Old Feb 25, 2007, 05:50 PM
FlyNow,LandLater is offline
Find More Posts by FlyNow,LandLater
Miami, Florida
Joined Nov 2006
Madsci Guy- no way for 1/2A Pacer.... look great model but too fast.... same model um the birdie 10-15 by Global. I been thinking about the Pacer. will see about that this year or so. (thinking) upgrade the pico or mini retract on it that will be looking GGOODD. Later.....
Steve.
FlyNow,LandLater is offline Find More Posts by FlyNow,LandLater
Old Feb 26, 2007, 07:15 AM
Miami, Florida
Joined Nov 2006
1/2A Airplane Trainer
here,,,, name that r/c plane? THANKS.....
Old Feb 26, 2007, 08:29 AM
madsci_guy is offline
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
That's a 1/2A SST, alrighty.
madsci_guy is offline Find More Posts by madsci_guy
Old Feb 26, 2007, 08:40 AM
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
Steve.
Pacers, too fast? I never found them to be so, but then again, I flew Chuck'rs and GLH's too. Compared to a 1/2A Shrike, they were very slow.
My personal opinion, I wouldn't stick retracts or anything extra on a Mach None or Pacer, or similar 1/2A plane. When they were at 11 oz or so they flew like a dream. If the thing was heavy, it would be too fast, maybe. The instructions talked about people putting a .15 on the Pacer, but then they said it was more like model rocketry, and recommended against it.
You're right, the 1/2A Birdy is pretty close to a Pacer. Very pretty lines, being a scale model of a Bridi Dirty Birdy, one of the best RC plans ever designed.
Old Mar 05, 2008, 09:09 PM
Andrew0820 is offline
Find More Posts by Andrew0820
Western KY
Joined Sep 2003
That's a great looking plane, Steve. Did you use the foam wing with capstrips or do a built up wing?
Looks like you have a super place to fly -- quite wide open.
andrew
Andrew0820 is offline Find More Posts by Andrew0820
Old Mar 05, 2008, 09:47 PM
Steve Benesh is offline
Find More Posts by Steve Benesh
Steve Benesh
Oshkosh, WI
Joined Nov 2004
Built right from what Hobby Shack put in the box - foam wing with cap strips. I have one wing kit left so I can build one more of these planes someday. If you want to build one, the plans are still available from RCM. Once you get the plans, you can make a template of the rib, send it to the AMA and they have a service that will cut you a set of foam cores. It's a fairly easy plane to build. I did change mine from the rubber band set-up for wing attachment to a more conventional small nylon bolt.
Our club (http://www.wrcf.rchomepage.com/) has a nice field just southwest of town. We rent about 5 acres from an antique steam & gas engine club that purchased a 40 acre farm for their use. There is only one problem with that field - a very large "plane eating oak tree" straigh out from the pits and right in-line with the downwind leg of the main runway. See picture of it after a meal of Piper Cub.
Steve
Steve Benesh is offline Find More Posts by Steve Benesh
Old Mar 05, 2008, 10:43 PM
Western KY
Joined Sep 2003
Originally Posted by Steve Benesh
<snip>...If you want to build one, the plans are still available from RCM. Once you get the plans, you can make a template of the rib, send it to the AMA and they have a service that will cut you a set of foam cores. ...<snip>....See picture of it after a meal of Piper Cub.
Steve
Thanks. I've had a plan set for quite some time, but it's always good to remind folks that the RCM plans service is still operational. The site is www.rcmmagazine.com . I built my own foam cutter, but didn't know that the AMA had a cutting service -- that's good info.
One of the first things I usually do with a new set of plans is cut templates from formica, both for cores and for cutting ribs -- gives me the option of both builds.
Those plane eating trees crop up everywhere. Many years ago I was flying a .020 powered freeflight in an 80 acre field on the farm -- there was one tall tree in a fencerow -- need I say more.
Old Jun 13, 2010, 08:00 PM
Mooney_Driver is offline
Find More Posts by Mooney_Driver
Mooney_Driver's Avatar
United States, WA, Benton City
Joined Mar 2004
i have a SureFlite Baby Turkey that I bought from Hobby Shack in the late 70's and started building. The instructions said to use contact cement on the wings for the balsa sheeting. I used 3M contact cement from the hardware store and watched the wing melt! That is how the kit has stayed for decades. I do keep an eye out for a built up wing to use instead but have not found one.
Can anyone tell me if the 1/2A SST from RCM (and Hobby Shack) was the same plane as the Sureflite Baby Turkey? They look the same and the plans or instruction sheet sure looks similar.
Thank you.
Originally Posted by madsci_guy View Post
I think the Sure Flite cores are an exact replacement for the SST cores, aren't they? Sure Flite was a Hobby Shack brand, if memory serves.
Build one under 14 oz and they fly super. Stay away from 22 oz.
