Go Back   RC Groups > Aircraft - General > The Builders Workshop
Closed Thread Post New Thread  Previous Thread Next Thread
Old Oct 10, 2002, 05:08 PM   #31
Balsaman - that's good stuff, alright! Great that you have such a source. Those will be PLENTY stiff enuf ! The bearing you posted the picture of is worth $200-400 buckadingdongs, new, never mind the rails!
I used to have the same access to leftovers at my last job, but now I work for a CMM company (Zeiss) and they're all air bearings and band drives . . .
Happy trails - there's gonna be two good hours of flying weather tonight, so work has had me for today.....
uscra112 is offline Find More Posts by uscra112
Old Oct 10, 2002, 07:43 PM   #32
I'm really gonna reach here with this one, but why hasn't anyone checked out the H2O, pressure cutters? The foam will get wet, but it won't hurt it{it'll dry out}. No worn tooling to replace or resharpen...cuts as fine as a thin stream of high pressure water can, and water is cheap. I've seen these set ups cut thru high grade{5000/6000 series aluminum} that's a 1/4" thick and it'll leave an edge sharp enough to shave off of...nearly. Question is just how much psi will it take to make a clean consistant cut thru roughly 2" of OC pink foam. I'm not even going into lasers. Next question is how would cutting wood be with this...if a fine enough stream could be shot and done quickly at that, there shouldn't be too much of a warpage problem...I'm thinkin.
Scratchbuilder is offline Find More Posts by Scratchbuilder
Old Oct 10, 2002, 07:53 PM   #33
It's just PLANE silly!
balsaman's Avatar
I haven't looked into this. I personally am concentrating on making one that cuts....period. If I am successful, It's a matter of replacing the dremel tool with???? For me, making the x, y, z, table work is enough challange for the time being.
Eric
www.e-zflight.com
balsaman is offline Find More Posts by balsaman
Old Oct 10, 2002, 11:55 PM   #34
PanzyPoof's Avatar
WaterPick from Hell
I was show one of these machines @ Steen Aerolab
Home of the SkyBolt (My Baby's in the Garage)
And it was huge! Used to cut metal 4130 into fittings. Hmmm I used a hacksaw.
The Nossel is the size of a Hair and Huge $$K .
Water filter system anouther major problem. And the Noise is real Bad. If I recall a fine median is injected into the jet a few mm from the tip. Where it accelerates to the speed of sound
in about 7mm. Ya Nuts.
Nice desired Cut since the surrounding metal is not hardened as with Laser. Big Job keeping it operational.
For my Cutting damm close is good enough for now
Pass 220 paper once Done I'm shure later on I'll
learn more see and build a nicer machine. As we all would like.
PanzyPoof is offline Find More Posts by PanzyPoof
Old Oct 11, 2002, 02:05 AM   #35
Zoltar's Avatar
-------Air pressure !-------
The Dremel or similar is good for a start in this CNC hobby.
As a replacement for electric tools I've been looking for air pressure - hand- tools.
Its used mostly in car bodyshops and they run on pressed air.
and are build rigid, take up larger tools too.
These tools sell at 30 to 40 Euro overhere.
The only disadvantage is the sound and you need a compressor.
BTW-- Balsaman love your guide-balbearing roller guide system I guess you've got it sorted for a durable machine !
regards,
Chris
Zoltar is offline Find More Posts by Zoltar
Old Oct 11, 2002, 02:13 AM   #36
PanzyPoof's Avatar
Picked up some more parts. Easy to find just running around to get em.
  • Name: alum frame.jpg
Old Oct 11, 2002, 02:15 AM   #37
PanzyPoof's Avatar
Here is a Skate BB end .It's very smooth
  • Name: simple skate end.jpg
Old Oct 11, 2002, 08:37 AM   #38
Yah, PanzyPoof is right. I once researched these with a thought toward adding one to the aerospace machining facility I was tooling up. It takes something like 50,000 PSI to make them work, so the pump is enormous and costs $100K. The jet doesn't HAVE to have an abrasive in it. For soft materials like wood you use plain water, but it has to be very clean. The jet is very dangerous. After it goes thru the thing you're cutting it's still good for taking off an arm at the elbow. But y9ou'd be surprised where you find these in use. They cut up chickens with them. Clothing manufacturers use them to cut fabric 50-100 layers at a time. Plastic moulders use them for sprue cutting and flash trimming. But for us? Forget it.
