Old Feb 16, 2007, 06:22 PM
mharms is offline
Find More Posts by mharms
Realtired User
mharms's Avatar
San Jose, California
Dave,
Need a litle more info to help you.
You mean the "hinge acts" that have a thin PCB attached to the coil and another attached to the magnet, with tape hinges between the PCBs?
Which Plantraco RX? The "Butterfly" RX (5mm spaced battery magnets) or the larger 0.9g RX (10mm spaced magnets)?
The Butterfly RX has no FETs to drive low-ohm actuator loads, the 0.9g RX does.
The hinge acts are about 150 ohm each (suitable for the Butterfly RX), the "remote" acts (with pivoting magnet and pushrod arm) are near 50 ohms (suitable for the 0.9g RX).
Mark
mharms is offline Find More Posts by mharms
Old Feb 16, 2007, 11:49 PM
Dave Lofthouse is offline
Find More Posts by Dave Lofthouse
United States, CA, Riverside
Joined Feb 2003
Details
Okay I am home now and able to give more details.
I have the .9gm 3 channel hfx900 system.
The hinge acts that I hope to use are the 150 ohm (I just measured them) BIRD type.
I am going to try these even though they may be a bit light. Since I am going with true EDF power using only 6mm motors I need to go as absolutely light as possible.
So which way do you figure I can wire these up? Series or parallel?
Thanks in advance for your help fellows.
Dave Lofthouse is offline Find More Posts by Dave Lofthouse
Old Feb 16, 2007, 11:57 PM
skychaser53 is online now
Find More Posts by skychaser53
Cardington,Ohio
Joined Nov 2006
If you put them in parallel, your resistance will then be 75 ohms. (R1 xR2) divided by (R1 plus R2). its easy when both r's are the same; just divide by 2 .
will that burn up your RX ? Maybe someone can tell you the minimum resistance for that Rx
skychaser53 is online now Find More Posts by skychaser53
Old Feb 17, 2007, 12:35 AM
mharms is offline
Realtired User
mharms's Avatar
The 0.9g 3chan RX handles 50 ohm actuators, no problem. So a 75 ohm load (hinge acts in parallel) is fine.
6mm EDFs? Cool.
Mark
Old Feb 17, 2007, 02:41 PM
Joined Feb 2003
Okay very helpful. Now I am going to assume that a parallel set up is more powerful than series.......right? I will plan to post a pic of the project here when finished.
Thanks again.
Old Feb 17, 2007, 03:02 PM
mharms is offline
Realtired User
mharms's Avatar
Each act will receive the same current that it would receive if there was only one act. So, individually, they won't be more powerful. Its just that the RX can deliver the total current to drive both. You'll still have relatively low torque from those hinge acts. Keep the size of the control surfaces reasonable.
If your plane will be flying fast, it might be hard for the hinge acts to overcome the force of the wind flowing over the surfaces. About how big is your plane and how heavy, overall?
Mark
Old Feb 17, 2007, 05:49 PM
Joined Feb 2003
Yes, I am concerned about that. My weight goal is 27 gm maximum, wing area 180 sq. cm. I have little experience building with foam (more of a stick and tissue guy). Most of the plane will be built from 1.3 mm depron. I am going way lighter than my head tells me I should on all the building steps. If I can come in a lot lighter than 27 gm- all the better. However, a slightly higher wing loading may not be such a bad thing since the EDF's require a certain amount of ram air pressure in order to reach maximum efficiency. Of course, the increased speed requires more torque from the act. The age old balancing act of modeling. I will go very conservative with the size of the rudders until I see how it performs in the air.
OK, I've made up my mind, it's going to be a Bandit. So where do I find one ?. William A Electric Sailplanes 13 Oct 26, 2002 09:09 AM
Yippee! So where are you guys!!?? FIN FLYER Bergen County Silent Fliers 1 Sep 09, 2002 02:28 PM
It's "Late Jun" so where are the endos? :) mkirsch1 Sport Planes 3 Jun 25, 2002 03:19 PM
would you pay for an actuator winding service??? Paul Penney Scratchbuilt Indoor and Micro Models 36 Jan 23, 2002 03:57 PM
So where can I find a review of the Logo 10? HankF Electric Heli Talk 2 Jan 09, 2002 08:34 PM
