Go Back   RC Groups > Aircraft - General > The Builders Workshop
Closed Thread Post New Thread  Previous Thread Next Thread
Old Feb 01, 2005, 05:07 PM   #2416
topflight-rcu's Avatar
xairflyer, Would it be good for a mahine that was posted by Mick Molloy on the previous page?
topflight-rcu is offline Find More Posts by topflight-rcu
Old Feb 01, 2005, 05:13 PM   #2417
Model Bender
OzDragonFlyer's Avatar
Topflight, as Xair stated, they will work quite well, I guess they will be rated around the 120-150oz/in mark if they are relatively new. You should be able to get decent performance out of them with a chopper drive at 24-30V. Many to choose from these days (but geckos still seem to get the best torque/speed from steppers)
Depending on the weight/friction of your individual axis' 24-30" would be a good starter for direct drive (you could go bigger on the Y axis if you used a dual screw/motor arrangement)
OzDragonFlyer is offline Find More Posts by OzDragonFlyer
Old Feb 01, 2005, 05:21 PM   #2418
OzDragonFlyer, I am new at the CNC stuff so these questions might seem kinda dumb. First, what is a chopper drive, Second, what is "Geckos"? and last , what would be a good controller or interface to control these stepper motor on the CNC machine? Thanks for all the reply's, this seem like a very interesting project. I plan on using the CNC machine to cut out Foamies, 6mm and 3mm thick.
Joe
Old Feb 01, 2005, 07:03 PM   #2419
Bleriot's R Us
xairflyer's Avatar
Those motors will be perfect for the machine Mick posted, drivers will depend on your budget.
All you need is a driver board either one for each stepper or a board that contains all three.
To supply the power you can modify a ATX computor power supply or build/purchase a higher voltage one.
Regarding the drivers
You can buy the excellent little K179 driver board from www.kitsrus.com available from one of their resellers for about $9.50 each (need three).
Or you could buy The HobbyCNC board which is also very good and well priced.
xairflyer is offline Find More Posts by xairflyer
Old Feb 01, 2005, 11:05 PM   #2420
cnc2play if you are still looking for channel i found a place in brampton cost me 10 buck for all i needed
Tom
Tree_Magnet is offline Find More Posts by Tree_Magnet
Old Feb 02, 2005, 09:14 AM   #2421
and this wire goes where?
What sort of amps do these set-ups pull? you mention the ATX computer power supply - not sure what they are capable of providing but I have a 0-36v power supply coming soon, but it's only capable of about 6 amps - is that enough?
Dongledell is offline Find More Posts by Dongledell
Old Feb 02, 2005, 09:42 AM   #2422
Tree Magnet,
yes, i'm still looking for channel ... what is the address please ?
cnc2play is offline Find More Posts by cnc2play
Old Feb 02, 2005, 11:48 AM   #2423
Bleriot's R Us
xairflyer's Avatar
The amp output depends on the rating of the power supply. I am using a 400W computor power supply and I have 15A @ 12v.
With a 6A supply I would'nt run much more than three 1.5A steppers.
The extra voltage will give you more speed OK, I am thinking about building a 24v PSU but would like about 10A min.
Old Feb 02, 2005, 03:14 PM   #2424
Team Black Magic
longhair's Avatar
Has anyone used the Xylotex board on their mill?
longhair is offline Find More Posts by longhair
Old Feb 09, 2005, 11:57 AM   #2425
That sickening crunch..
Andy W's Avatar
Keep the ranting, accustation and personal attacks out of these forums. I've cleaned up and restored this thread. In future, please use the "report post to moderator" button () if this kind of thing crops up again.
..a
Old Feb 09, 2005, 06:05 PM   #2426
Model Bender
Topflight: Chopper drives are far superior to the lower cost boards which use resistors to limit the current flowing to the motor. The boards and the drives also run much cooler as their efficiency is higher. You can easily distinguish between the 2 by looking for large (>5W) power resistors. If the board has these, it's probably a current limiting type design.
Geckos are popular chopper drives. (www.geckodrive.com). A lot of high end users prefer these because they are able to drive the motors with voltages up to 80V (giving more speed). They are both rugged and reliable, and give great performance.
Longhair: Xylotex boards are a good low cost alternative for a basic setup. I found them to be quite fragile electrically and sensitive to noise without modification, but lots of people have used them straight up with no problems. You will need a parallel breakout board or a parallel port card that supplies the pins with a high of >3.3V for them to work reliably.
Power supplies.. Lots of people have used PC (ATX) psu's with their steppers with great successs. However, switched mode supplies have a limited bandwidth and sometimes struggle with the constantly varying loads placed on them. There are ways of modifying these supplies (big caps and load resistors) to get them to work better. Given that most pc supplies are only rated for 12V limits them severely though.
Often it's just as inexpensive to build a dedicated (higher voltage) supply using discreet components. The geckodrive website has white papers on this and many other subjects, well worth spending time reading!
Old Feb 09, 2005, 06:45 PM   #2427
Team Black Magic
longhair's Avatar
Oz..thanks for the info.
I have a Xylotex sitting on the bench right now and have been following the Xylotex users group on Yahoo, but thought I'd ask the question here. It is supposed to run the Biploar motors I bought so that's why I got it. I also saw somewhere that 24v @ 6 amps is what I should use as a PS for it. So now I need to build or buy one of those....My hobbies are going to get me in trouble with my wife one of these days.
If anyone else has any input on Xylotex please let me know.
Old Feb 09, 2005, 07:26 PM   #2428
Steve McBride's Avatar
Send a message via Yahoo to Steve McBride
Time for a part II - 2427 posts in a thread is about 2000 too many. Let's try and keep the new thread civil please?
http://www.rcgroups.com/forums/showthread.php?t=333499
Steve
Steve McBride is offline Find More Posts by Steve McBride
Looking for CNC Mill Part II Steve McBride The Builders Workshop 375 Feb 14, 2009 11:49 PM
Looking for CNC router table FHHOBBIES The Builders Workshop 13 Jul 19, 2005 09:39 AM
Looking for CNC Mill - thread relocated Andy W The Builders Workshop 0 Feb 02, 2005 04:02 PM
Looking for a helicopter spare part David Rodriguez rec.models.rc.helicopter 1 Jan 18, 2004 07:02 PM
Looking for a CNC 4 AXIS FOAM CUTTER A.D. Power Systems 3 Nov 13, 2001 03:44 PM
Bored? Want to fight?
Join the RCGroups clan!