Old Oct 12, 2002, 11:10 AM   #39
Hi Gang,
I am 50 years old! I used to make gliders back in the
days when there were rudder only rigs. My hobby these days is
CNC. I design and sell plans for dirt cheap CNC machines. I have two machines that I recommend for cutting model plane parts. The
7th Sojourn and Morph. It takes very little machine to cut balsa so I went way cheap! I was hoping that RC people would realize they could exchange GCode files for cutting planes. I put many hours into this field. Please feel free to ask questions. The Dremel Multi Pro will cut balsa like butter. Use a $7 carbide three or four flute cutter. A good DC motor will also cut balsa. With all the foam cutters out there. I decided to make some machines that will do the other parts. There are now several people making
my machines so they can cut balsa parts.
Cranky
crankorgan is offline Find More Posts by crankorgan
Old Oct 12, 2002, 11:31 AM   #40
bob h
>CNC. I design and sell plans for dirt cheap CNC machines. I have >two machines that I recommend for cutting model plane parts. >The 7th Sojourn and Morph.
Crankorgan, Where can we buy/see your plans?
Bob H
Bob H is offline Find More Posts by Bob H
Old Oct 12, 2002, 11:48 AM   #41
balsaman's Avatar
His web page is here:
http://www.crankorgan.com/
Eric
www.e-zflight.com
Old Oct 12, 2002, 11:49 AM   #42
Hi,
My website is:
www.kleinbauer.com
or
www.crankorgan.com
I joined this conference to answer questions and to discuss the steps or equipment need to CNC model parts. I
am not here to push my plans! My plans were the result of a
vision of people exchanging plans for models as GCode-DXF
or PLT.
Cranky
Old Oct 12, 2002, 11:52 AM   #43
DICKEYBIRD's Avatar
Bob H
In case Mr. Kleinbauer's not online, here's his GREAT website. (Also posted in my post upthread a ways.)
HTH
Milton Dickey
(Oops, Mr. K wuz posting as I wuz typing!)
DICKEYBIRD is offline Find More Posts by DICKEYBIRD
Old Oct 12, 2002, 12:38 PM   #44
Hi to Zoltar and DickyBird!
Nice machine DickyBird. What bit do you use with your machine. Zoltar, you are the guy with the CNC machine kit?
Cranky
Old Oct 12, 2002, 01:05 PM   #45
Crankorgan, you're my kind of guy. Great stuff. What WOULD we do without the internet? Gawd I'd be bored. . . . But I'm going to do my all-wood machine tool anyway, just for grins.
The thing many of us modelers aren't good at is the electronics part. I USE computers extensively, but I'm not hot at the nuts and bolts of the bloody things. You apparently have been scavenging plotters for axis drives and controls. Do pen plotters have the oomph to do anything useful? What are the best ones to scrounge for? How do you get them to slow down enough to become a router? (Gear the motors down?) etc., etc. Is all this stuff in your plans packages?
Looking for CNC Mill Part II Steve McBride The Builders Workshop 375 Feb 14, 2009 11:49 PM
Looking for CNC router table FHHOBBIES The Builders Workshop 13 Jul 19, 2005 09:39 AM
Looking for CNC Mill - thread relocated Andy W The Builders Workshop 0 Feb 02, 2005 04:02 PM
Looking for a helicopter spare part David Rodriguez rec.models.rc.helicopter 1 Jan 18, 2004 07:02 PM
Looking for a CNC 4 AXIS FOAM CUTTER A.D. Power Systems 3 Nov 13, 2001 03:44 PM
Bored? Want to fight?
Join the RCGroups clan!
