Old Sep 24, 2002, 10:45 AM
The Other Dave is offline
Find More Posts by The Other Dave
The Other Dave's Avatar
Colorado Front Range, USA, EARTH, Sol system, Milkyway Galaxy
Joined Nov 2001
Question on trimming out Hobby Lobby Skimmer 400
I have 8 flights on my Skimmer 400 and I have some trim
questions.
Pics of plane in this thread
http://www.rcgroups.com/forums/showt...threadid=62453
My setup is
Zagi speed 400 w/ 6x3 prop
8x1100 Hecell NIMH
2x hs81 metal gears
hitec 555
1/4 inch washout
AUW 20.5 oz
CG dead on 2.25 inches from leading edge.
I have the recomended amount of downthrust.
Overall I am very happy with it's flight characteristics. I have had
multiple 20+ minute flights w/ 5 flights to altitude (4 minutes of run time total). All of my flights have been in early morning (before 9 AM) so low/no thermals.
Here is the questions.
Under power with what I would call neutral trim (tail feathers
inline with elevator) it wants to pitch up to stall. With some downtrim this problem goes away. But should it be neutral.
During glide I also need some downtrim to avoid porpoising (sp?).
It will slowly pitch up approach stall, nose comes down and it will
accelerate.
Is this a CG problem or possibly an angle of incidence issue.
As I said everything is to the plan.
Dave
The Other Dave is offline Find More Posts by The Other Dave
Old Sep 24, 2002, 11:31 AM
Dan H. is offline
Find More Posts by Dan H.
Crashez-vous sans stress!
Dan H.'s Avatar
Chicago
Joined Nov 2001
Try shimming up the trailing edge of the wing in 1/8th inch increments. You may also benefit from moving the CG back, also in small increments (don't try both modifications at the same time until you have an idea of what they do for you separately). Good luck and have fun!
Dan H. is offline Find More Posts by Dan H.
Old Sep 24, 2002, 01:06 PM
WarrenKriesel is offline
Find More Posts by WarrenKriesel
Athens, Ga, USA
Joined Jan 2001
My skimmer does the same thing. Our club "expert" advised me to learn to change the elevator trim when transitioning from power to glide. Example: from a flat glide, going to full throttle requires 20% more down trim. It has become automtic for me to do this now. I think that this continous monitoring of the trim conditions has also improved my flying technique with the more advanced sailplanes (six servos) I've progressed to in the last 2 years.
Warren
WarrenKriesel is offline Find More Posts by WarrenKriesel
Article The Hobby Lobby Skimmer 400 jbourke Electric Plane Talk 8 Mar 16, 2013 11:55 PM
Discussion Hobby Lobby Skimmer 400 current draw info... w0ace Electric Sailplanes 1 May 29, 2006 06:18 AM
Thinking about adding wing tip extensions to Hobby Lobby skimmer 400 The Other Dave Electric Sailplanes 4 Aug 03, 2003 07:20 PM
for sale Hobby Lobby skimmer 400 pval3 Aircraft - Electric - Airplanes (FS/W) 2 Jul 27, 2003 02:10 PM
Will an 8x800ar bat pack fit in a Hobby lobby skimmer 400. The Other Dave Electric Sailplanes 11 Oct 18, 2002 10:25 PM
