Old Jan 23, 2007, 05:34 PM
The L is offline
Find More Posts by The L
Joined Sep 2006
Reinforcing a GWS Formosa (aileron came off at ~70 mph)
I just had someone radar my Formosa. Previously I radared my Stryker out of a dive at 83 mph. (The dive was about 30 degrees from about 500 feet out.)
The same gun showed my Formosa going 64 mph out of about a 10 degree dive. I'm guessing it's going 55-60 mph level.
I have a JustGoFly 400DF with a 5.7x3 propeller on it.
Then I took my Formosa up to see how fast I could get it going out of a long, steep dive.
It looked like it was going slightly faster than it was when radared at 64 mph. All of a sudden I heard a snapping sort of noise and saw some foam flutter to the ground. I gave it slight up elevator. The elevator was still there. I gave it rudder. The rudder was still there. I gave it aileron, it banked, but just enough for me to see it was missing most of the left aileron. (I've still got about 2 square inches left.)
The plane still flew fine (but felt like it was on low rates with 100% exponential), so I came in for a landing.
Now I think I'm going to build another one, and really reinforce it.
How do you reinforce your planes? Should I try covering it? Glassing it? How do you glass planes?
The L is offline Find More Posts by The L
Old Jan 23, 2007, 05:36 PM
Keith43221 is offline
Find More Posts by Keith43221
Got H2? Fuel Cell R/C Car
Keith43221's Avatar
United States, TX, Del Rio
Joined Mar 2004
Glassing:
http://www.rcgroups.com/forums/showthread.php?t=176211
One of the many Formosa threads:
http://www.rcgroups.com/forums/showthread.php?t=235703
Hope this helps.
Keith43221 is offline Find More Posts by Keith43221
Old Jan 23, 2007, 09:37 PM
The L is offline
Joined Sep 2006
Thanks.
Old Jan 24, 2007, 02:46 AM
CSI is offline
CSI
Find More Posts by CSI
CSI
I promise, just ONE more order
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
L,
I have glassed several of my GWS planes and had ok results. While they are a bit stronger, a regular crash still caused significant damage.
I have since been using low temp iron on covering and there is no comparison. The airframe become like iron and the weight increase in minimal...less than my glassed planes. I'm not kidding, the iron on film becomes part of the foam and it is STRONG. No way to pull that baby apart. It takes a bit of time to get it all ironed down, but well worth it. Crash survivability went up 75%. Even the standard "finger dents" in the foam are hard to make. Like I said, takes time, but the foam is like iron. I have only used the $6.99 rolls of Tower Kote from Tower Hobbies. It is low temp covering.
That's just another suggestion to toss your way.
Ken
CSI is offline Find More Posts by CSI
Old Jan 24, 2007, 02:55 AM
The L is offline
Joined Sep 2006
Thanks.. I'll try iron on covering. I don't care about crash durability - I don't plan on crashing it if I've spent time covering it. As long as the control surfaces don't rip off in mid flight I'm happy.
Old Jan 24, 2007, 03:58 AM
perttime is online now
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Did your hinges break or come off?
What sort of hinges did you use?
Also, make sure your aileron linkage is solid, if you plan to fly fast. Or use separate servos, mounted in the wing.
perttime is online now Find More Posts by perttime
Old Jan 24, 2007, 04:08 AM
The L is offline
Joined Sep 2006
The hinges didn't break. The far left and middle hing pulled out of the wing. The right hinge pulled out of the aileron.
I used the stock hinges, which was probably a mistake. When I built the model I knew I was going to stick a real power system in it and not some underpowered junk that would barely get it to go 30 mph.
Old Jan 24, 2007, 04:40 AM
The L is offline
Joined Sep 2006
All right, what sort of iron do I need to order with that TowerKote film to cover my new Formosa? I'm ordering as soon as I figure out what I need.
Old Jan 24, 2007, 04:41 AM
The L is offline
Joined Sep 2006
I was just looking at that TowerKote stuff and it says the rolls are 6 inches by 26 inches? How do I cover a whole plane? Just use strips or squares of the stuff? Do seams form where it overlaps or does it just sort of "melt" together?
Edit: Also, about how many rolls will I need to cover my Formosa? From my guesstimates it looks like 7. A $30 airframe with $50 worth of covering and a $100 power system...
Edit again: Never mind. That's 6 feet by 26 inches. One roll ought to be good... lol
Old Jan 24, 2007, 04:51 AM
perttime's Avatar
Finland
Joined Nov 2004
Sounds like the hinges were not glued well enough. The stock hinge material is not that bad, although I am not flying my GWS birds fast.
You need an iron that has adjustable temperature. You do not want to melt the foam...
"6 inches by 26 inches" sounds very small, like some sort of trim material. I think something like 26 inches by 6 feet is more like it.
There was an article on covering a Formosa in Model Airplane News (not real recent) and the guy did the fuselage in two parts of film: left and right. Getting the foam smooth first seemed like the biggest job but he really knew how to handle the film and iron too.
Old Jan 24, 2007, 04:54 AM
The L is offline
Joined Sep 2006
Probably true. I used the stock GWS glue to attach them, which was probably a mistake.
Anyway, what iron do you use for covering?
Old Jan 24, 2007, 05:18 AM
perttime's Avatar
Finland
Joined Nov 2004
I do not remember what brand/model my iron is. Something like this:
http://www.atalarc.fi/kauppa/images/...olarille_b.jpg
In that MAN article the guy also had a really tiny iron for some tight angles.
...I have used GWS glue on my hinges too. It is a bit hard to get glue into the slots without making a mess...
Old Jan 24, 2007, 08:29 AM
CooHead is offline
Find More Posts by CooHead
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
Maybe it WAS the stock GWS glue? I have an over powered Foammosa and use the standard hinge material...but two part epoxy. I'm sure mine goes over 70MPH with 11x8.5 prop and 2025-4200 motor in a Cobri GB. No flutter issues.
I covered mine with leftover Solite. It's a real hack job. I just wanted to get it covered and not have to paint it because I don't like the raw foam look. Once I got it done I noticed how much stronger it made the plane.
I have a lot of experience covering laser cut kits, so this hack job didn't take to long and looks alright.
(this is the only pic I have of the SoLite covered Foamosa)
Coo
CooHead is offline Find More Posts by CooHead
Old Jan 24, 2007, 08:36 AM
CooHead is offline
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
I guess I could take a couple more pics of just the plane.
CooHead
Old Jan 24, 2007, 10:03 AM
rcboatnut is offline
Find More Posts by rcboatnut
Are you one of these
rcboatnut's Avatar
loveland colorado
Joined Nov 2003
I use Dubro hinges and a mix of polyurethane glue and white glue it expands to fill the voids in the slot in the foam you cut to put the hinges in and is very sticky and bonds well to the foam you could also drill a whole perpendicular in the wing to the hinge and put a carbon rod through the wing and hinge to lock it in. Just a thought
rcboatnut is offline Find More Posts by rcboatnut
Discussion GWS Formosa II in stock at Tower - photos Turbo442 Parkflyers 0 Dec 31, 2005 06:20 AM
OLD STYLE PJS OUTRUNNERS 70% off at Hobby Lobby! Daniel11 Power Systems 25 Nov 27, 2004 11:07 PM
Prop came off at 100 feet, what happened? Mopar92 Parkflyers 8 Apr 20, 2004 02:42 AM
GWS Formosa - good aileron trainer. jgmtens Parkflyers 11 Nov 19, 2003 10:38 AM
GWS 300C Negative lead came off?? BrunswickOH Power Systems 12 Oct 21, 2003 12:48 AM