1/2A plans
http://my.pclink.com/~dfritzke/
Mooney_Driver is offline Find More Posts by Mooney_Driver
Old Jun 13, 2010, 08:31 PM
Western KY
Joined Sep 2003
M_D
Check with Steve Adams at Select Hobbies. ACE constant chord wings are located at the bottom of the link. He usually keeps several sets on hand. The ACE wing should work for your SST.
andrew
Old Aug 28, 2012, 03:39 AM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
Stevo go here
http://www.rcgroups.com/forums/showthread.php?t=1566354
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Sep 30, 2014, 04:11 PM
Condor84 is offline
Find More Posts by Condor84
Condor84's Avatar
United States, FL, Hastings
Joined May 2013
I know this is the second time I've dragged up an ancient thread today, but I just needed to share. I built my 1/2a SST when I was around 9 or 10 years old, but it never flew. I used standard Futaba gear and a black widow .049 back then, but I just could never get it airborne. It was also the first R/C plane I had ever built. So, when I moved to Florida this summer, I came across it's old battered airframe. I had a motor meant for a quadcopter lying around that spins a 10X4.5, and a roll of orange Econokote, so I went at rehabbing it and seeing if I could get it to fly. I completely recovered it and fixed several things I had done wrong as a young kid, and even detailed the motor to sort of look similar to the original black widow it had up front, with a diesel twist. It almost fools people at ten feet (ok, maybe 20). I also added two aileron servos internally, utilizing the original torque rods (sort of how I did it on my Cosmic Wind). I did leave the vertical stab covered in the original red, just as a homage to my past. Well, I brought it down to the local park, and I'll be damned that it flew after building it and then failing 20 years ago. Man, was I excited. I've flown plenty of airplanes since building that first one, but getting that first failure to fly was more of a rush than any Spitfire or racing plane I've flown since. For some specs, the motor is an Emax 2213 Multicopter motor spinning a 10X4.5, 30amp Mystery ESC, on either a 1300 or 2200 3S Lipo. Requires 1/2 to full to keep it airborne, so I'll eventually swap it out for something a little more matched. But for now, it flies just fine. Even with this setup, the motor and ESC are always cool to the touch after. So, here's some pics to add to the thread. On a side note, setting it up with both Flaperons and Spoilerons was worth the extra little bit of weight. It can either land in a VERY VERY short spot, or fly almost at a walk.
Condor84 is offline Find More Posts by Condor84
Old Sep 30, 2014, 04:48 PM
Western KY
Joined Sep 2003
Condor84 --
Good for you. Looks like you've got a nice flying plane --- especially for a restoration. Seeing something fly after so many years is bound to be satisfying. Thanks for sharing.
andrew
Old Sep 30, 2014, 06:42 PM
PGregory is online now
Find More Posts by PGregory
Now I have to land that thing?
PGregory's Avatar
United States, NY, Poughkeepsie
Joined Apr 2014
I think this is great. Kind of no reason to abandon a thread, and you'll find some of the earlier contributors will voice up. You have me considering the SST build - I have stockpiled some engines lately so quite a few to pick from.
In a perfect world I would build at least three of everything - one in glow, one in diesel, and one in electric.
See if you can get some video - that is a nice looking plane. Super that you kept the rudder covered as original - cool.
PGregory is online now Find More Posts by PGregory
Old Sep 30, 2014, 10:13 PM
~SnApRoLl is offline
Find More Posts by ~SnApRoLl
Team Fearless
~SnApRoLl's Avatar
United States, MD, Piney Point
Joined Mar 2005
Originally Posted by FlyNow,LandLater View Post
madsci guy, Thanks for help and found the RCM's plans, been looking for Foam Wing by ACE. No more ACE Foam Wing Kit. Ace high MK II-out of production. I will keep looking.
thanks again madsci guy......
FNLL.
I know this is re-hashed page but Don't order from RCM!!! They have ripping people off for the last couple of years by taking money and not delivering plans!! Do a search here in RCG on RCM plans and you'll find some interesting posts.
Shawn
~SnApRoLl is offline Find More Posts by ~SnApRoLl
Discussion Looking for a 1/3 scale Axel pilot or maybe do a group buy? GNX430 Scale Sailplanes 5 Apr 16, 2007 06:55 PM
Wanted looking for 1/2A SST FlyNow,LandLater Aircraft - Fuel - Airplanes (FS/W) 5 Jan 28, 2007 01:39 AM
Discussion Aerobatic/Fun-Fly or Pattern plans for 1/2A? FlattyFlier 1/2A Planes 34 Jan 15, 2007 05:12 PM
Question Free 1/2A plans & prices for 1/2A engines? t_predator90 1/2A Planes 4 Dec 14, 2003 05:59 PM
looking for 1/2A norvels Jboy381 Aircraft - Fuel - Airplanes (FS/W) 15 Jun 17, 2003 06:13 PM
