Old Mar 21, 2007, 04:47 PM
mysticplayer is offline
Find More Posts by mysticplayer
Joined Mar 2007
I am getting back into RC after many yrs out. Been a huge Futaba/Airtronics fan when I was power/glider flying.
Picked up a 4ch computer Futaba with micro S3108m servos. Very nice servos, fast, return to zero promptly and quiet. Lots of torque for my 3D Charger and Turmoil I was flying. No issues. Since they came with the radio and now discountinued, value is kind of silly.
However, at the reg. $14 price, if they still were for sale, I would rate their quality a 9, performance a 9 and their value a 8 (lower torque then S3110m).
Now I have been using the S3110m and see no real difference in function except they come rated at a higher torque. A really great servo which again is discontinued. At the $14 street price, I rate their quality 9.5, performance 9.5 and value 9.5.
Will likely get some S3114 if they are still around in a few days.
Like many many flyers, I also have a couple of HS55 servos. These I bought on sale for dirt cheap. They have run really well, like the S3108, until the last flight. Formosa coming out of a turn then doing an uncontrollable spiral into the ground. No problems, glitches for 3 flights prior.
Well within range of the Rx. All electronics functioning after the flight except one HS55 servo (aileron) is jammed solid. The only thing I can figure out is that coming out of the turn, the servo locked up/did not return to neutral causing the death spiral.
So before the crash, I was very favorable of this servo (Q-8, P-9, V-10). Now, very gun shy for a faster E-pattern plane. If I simply put the wrong servo into the application, then the issue is me. However, I have seen numerous reviews of similar planes that use this servo with zero problems.
Since this is likely an isolated case, I would not condemn the servo. But that is enough for me. Present rating is Q-3, P-3, V-3. I think the HS65 with stronger gears is the smarter option for this application but they are significantly more expensive then the S3110/3114.
For those that have not used the new Micro plug from Futaba, the concept is great. Very low weight but the plug is so small that handling (unplugging) is frustrating and if handled rough, likely break. For the extra few grams over all the servos in a plane, the reg J plug would be my recommendation.
Jerry
mysticplayer is offline Find More Posts by mysticplayer
Old Apr 21, 2007, 10:26 PM
Fishbone4u is offline
Find More Posts by Fishbone4u
Fishbone4u's Avatar
Irving, TX
Joined Apr 2006
Wow...excellent add to the site. Thanks.
Fishbone4u is offline Find More Posts by Fishbone4u
Old Apr 21, 2007, 11:07 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Not real impressed with the JR S241 servos that I have. Fragile gears and the centering doesn't seem to be very good. I bought then used so maybe they are just used-up. Probably wouldn't buy them again, especially not for nearly $30 each. I hate to put a rating on them since they were not new when I got them
village_idiot is offline Find More Posts by village_idiot
Old Apr 25, 2007, 11:01 AM
jrturbo is offline
Find More Posts by jrturbo
pigs will fly!!
Joined Jan 2007
Hi guys
I am using Robbe FS 60, for the tail surfaces of my condor voodo glider, they seem to work ok. they are smooth, centre well and quite powerfull for the size. I would rate them 8 out of 10
I also have a Robbe FS31 pico servo which I am going to use in the tail to drive the elevator on my sky sergio, its very thin 8mm only and light at 5.5 grams. cant comment on its operation as of yet
I have also bought a pack a 5 servo of the make E sky they seem to be roughly the same size as the robbe FS 60 but at half the price, currently untested, as the will be fitted to a Kyosho Soarus, which is waiting for me to build.
Regards
Joe Rubido
jrturbo is offline Find More Posts by jrturbo
Old Apr 25, 2007, 11:24 AM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Buddy of mine bought the JR S241 on recommendation from a die hard JR fan. Lasted less than one trip to the field. Stripped putting it in the truck and replacement stripped on the ground before takeoff with no impact to surface. Katana Mini elevator was the application. He uses E-Flite S75 and has had no issues yet.
Got my Tower 10 off 24.99 today and gonna order another HS-65.
edit 1 HS-65 Karbonite and 1 bottle of 6 min epoxy $21.97 to my door.
bildo baggins is offline Find More Posts by bildo baggins
Old Jul 24, 2007, 11:22 PM
rcboosted is offline
Find More Posts by rcboosted
Joined Sep 2006
I picked up 3 HXT900 servos from UH after reading favorable reviews here. I have to say, as a servo, I'm not all that impressed. They're fast, but 2 out of the 3 seems to have a dirty pot. Looking at the servo output shaft, on CW turns, it would not stop precisely when the stick stops. It would oscillate a bit. Like if my stick movement will make the servo go from 3o'clock to 4o'clock position, it would stop at 4:30, bounce back to 3:30, then stop at 3o'clock. On CCW turns, it would stop precisely most of the time. I've warrantied 2 HS65MG servos that behaved this way after hard crashes. These HXTs are brand new.
