Old Jan 20, 2007, 11:43 AM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Idea
Per Dick Kline, Kline-Fogleman test
While speaking on several occasions to Dick Kline he said that I could actually gain more lift with the step on the top of the airfoil. being intrigued by The size of the nano glider, It just give me ideas to test the KF.
kline also referred me to a Mr. Dick Wood, that has done some wind tunnel testing with this airfoil and he has also offered me some additional advise.
I love foam and this give me a break from the Cumulonimbus wing I am building. This is instant gratification.
The thought behind this is to make a simple glider, and simply balance it to glide, with no step at all, purely a 3mm depron wing with one strip of CF.
Then I will cut the steps of the yellow templates out of 3mm depron, not proportioned at the tip, and double side sticky tape them on to see what I gain, documenting between each step. Starting at the Leading edge.
If anybody has any questions please comment.
Once I have achieved the best glide I will upsize it 3 to 5% and then add gear.
I am shooting for about 2 ounces with no gear balanced.
doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Jan 20, 2007, 02:13 PM
Glendale,Az.
ok, test planform weighs in at 1 ounce......
first video will not have a step installed
flat plate 3mm wing
Step configuration from leading edge
from leading edge
25%
37.5%
50%
62.5%
75%
doug, video of flat plat wing gliding next post
Old Jan 20, 2007, 03:43 PM
Glendale,Az.
test one video, No step, no gear, test glide
video here:
http://www.rcgroups.com/forums/showt...44#post6769213
more to come
steps are made,
time for attachment
doug
Old Jan 20, 2007, 03:59 PM
Glendale,Az.
the 5 steps cut
weight of wing and fuse with first step glued on leading edge and shaped.
1.1 ounces
Old Jan 20, 2007, 04:12 PM
alk509 is offline
Find More Posts by alk509
Somerville, MA
Joined Aug 2002
Watching with interest...
Best,
Al.
alk509 is offline Find More Posts by alk509
Old Jan 20, 2007, 05:03 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
That's a beautiful planform for a test - also watching. . .
ajroahkni is offline Find More Posts by ajroahkni
Old Jan 20, 2007, 05:43 PM
Glendale,Az.
test 2
Thanks guys, that is inspirational.
video here:
http://www.rcgroups.com/forums/showt...08#post6769773
auw so far is 1.2ounces.
I added a wing mount consisting of two pieces of 1/16th balsa sandwhiching the 2 balsa inserts for some screws to hold the wing on.
Videos are hard by yourself.
Gained 10-12 feet with first step, the next ones will be double sided tape attached., I might have to move to the front yard.
Doug
Old Jan 20, 2007, 06:15 PM
weather_man is offline
Find More Posts by weather_man
semper ventosus
weather_man's Avatar
Sasebo, Japan
Joined Jun 2004
Wow, great job on the test glides.
weather_man is offline Find More Posts by weather_man
Old Jan 20, 2007, 06:21 PM
Glendale,Az.
Misting the steps for Reference
Thanks WM-
Just lite mist painted the steps for reference, will post when paint dries
This is the paint code
Step one,Leading edge- Orange 25%
Step Two, Black 37.5%
Step three, Yellow 50%
Step four, Green 62.5 %
Step Five for thrust- Red 75%
Picture soon
Kind of ugly for testing,but the final flying version will have a single color paint scheme
Doug
Old Jan 20, 2007, 07:37 PM
semper ventosus
Sasebo, Japan
Joined Jun 2004
Sorry if it's a stupid question, but do the steps have to be sanded to blend?
Old Jan 20, 2007, 07:46 PM
Glendale,Az.
90 degree step
WM- no the rear step does not have to be sanded. My first KF airfoil I made I tapered the back of the step 45 degrees. Dick Kline told me that there is more lift produced with a 90 degree step to the wing.
Then he told me the wind tunnel resulted in even more lift if the step is on top.
I was worried about looks, aesthetically- but test glides are getting better with each step.
I did sand the leading edge to create less drag.
This drawing represents the steps as I am testing. The double sided tape seems to be holding well, I had the black step tonight added on and it went the full legth of my back yard to the brick.
More video when ther is sunlight.
Doug
Old Jan 20, 2007, 09:26 PM
Crashaholic is offline
Find More Posts by Crashaholic
trying to kick the habit
United States, CA
Joined Mar 2006
Ditto. Guess I should have said that when I subscribed Very interesting Doug.
Crashaholic is offline Find More Posts by Crashaholic
Old Jan 20, 2007, 09:31 PM
United States, CA
Joined Mar 2006
Bite your tongue. To me, some of the "prettiest" things in the world are pretty darn ugly
Old Jan 21, 2007, 12:23 AM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
It's always fun to run tests, but wouldn't it be pretty simple to model the airfoil in Profili and see what the results may be?
But hat's off to you, for being motivated to do the tests.
GaryO is offline Find More Posts by GaryO
Old Jan 21, 2007, 02:36 AM
Glendale,Az.
GaryO, I only have an old version of Profili. I wasn't aware you could make your own airfoil in Profili and test it.
By wanting to test this airfoil, it gave me my lightest glider yet, and pleasantly I believe with some good looks that I will be scaling up a little.
If I sit in front of this computer figuring out what would work and not work in a really nice program like Profili, I would of never been where I am at today with builds and new designs.
If somebody wants to do that test, I would love to hear how it works.
Thanks, Doug
Idea 40" Depron Dynamite, Kline fogleman Depron build dougmontgomery Hand Launch 686 May 15, 2016 04:50 PM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 09:08 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 07:37 PM
Idea 50 WS Kline Fogleman bagged(Depron) dougmontgomery Foamies (Scratchbuilt) 0 Apr 10, 2007 07:42 AM
Discussion Kline-Fogleman Airfoil on a flying wing Tony65x55 Modeling Science 1 Aug 20, 2006 11:14 AM
