| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
uscra122,
I use hardware store parts in most cases. If you find a plotter, you can use it to draw the parts on the balsa. Then you can cut them out. A plotter has problems just moving the pen!DXF files can be printed to a plotter as a PLT file. Most of the Windows versions won't let plotters work. This is why I combined CNC machines and Plotters in my designs. There are lots of ideas kicking around. I am at the point now I can start helping people. I got in over my head there for awhile. Those 16 hour days are killers! I spent seven days a week for two years designing machine. I didn't even know if there was a market. I liked RC when I was active. I figured there must be a few soles out there. I got laughed at by the Bridgeport guys. I hear Bridgeport closed up! Maybe they should have produced simple machines to cut out RC parts. Cranky |
#47 |
Administrator
Cranky,
I'm glad to see you here! I enjoyed browsing your website a couple of weeks ago. This thread is really interesting because I've been looking into making my own CNC machine for a couple of weeks now. I created "The Workshop" forum to give me a place to post some threads on my experience. Coincidentally, I was planning to contact you and Zoltar and a few others to see if you guys would be intersted in talking about CNC in this new forum. In fact, I'll just move this thread to get things started. This is a really exciting new direction for me in the hobby. I can't wait to get my first CNC machine set-up. Jim |
#48 |
It's just PLANE silly!
Cranky,
I have a question. Will the 50 oz. steppers be sufficient to cut heavier woods than balsa? I may want to cut mdf, etc. in the future and only want to build once. I have seen 80 and 100 oz motors out there. Should i splurge on the heavier drive board and larger motors or is it not necessary. I plan on using a rotozip or small router for the cut motor. I don't want to cut at 2-3 inches per minute. Eric www.e-zflight.com |
#49 | |
If I had it to do over (and I may just do it again!) I'd use your plans. Mine has trouble with the X/Y table moving up & down at the limits of travel causing cutting depth inaccuracies. Yours is much simpler and more rigid. I shouldn't complain about Dan's design though since his was designed to be a CNC circuit board driller where Z-axis depth accuracy wasn't that important and I chose to run a router with it. It does great for 2 1/2D stuff in balsa and ply.I would like to do another one with maybe 24" to 36" X travel, more Z accuracy, learn 3D CAD and toolpaths so I can rough out plugs for wings & fuselages....then a 4 axis foam cutter....a medium size CNC mill.....oops!....I wouldn't have time to build any airplanes!
#50 |
Cranky -
Just as I guessed - plotters can barely get out of their own way. And Windows plotter-drivers are all keyed to the applications they sevice, not to plain old ASCII files like DOS drivers were. What with the software now on the Web for a couple'a Benjis that'll run G-codes, you hardly need to fuss with using plotter software anyway. Have you had results using plain old threaded rod for leadscrews? For the accuracy we need, that should work fine, and they'd be so cheap that if they wear out you just replace 'em. Y'know, what we need is somebody testing and reporting on kits that have the stepper motors, controllers, cabling, and software all bundled for us to install on a structure we built ourselves. There's any number of vendors on the Web, but who knows who's got the right goods at the right price, and who doesn't? I mean, I was IN the machine tool business for years, but I myself am in the dark about these vendors. A nice website doesn't guarantee the goods. jbourke - I think you might be heading in that direction, yes? |
#51 |
Balsaman,