Since they're only $3 a piece, I don't know what to think. Yea it's cheap, but that oscilation could crash a plane in the air. Has no one experienced this problem before?
rcboosted is offline Find More Posts by rcboosted
Old Jul 25, 2007, 07:57 AM
chainlink is offline
Find More Posts by chainlink
Free State of Lavaca
Joined Nov 2006
I have some of the HXT servos, but am using them in fairly low demand applications. As such I am fairly happy with them. I will try to look at them more critically next time I power up.
I have had issues with Blue Arrow 3.3 gram. I lost 2 in a crash, so while I am frustrated, can not say that that was the servos fault (the servos worked fine till they were sheared in half).
Next plane was not so lucky as the pot came loose in the elevator servo. After several crashes caused by that servo, I finally diagnosed the problem (I saw the servo do a 180 and recenter pointing the opposite direction - that is something really neat on an elevator servo - having the servo reverse all on it's own). I ended up stealing the case and gears off of that servo and the electronics off of one of the sheared ones and had no more issues. FWIW I had read that loose pots were an issue with this servo, and probably should have tested it more thoroughly before installing it (and re-glued the pot if necessary).
The reason the servos were sheared was do to the way they were mounted (between a glassed wing and carbon fuse-they never stood a chance)- that was no fault of the servos. The elevator servo was new when it was installed, so it's excuses were mine for failing to test it properly.
chainlink is offline Find More Posts by chainlink
Old Jul 25, 2007, 09:10 AM
Inciting Riots
Joined Dec 2006
I have some Batan digital servos that I'll be trying very soon.
So far my Blue Arrow 3.6 servos are ok, no centering issues, we'll see what happens if I get a bad crash. These are in a Cox warbird at 4.8 ounces AUW.
Old Jun 17, 2008, 04:10 PM
PositivelyJoe is offline
Find More Posts by PositivelyJoe
add lightness
PositivelyJoe's Avatar
Big time Minneapolis, Good Ol' St Paul
Joined Oct 2007
Add the esky 8g EK2-0500.
1.3 torque
.12 speed
great servos especially for the price. about $5 each.
PositivelyJoe is offline Find More Posts by PositivelyJoe
Old May 31, 2009, 02:17 PM
RCFlyingKiwi is offline
Find More Posts by RCFlyingKiwi
RCFlyingKiwi's Avatar
New Zealand, Auckland, Manukau
Joined Jun 2008
Hi
I've used BMS 380Max (BB and metal gears) servos on a Hyperion Yak 55 25e for the passed year completing over 100 flights. The servos performed very well, I have not adjusted my subtrim since new. I'd give them a 9/10. The only issue is slack in the gearing or bearing, I have about 2mm of control surface movement now. I fly big air high speed F3A style moves so they get a workout on every flight.
Cheers.........
RCFlyingKiwi is offline Find More Posts by RCFlyingKiwi
Old Sep 05, 2009, 11:09 AM
4world is offline
Find More Posts by 4world
Joined Jul 2006
Would the original starter of this thread "Treker-1701" please post the latest updated spreadsheet file to this group? This would hopefully, consolidate all the ratings so far and be useful to everyone ... now that he has put in so much effort.
Thanks much
4world is offline Find More Posts by 4world
Old Jul 02, 2010, 11:07 AM
XrayZulu is offline
Find More Posts by XrayZulu
Germany
Joined Feb 2004
Spare motor source for BMS-306 / 308 / 306BB / 308BB servos
Strangely, two of my fairly new BMS-308BBs have developed a motor failure (siezed up, respectively, motor doesn't rotate at all even if removed from housing). The size is 7mm dia. x 12,2mm. The pinion is a pain to remove, so the spare motor should come with the original pinion. Haven't found anything via the search engines. Does someone know a source?
Similarly, one of my trusty GWS naro servos - running about 200hrs in an FP microheli over a period of 4 years and NO slop (as opposed to the highly-rated BMSses) jitters strongly around 0, i.e. a worn pot. Same sourcing question. Thanks to all.
XrayZulu is offline Find More Posts by XrayZulu
Discussion 9g (sub-micro) Servo Comparisons Treker-1701 Electric Plane Talk 75 Oct 20, 2008 06:35 AM
Jr Nes 241 Sub micro servo reznikvova Aircraft - Electric - Airplanes (FS/W) 0 Jun 16, 2003 07:33 PM
What is your sub-micro servo of choice? BING! Radios 2 Apr 08, 2003 12:02 AM
WTB Sub-Micro Servo(s) T-Bo Aircraft - Electric - Airplanes (FS/W) 12 Feb 21, 2003 02:50 PM
One Hitec HS-81 Sub Micro Servo New in Box!!! karl446 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2001 09:48 PM
