Go Back   RC Groups > Aircraft - General > The Builders Workshop
Closed Thread Post New Thread  Previous Thread Next Thread
Old Dec 28, 2003, 09:45 PM   #1501
xairflyer,
Go to a paint store and ask about latex. Don't go to a department store.
John
crankorgan is offline Find More Posts by crankorgan
Old Dec 29, 2003, 09:39 PM   #1502
Bez
I think Emulsion is what they call latex paint in Ireland and the UK.
But it looks thicker than what we have.
I watch DIY shows on BBC America and they call indoor paint Emulsion.
See this link...
http://www.johnsofnottingham.co.uk/T...lsionPaint.htm
Aaron
Bez is offline Find More Posts by Bez
Old Dec 29, 2003, 10:44 PM   #1503
What type wire and connectors do yoe use to connect the stepper motors?
titewad is offline Find More Posts by titewad
Old Dec 30, 2003, 01:04 PM   #1504
MSgt, USAF Ret.
Jim Frahm's Avatar
This thread has been a big help. I've read it from start to finish over the past few weeks, and now I have a question for you guys. I've been gathering parts, plans, etc, and now I'm looking for software. I came across a G code converter called Quickstep ($55.00). Any of you familuar with it? I know you've talked about software in this thread, but I can't find it. The search function for this thread has been turned off. Thanks in advance,
Jim
Jim Frahm is offline Find More Posts by Jim Frahm
Old Dec 30, 2003, 01:32 PM   #1505
Latex paint is technically an emulsion - particles of non-aqueous material suspended in a water carrier. When the water evaporates the particles bond together as a coating film. Same as the water-base polyurethane varnish a lot of us use for covering foam airframes.
uscra112 is offline Find More Posts by uscra112
Old Dec 30, 2003, 02:27 PM   #1506
Catch-Air,
Most people use TurboCnc ($20)(DOS) to convert the GCode to motor movement. You can convert a DXF to a Gcode using ACE (Found free in the CNCPro package) or use KCam(Win)($100). The Flashcut Demo (Win) will convert a DXF to GCode.
Quickstep is a clone of KCam that does not let you set the pin numbers to most of the controllers out there. Maybe he changed it by now. Try KCam first.
John Cranky Kleinbauer
Old Dec 30, 2003, 02:54 PM   #1507
MSgt, USAF Ret.
Jim Frahm's Avatar
Crankorgan,
As always, thanks for the info. I just downloaded ACE. I'm really looking forward to your plans.
One more question for you: The bar holders you made with the 4 adjusting screw, what material did you use? I think I read PVC, but it looks like aluminum.
Old Dec 30, 2003, 04:01 PM   #1508
Catch-Air,
1/2" Grey PVC. Plexi-Glass will also do. Some people use MDF (Bogus)
John
Old Dec 30, 2003, 07:40 PM   #1509
John,
Where can this Gray PVC be found? Don't think I have seen it in the home stores.
Hager
MrChips is offline Find More Posts by MrChips
Old Dec 30, 2003, 07:50 PM   #1510
MrChips,
Local Plastic supplier, Ebay, On my Links page there is a guy at Norva plastic that will sell you a nice amount cheap. He is also on Ebay. You can drill-tap or sand it all with standard hand woodworking tools. Unlike plexi-Glass it does not crack. Grey PVC is neat stuff. I turned several robotic guy on to the stuff. They got tired of Plexi. I use 1/4" and 1/2"
John
Old Dec 31, 2003, 01:44 AM   #1511
John,
I checked Nova Plastics and they list five types of PVC, which one do you suggest?
Hager
Old Dec 31, 2003, 07:13 AM   #1512
MrChips,
Tell Howard you want some Grey PVC 1/4" thick and some 1/2". Are you build one of my machines?
He sells some precut pieces that help with building my machines. Not all the blanks are there.
John
Old Dec 31, 2003, 11:44 AM   #1513
MSgt, USAF Ret.
Jim Frahm's Avatar
John,
Thanks for all your help and information in this thread. I ordered two sets of plans from you. I don't have the plans with me, so I'm sorry if this is answered somewhere in the plans. Is it possible/advisable to mount the two rails on the 7th Sojourn just like the Routezilla II?
As you advised MrChips, I will contact Howard for the grey PVC.
Thanks again and Happy New Year.
Jim
Old Dec 31, 2003, 01:05 PM   #1514
Catch-Air,
The flanged mounted pipe holds its setting better than the other designs. The 7th can be moved and used without recalibration. The pipes strengthen the base. People have milled circuit boards with the 7th. The Phoenix is designed for cutting out larger balsa parts and cutting signs. This requires less accuracy. The 7th can be made very accurate. There is also a private support of my main page.
John
Old Dec 31, 2003, 02:01 PM   #1515
Well my router is up and running it's all based on crankys 7th. It is a simple an accurate design. if any one was thinging on building a router for the first time use crankys 7th plans. i am using xylotex 3 axis chopper driver board and am cutting 18 inches/min which isn't bad. the chopper driver is the only way to go i built another controller using lm298 chips a (couple of years ago ) and current limit resistors. it was a little cheaper but the xylotex driver is only $125 usd (about $160 cdn + 25 shipping)
Tom
Tree_Magnet is offline Find More Posts by Tree_Magnet
Looking for CNC Mill Part II Steve McBride The Builders Workshop 375 Feb 14, 2009 11:49 PM
Looking for CNC router table FHHOBBIES The Builders Workshop 13 Jul 19, 2005 09:39 AM
Looking for CNC Mill - thread relocated Andy W The Builders Workshop 0 Feb 02, 2005 04:02 PM
Looking for a helicopter spare part David Rodriguez rec.models.rc.helicopter 1 Jan 18, 2004 07:02 PM
Looking for a CNC 4 AXIS FOAM CUTTER A.D. Power Systems 3 Nov 13, 2001 03:44 PM
Bored? Want to fight?
Join the RCGroups clan!
