@rpage53: Problem is at partial throttle the ESC gets even warmer than at full throttle. @bpu6999: Use a different prop which draws less amps.
Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
Sure it might be ok but just barely if at all and a speed control with a higher rating should have a lower resistance and thus better performance. I would save the 30 amp control for another plane and get a 50 amp control for the E-Streak. A fried speed control can cost you a plane, either because of the unexpected loss of power or if the thing really fries the heat may cause the voltage regulator in the BEC to cut out as well causing loss of control. I expect that because you are asking the question that you do not use a fuse between the motor and the battery. There was one time when if I had used a fuse it would have saved me a speed control. Does the speed control have overcurrent protection.
Tim Knowles Tim Knowles |
Not if full throttle exceeds the ESC's specs. Most ESC's can handle "momentary" currents well above their rated value (i.e. 30A continuous, 40A momentary). So a 35A static draw for a 30A ESC is likely OK if: 1) the prop isn't stalled at static 2) the voltage is within the specs 3) you limit the time at full throttle 4) the ESC has adequate cooling. Keep in mind, you still might burn out your ESC. If you don't mind that risk, go ahead. [This message has been edited by rpage53 (edited 09-08-2001).] |
There's also a problem of the actual flight usage; what kind of flying you do. And what you're measuring on the ground. Here's an inflight plot of a motor/battery/prop (8x6 APC SF) that measured 12.7amps 11v on the ground.
The first curve is "static test in the plane." Full throttle just before hand launch. Note that it pretty much says the same as the ground measurements (I ignore sharp spikes). The second blip is takoff into an initial climb straight up, followed by coasting back down, then full throttle into the wind, coast around the corner, full throttle with the wind. Note the upper registers of power use are in all cases quite brief, and most of the time this 12.7-amp system is well under 11 amps, and rarely over. I wouldn't be surprised if a good 10-amp ESC could handle this load. Dave |
Impossible to say without more detail. Motocalc will give you a general feel if you plug the 'streak in with the right prop etc. |
Beav, I hate starting new threads to address old ideas. Doing this gives it a bit more perspective, don't you think? These problems and questions have lingered for half of forever, and now we're starting to see some data flow in.
I'm thinking of starting a new thread on the subject, though. Data only. Dave |
Toronto Canada
Joined Dec 2002
This has been posted before, but it shows power drawn as a function of flight speed for props with Pitch/Diameter ratios between 0.6 to 1.1.
The X-Axis of these Advance Ratio plots may be considered airspeed. Pitch Speed occurs at an Advance Ratio equal to the Pitch/Diameter ratio. The Coefficient of Power Cp demonstrates the power absorbed by the prop at different flight speeds. Of note and mentioned previously is the fact that the power absorbed can actually be greater than static at some airspeeds. Also of interest is that the power is not zero at zero thrust because of the profile drag of the prop. |
| Thread Tools | |
| How much does your Zagi 400x weigh? | Balin | Foamies (Kits) | 19 | Nov 17, 2002 05:28 PM |
| How much does the Magic weigh, empty? | slowflyer | Sport Planes | 2 | Sep 09, 2001 01:18 AM |
| How much does the Wattage 550 Speed Control Weigh? | Ryan Nau | Power Systems | 1 | Jun 10, 2001 09:17 AM |
| How much does RS 8x1600 Nimh pack weigh ? | Al P | Electric Plane Talk | 7 | Jun 01, 2001 11:18 AM |
| how much does a multiplex twinstar weigh? | flyer10 | Foamies (Kits) | 5 | Apr 24, 2001 01:34 PM |