50oz motors into a 1/4-20 threaded rod gives you 100 to 250 pounds of force. Torq goes down the faster you run the motor. I would rather own a whole machine than just a great motor system. With all hobbies, you should work your way up. That's how you learn. A friend of mine built a $800 RC plane rather than buy a trainer. He was afraid to fly it! The last I heard it was locked in the trunk of an old car in his garage. He kid got a hold of the plane. Now parts are missing. People don't like starting on the bottom. The funny thing is you pickup so much more. Sometimes you even come up with a new idea! Hey! is anyone using a flatbed printer to print layouts right on the balsa? and is there a synthetic material that replaces balsa. Some kind of plastic? Cranky |
#52 |
jbourke -
If you're going to "move this thread" - how do I make sure I can still find it? Gottsta run - back on Monday. |
#53 |
uscra112,
HobbyCNC has complete motor systems cheap. I bought my first motors there. Lots of stuff on Ebay. I warn people about spinning the motors first. Just like RC, once you spin the motor, the building seems to stop. Motors are the easy part! Cranky |
#54 |
Dickeybird,
Even if your machine is not perfect, I bet you learned alot! I stayed away from drawslides. Lots of people mention them. I went with roller blade bearings. They have dust caps and you can buy them at most sports stores. I bought the $32 ones then I bought the $16 ones. The cheaper ones are just as good. Rollerblade bearings are made to be around dust. My machines also use the guide and way methods like a milling machine uses. These are also easy to keep clean. Threaded rod works great with a nylon,Delrin,Plastic or a nut made out of a chunk of white plastic (UMB?)cutting board. Cranky |
#55 |
Hi,
If we move let me know.....I tend to talk to myself as it is! Cranky |
#56 |
Cranky,
Thanks for all the help! I am using 1/2"-10 acme threaded rod. If you say 20 pitch = 100 lbs, then my 10 pitch should be around 50 lbs. That's quite a bit. I think I will get this kit from stepperworld.com then: http://209.41.165.153/stepper/sp3HT.htm with the FET3 upgrade for more current. Or should I forget the upgrade? the sp3 is good for 1.25 a per phase. Or do you recomend the 83 oz system from hobbycnc.com? Way to many choices. Lots of guys use fanfold foam as a substitute for balsa these days. Have a look at the foamies section. Also coroplast, which is a tough coragated plastic. Eric www.e-zflight.com |
#57 | |
Next machine will definitely have roller blade brgs. as you suggest but for now, I'm cutting some good parts to go in my planes. |
#58 |
Balsaman,
Alway check with the guys you are buying from. Then if there is a problem you can get your money back. Both Dave and Russ are honest guys. 1/2-10 rod, sounds like over kill for cutting balsa. I have no experence with threaded rod that thick or the torq needed to move the threaded rod. I hope you are going to be cutting other things. The reason I use 1/4-20 rod is. It's cheap, you can find cheap qualty rod and replace it later with better. It gives you lots of power using small motors. And the payoff of being able to tap and make your own drive nuts. There is almost no backlash at all when you use a 1/2' thick pice of nylon-Delrin or cutting block. As the thread gets coarser the nut can get sloppier. Then you have to spring for antibacklash nuts Do you own a 1/2-10 tap? Cranky |
#59 |
DickeyBird,
I used the free version of Turbocad from the internet. I then found a version of it for $29 at Staples. So I bought it. I use an old version of Kcam to convert to GCode. Converts the DXF to GCode. Lets me see where my part is going to be based on the size of the bed. I can also do offsets in KCam. There is also a Find and Replace. I use this when moving a GCode to a new machine. The new version of Kcam stops working after 30 days. What cutting bits do you use? I use four flute 1/32 ToughCarb. Cranky |
#60 | |
| Thread Tools | |
| Looking for CNC Mill Part II | Steve McBride | The Builders Workshop | 375 | Feb 14, 2009 11:49 PM |
| Looking for CNC router table | FHHOBBIES | The Builders Workshop | 13 | Jul 19, 2005 09:39 AM |
| Looking for CNC Mill - thread relocated | Andy W | The Builders Workshop | 0 | Feb 02, 2005 04:02 PM |
| Looking for a helicopter spare part | David Rodriguez | rec.models.rc.helicopter | 1 | Jan 18, 2004 07:02 PM |
| Looking for a CNC 4 AXIS FOAM CUTTER | A.D. | Power Systems | 3 | Nov 13, 2001 03:44 PM |
