Go Back   RC Groups > Aircraft - Electric - Helis > Mini Helis
Old Jan 24, 2007, 05:15 AM   #1
Dragonus Owners thread!!
I know there is several build threads already but i did not see one owners thread. So all of you dragonus SA , elite , pro owners care to chime in and post your setup?
gyro?
servo?
motor?
battery? (location?)
and better yet picture of your heli with and without canopy
crxef9 is offline Find More Posts by crxef9   Reply With Quote
Old Jan 24, 2007, 10:59 AM   #2
LAHeli Ricco Ninja
w00t w00t!
GY-401 w/ S9650,
HS-65MG's cyclic,
RC-TEK 3500kv motor w/ Align 35A 6v ESC (couple different ESC's in testing tho),
MaxAmps 3s 2100 or TP Prolite 2100 or TPX 2070 - all in the battery tray like normal.
Can't find a good pic right now.. =\
-Kyle
arclite5 is offline Find More Posts by arclite5   Reply With Quote
Old Jan 24, 2007, 11:27 AM   #3
only one owner?
arclite5: how were you able to fit in those HS65? i thought those cant fit?
Old Jan 24, 2007, 11:54 AM   #4
JKY
Dragonus SA
Z-power 450th 3300kv 'fan' motor
Rc-expert 40a governor ESC (this may only be temporary depending on how it performs)
3 x Hitec 65s - frames need opening out
No tail servo yet
Probably telebee gyro for now
JR 77s receiver
JKY is offline Find More Posts by JKY   Reply With Quote
Old Jan 24, 2007, 12:07 PM   #5
LAHeli Ricco Ninja
Originally Posted by crxef9
only one owner?
They fit just fine.. I didn't have to open my frame or anything. They were a tight squeeze to fit into the servo tower, but I convinced them to fit with a little wiggle.
Weird that some people can't get 'em to fit. I guess it would only have to be a fraction of a millimeter smaller of a hole to cause that to happen?
-Kyle
Old Jan 24, 2007, 12:09 PM   #6
JKY: whats a 'fan" motor , what whats a JR 77s receiver? a 770 or 790?
arclite: yea even jky need to open things up
keep em coming guys
Old Jan 24, 2007, 12:21 PM   #7
Fly-Bar? What Fly-Bar?
blade strike's Avatar
only one owner?
It seems that SA's need to be moded just a bit... But some say the same on the SE.. I didnt need to mod my SE but some do.
But on the elite's they fit just fine
blade strike is offline Find More Posts by blade strike   Reply With Quote
Old Jan 24, 2007, 12:59 PM   #8
JKY
My frame will need about 1.5 mm (.75 each end so not too much), same on the servo tower - no way that wiggling it will get it to go. Understand that the metal v fibre frames may be different but I thought that the tower was the same. Strange that there seems to be such variation.
Jr 77s is the small pcm sythesised rc (same looks for all 700 770 70s 77s). May be labelled differently in USA
Fan motor is the latest zpower one with a fan on the bottom that only seems avalable from 'wattsuprc'. A pal has one in his Trex SE and he is very impressed - super smooth, powerful, low consumption and never gets hot.
http://www.wattsuprc.com.au/product_...asp?pid=ZP02-1
Old Jan 24, 2007, 01:22 PM   #9
great info thanks
Old Jan 24, 2007, 02:49 PM   #10
Conformity Kill's
Dragonous II Elite
HS65mg on Cyclic
401/9650 on tail with RC-Teck 9650 frame mount for the 9650
Spektrum DX7 TX with AR6000 RX
ZPower Z10A 3300
13t pinion
325mm pro woddies
DN Power 2150 20C 3S
A2,B2,C2 programed on the head
geneween
PS: The picture is an old one. It now has the intruder canopy on it and I like the looks much better.
  • Name: DSCN0653.JPG
geneween is offline Find More Posts by geneween   Reply With Quote
Old Jan 24, 2007, 02:52 PM   #11
buzzsaw 46's Avatar
DII Pro
3x DS285's on cyclic
1x KoPropo PDS-3014 on tail
Logictech LGT-2100T gyro
JR 790 PCM RX
CC P-60 ESC
Park BEC 6v
Mega 16/15/5 11t pinion
6s TP PL 1320's
A2,B1,C1 on the head links
buzzsaw 46 is offline Find More Posts by buzzsaw 46   Reply With Quote
Old Jan 24, 2007, 03:31 PM   #12
Your attitude is your alt
Gary Morris's Avatar
Dragnous II
I have two, one using a Futaba GY-240 gyro the other using the Art-Tech HH gyro, both fly well with no problems thus far. I hope that parts become available soon in quantities that will be able to fill orders when that all too often crash happens. I'm running Electron 6's with Jeti Spin 33 speed controllers, HS-65's on swash and tail. My only concern has been battery placement, if using anything larger than a TP 2100 pack the battery hits the front of the canopy and if your not careful the back of the battery will rub on the front of the motor. The canopy should have been designed so that there is 1/2 inch more room in the front, had they done this practically any 3-cell pack would fit with no problems. Another possible solution is moving the two posts forward 1/2 inch and having the canopy not slide so far back. This would cause the main gear to possibly rub on the canopy though.
Gary
Gary Morris is offline Find More Posts by Gary Morris   Reply With Quote
Old Jan 24, 2007, 04:03 PM   #13
Ok here is my Dragonus Pro:
JR 7202 with 3x DS 285 on cyclic, 9650/401 on tail, RC-TEK 3500 kv motor (awesome for the money), Park BEC 6V, Align 35G ESC, Tech-MP micro antenna, DN Power 15C and 20C 2150 packs.
Here is a picture of my baby sleeping in its crib!
Here are some other pictures:
http://www.rcgroups.com/forums/showthread.php?t=625698
  • Name: IMG_1729.jpg
ucsdgemini is offline Find More Posts by ucsdgemini   Reply With Quote
Old Jan 24, 2007, 05:30 PM   #14
LAHeli Ricco Ninja
WOW uscd! That thing looks -fierce- in there with all that CF and your sweet sweet paintjob..
I'm jealous =]
If I sent you my canopy, would you do that for me? haha =]
-Kyle
Old Jan 24, 2007, 07:30 PM   #15
Rcer field rep.
Send a message via AIM to moosemanty Send a message via MSN to moosemanty Send a message via Yahoo to moosemanty
i am going to have these electronics (almost done buying these)
rc-tek 3500kv motor
DN 36a esc
3 hs65's
futaba 401
1 futaba 9650
berg 7p receiver
hitec eclipse 7 tx
2 aplus 20c 1700mah lipos (for now)
and for all of you that have the hs65 mg's, would you reccomend them over the hb's?
Tyler
moosemanty is offline Find More Posts by moosemanty   Reply With Quote
Yippee! IFO owners thread #1 jimklein Indoor and Micro Models 1639 Oct 22, 2009 10:00 AM
Alert Skyshark owners thread Chris Nicastro Scale Electric Planes 29 Sep 19, 2009 04:16 PM
36# owners' thread. J-ken Micro Helis 20 May 23, 2008 04:41 PM
Discussion Blade CP Owners Thread PiperLance Micro Helis 3281 Mar 19, 2006 09:01 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 10:02 PM
Bored? Want to fight?
Join the RCGroups clan!
