Old Jan 24, 2007, 12:31 PM
golem is offline
Find More Posts by golem
golem's Avatar
Maryland, USA
Joined Mar 2006
Question
Can carbon strip be scored and snapped cleanly?
I'm envisioning being able to longitudinally cut unidirectional carbon strip the same way one would score and cut a sheet of glass. Is this possible?
Cheers,
golem
golem is offline Find More Posts by golem
Old Jan 24, 2007, 01:24 PM
lolzor is offline
Find More Posts by lolzor
Lund, Sweden
Joined Jun 2006
try?
lolzor is offline Find More Posts by lolzor
Old Jan 24, 2007, 01:47 PM
golem is offline
golem's Avatar
Maryland, USA
Joined Mar 2006
Originally Posted by lolzor
try?
Thanks for the recommendation but...if I had some I would have already tried it. Positive input will be the determining factor as to whether or not my first carbon strip purchase is a single wide strip that I can cut to required widths or buying multiple narrow strips.
Cheers,
golem
Old Jan 24, 2007, 01:59 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I've found that when I try to break a strip even after I've scored it, there are always some threads that are hanging off. From what I've experienced, it'll break but not cleanly.
rmgmag is offline Find More Posts by rmgmag
Old Jan 24, 2007, 02:16 PM
golem is offline
golem's Avatar
Maryland, USA
Joined Mar 2006
Thanks for the insight rmgmag. That's what I was hoping not to hear but what I was prepared for nonetheless. Probably would be expecting a lot for both the filaments AND score to be lined up perfectly. Curious though, did the threads clean up easily or does it seem to be more trouble than it's worth?
Cheers,
golem
Old Jan 24, 2007, 02:38 PM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I guess it depends on the thickness of the strips because lately I've just been cutting them with a scissors. That does lead to some fraying, but not too bad. I just trim the ends as best I can and dip the ends in a drop of CA and hit it with accelerator and everything stays together fairly well. You can even sand the ends down a bit to smooth them out once they've been CA'd.
I think that if you break the strips and then trim the filaments and then add a touch of CA to the ends, you should be OK.
When I'm not feeling too lazy I'll use a dremel with a cut-off wheel to cut the strips, but even then I end up with some frayed edges. Again, the CA trick cures that issue.
Bob
Old Jan 24, 2007, 03:03 PM
golem is offline
golem's Avatar
Maryland, USA
Joined Mar 2006
Appreciate the follow-up! Now that it sound like acceptable results may be possible I think I'll give it a try.
Cheers,
golem
Old Jan 24, 2007, 07:20 PM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
I've found dremmel tool with cutting disk works for me (just don't breath the dust)
I've never been able to just score it and have it break. (with the epoxy in addition to the carbon, it's not prone to brittle fractures as is glass)
Nethole is offline Find More Posts by Nethole
Old Jan 24, 2007, 07:47 PM
golem is offline
golem's Avatar
Maryland, USA
Joined Mar 2006
Thanks for your info Nethole.
I was just thinking about using the dremel (as per yours and rmgmag's posts) with a router attachment. Should be really easy to affix a jig to the router attachment allowing for a very clean and precise cut, nice thin blade on low speed should also provide for little waste. And yes, a shop-vac to eliminate the nasties.
It's just too tempting to be able to get six .8x4x1000mm strips for less than $2 apiece or eight 3mm wide for $1.30ea from Hobby-Lobby.
Cheers,
golem
Can a Monarch HLG be discus-launched ? knut Electric Sailplanes 5 Dec 11, 2001 09:20 PM
Can 540 motors be used with Kyosho EDF unit? the#1 Electric Ducted Fan Jet Talk 1 Sep 12, 2001 05:29 PM
Can my ESC be fixed? mopar_man Power Systems 14 Aug 03, 2001 12:54 AM
Can a folding prop be used in pusher config? MtnGoat Power Systems 2 Jul 26, 2001 09:44 PM
Can a hill(mountain) be too big for sloping? Foxtrot Electric Sailplanes 17 Jul 05, 2001 12:23 AM
