Toledo Express, Ohio, United States
That's interesting, that seemed to happen. The only way I was able to get the plane bac to me was by climbing higher and higher and then putting it nose down in my direction. At that, it enough took a couple passes before I was able to land.
Any idea on what size folding prop I should get? I mean, I already tried one that was slightly bigger than the stock Electra prop and when I launched it, it just glided to the ground. I tried it a few times thinking I needed a harder launch and on the last attempt I shattered the blades off because I was focusing on keep the plane level and didn't cut the throttle in time. FYI - RCHAWK - I checked out the DD and a few other planes like it. Very cool! Although it looks like a flying baseball home plate. I like the scale look, but if I can zip by at 250 MPH and the kit is only $65, I think I'll build it after I finish my Somethin' Extra and 4*60. |
I think there is a glider group in Toledo. You should try to hook up with them. Seeing pilots thermal or getting tips on thermals will incrase the fun factor. It is neat to have a plane climb from 300 feet to 1500 feet in a few minutes without using any motor.
I'd concur that 18 mph steady is a bit too windy for the electra if it is your first time working with it. I used to have a Gentle Lady, and did fly and thermal it in 18 mph winds, but at that speed you are kind of flying a kite, aka you point it into the wind and sort of park it there. You are not going to be doing laps or what not in those winds with the Electra. Oh, and nice job on the build. Ryan |
Latest blog entry: May 2013 US F3B Team Practice contest
| Thread Tools | |
| Carl Goldberg Electra launchquestion | Mr Abe | Electric Sailplanes | 11 | Jun 24, 2004 05:51 PM |
| Finally.......her first REAL flight! | thazy2 | Electric Heli Talk | 5 | Apr 16, 2004 11:01 PM |
| carl goldberg electra with motor | chris-miranda | Aircraft - Electric - Airplanes (FS/W) | 9 | Apr 12, 2004 05:18 PM |
| First real flight of the Mirage 15/2 | kushal_22 | Foamies (Kits) | 4 | Jan 19, 2003 02:09 PM |
| First real flight of repaired zero today! | bztguy | Parkflyers | 3 | Apr 27, 2002 11:32 AM |
