be tweaked a bit more for the larger R90. Ron will do take care of this fine tuning this coming weekend.
Before I get a flood of emails and PMs, this conversion is not for sale. It was just something Ron did as a "test bed" for the flybarless setup. He wanted something "sporty" to fly at this year's 3D Masters. I'm not sure if TT is working on a 90-size electric, or not. I'm guessing that if they are, we might see something at next week's Nuremberg show.
Anyway, I will get Ron to post his test results here. I must say, how impressed I am with this "outside-the-box" approach to develop a model of the highest performance, by any measure.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Jan 24, 2007, 05:06 PM
United States, MI, Goodrich
Joined Mar 2004
Speechless!!!!!
UAVProducts is offline Find More Posts by UAVProducts
Site Sponsor
Old Jan 24, 2007, 06:16 PM
volts x amps = watts.
Wheelhaus's Avatar
Denver
Joined Sep 2006
holy crap... That's awesome.. If you find any video, PLEASE post it!
Wheelhaus is offline Find More Posts by Wheelhaus
Old Jan 24, 2007, 06:18 PM
Gimbaled
superdave42's Avatar
morgan hill california
Joined May 2004
That is awesome !!! wow very nice work
superdave42 is offline Find More Posts by superdave42
Latest blog entry: Some of my Multicopter designs
Old Jan 24, 2007, 06:35 PM
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
http://www.rcgroups.com/forums/showthread.php?t=500904 for those that don't have a R90.
I've got around 60 flights on the helicopter and so far the SL-720's are awesome.
DavidB. is offline Find More Posts by DavidB.
Old Jan 24, 2007, 07:01 PM
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
looks like fun boys
ozace is offline Find More Posts by ozace
Old Jan 24, 2007, 10:32 PM
Wheelhaus's Avatar
Denver
Joined Sep 2006
I've been following some Runryder threads for the last few months about CSM's virtual flybar. I am hoping I can be one of the first in line, but I have a feeling there's already a huge line to begin with...
Old Jan 24, 2007, 11:14 PM
Photoship One's Avatar
Mesa, AZ
Joined May 2002
nice! I suspect he "glued" the washout to the shaft because there may be a chance of it dropping too low and coming "unconnected" with the pins in the head at full negative collective.
I bet it's ultra responsive!
Photoship One is offline Find More Posts by Photoship One
Old Jan 25, 2007, 12:29 AM
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
Tell me you're gonna build one. I'll definetly drag myself away form my books to watch you test that! I wonder why he selected that big pletti. I ran mine in my maxi, but found in my setup, the actro 32-4 ran a lot better. The pletti has power, but doesn't seem to cool very well. it gets fairly warm, and just stays warm.
Rhett
rroback is offline Find More Posts by rroback
Old Jan 25, 2007, 12:47 AM
GGoodrum's Avatar
Joined Mar 2003
Actually, the swash only moves about half as much as it used to, so "falling out" of the guides is probably not an issue.
Ron said it was extremely quick, even with the gain way down low.
-- Gary
Old Jan 25, 2007, 01:49 AM
Lorents
lorents's Avatar
Oslo, Norway
Joined Dec 2004
Very cool!
I guess the glueing of the wash out base is dont to make a swash driver for the flybarless head.
lorents is offline Find More Posts by lorents
Old Jan 25, 2007, 07:39 AM
Das Universus Elektrikus
Albig's Avatar
NM, USA
Joined Mar 2002
This is really cool
I can't wait until Colin puts something on the market.
Albig is offline Find More Posts by Albig
Old Jan 25, 2007, 09:03 AM
Wheelhaus's Avatar
Denver
Joined Sep 2006
yep.
I think I will either drill two holes on both sides and use grub screws, or cut the pin slot clean through on one side of the washout base and use a bolt, so the whole washout base is a clamp, driver link on the opposite side of the clamping bolt.
The only problem with mikado's swash driver is that it pushes against the pitch links. First, it wears into the plastic guides, and secondly, it creates extra friction. On some head designs, that may facilitate a slightly loose ball link to pop off it's ball...
Old Jan 25, 2007, 10:07 AM
GGoodrum's Avatar
Joined Mar 2003
I guess I'm having trouble understanding why the washout has to be fixed to the shaft when the existing pins would keep it from rotating. The swash doesn't move up and down as much as it does with the flybar setup, so the washout is not going to "fall out".
The SL720 solution is available now, if you have an external eCCPM mixer. I think you can get the "tweaks" directly from CSM. I have several AP-2000i stabilzers, from www.spartanrc.com, that we use with the FMA CoPilot IR sensor on AP/AV rigs for helping to stabilze hovering. One of the functions included in the AP-2000i is a very good eCCPM mixer. One of these plus two SL720s would do quite nicely I think. Spratan RC is also working on their own programmable gyro, which will be a direct competitor for the SL720 and GY611, and I fully expect we'll see a complete V-Stab - like offering from them as well.
Of course, there is also the option of doing a Raptor with the stock mechanical mixing, like Ron is doing with his R90. I wonder if I could modify my eTitan conversion to still keep the motor up high, in back, but use the mechanical mixing. Food for thought...
-- Gary
Old Jan 25, 2007, 10:18 AM
Wheelhaus's Avatar
Denver
Joined Sep 2006
It's fixed so it doesn't drop down and sit on top of the swash. without a link connected to the flybar, there's no support.
With the washout fixed, you could eliminate a bit of weight and cut off the alignment pins from the head.
Idea Raptor 90 Electric convertion Helioaus Electric Motor Design and Construction 5 May 28, 2008 12:08 PM
Discussion TT Raptor 90 Electric conversion ? OzparkPilot Electric Heli Talk 5 Jul 22, 2007 08:46 PM
For Sale Super electric Raptor 50/90 camera ship!!! MUST SEE!!! FlybyPDX Aircraft - Electric - Helis (FS/W) 9 Oct 19, 2006 04:56 PM
