Old Feb 17, 2012, 01:25 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Poly and Cloth Skin
Originally Posted by chester2240 View Post
... can you put up a link thats shows how to do that waterbased poly and light cloth finish
I am also interested in the details of the skin over the 1/2" foam board.
Tsavah is offline Find More Posts by Tsavah
Old Feb 17, 2012, 03:19 PM
wirbech is offline
Find More Posts by wirbech
Pushing the Limits of FFF
wirbech's Avatar
United States, CA, Sierra Madre
Joined Jun 2005
I do not have any pics of how I covered the F-22, but I am currently building a 200% F-18 with the same materials. I will take pics of how I use the cloth and poly during that build and post some pics of it. It is pretty simple.
I use light spackle to fill any large gaps and holes and sand it smooth once dry. I then brush on a light coat of the poly and drape the cloth over the foam and add another coat until the cloth is fully coated. Then I let it dry. After I add a second coat of the poly then sand with 300 to 400 grit sand paper. I then brush on a thin coat of baby power mixed with poly to fill in the remaining fabric weave and then a final sanding before a thin coat primer. Once you primer it, you can see the pinholes and spots that you missed and fill them and another thin primer coat, then the final colors. Thats it. No magic here.
John
wirbech is offline Find More Posts by wirbech
Old Feb 19, 2012, 10:31 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
150%
First off...thank you very much Steve for wonderful plans.
this one is made of Dollar tree foam boards 8 sheets total.
AUW 2.6 LBS
with a monster jet.
smkn951 is offline Find More Posts by smkn951
Old Feb 19, 2012, 11:27 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
EXCELLENT work, smkn! Fantastic looking model. Great job with the shaping, especially.
What scale is that beauty--150%? Good luck on the maiden! Let us know how it goes.
jetset44 is offline Find More Posts by jetset44
Old Feb 20, 2012, 12:50 PM
wilmracer is online now
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
Looking really great Smkn951!
We think a lot alike
I pulled out my old and somewhat beat up 140% Shumate and outfitted the MonsterJet. With some luck I'll get out this afternoon and get some video, although it will probably have to be on a tripod as I doubt I'll get a camera person out in this cold.
Mine came out heavier too... 55oz AUW. Shouldn't be a problem at all though. This one flew great almost 1lb heavier. I did have to rework the motor mount for the monsterjet. The previous mount was way to big and heavy.
wilmracer is online now Find More Posts by wilmracer
Old Feb 20, 2012, 02:20 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
FFF Jet build
Originally Posted by wilmracer View Post
... I pulled out my old and somewhat beat up 140% Shumate and outfitted the MonsterJet. ... Mine came out heavier too... 55oz AUW. ... I did have to rework the motor mount for the monsterjet. The previous mount was way to big and heavy.
Sure looks like a flyer to me. I think I see a hint of FFF, which is what I often use. Thanks for sharing.
Old Feb 20, 2012, 04:14 PM
Joined May 2007
Flew the dust off of the raptor... got her dialed in and feeling pretty solid. Didn't have a camera person so I used a tripod. Not sure if I got any decent shots or not. I didn't get to run my third pack through her though... I accidentally pulled one of the wires to the BEC loose. Need to get it reconnected and beefed up a bit.
Need to try some other prop combos. The 7x6 (not an e prop, just one I had around) ran really smoothly but didn't have the thrust I want for this one.
Old Feb 20, 2012, 06:18 PM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
Hey wilmracer, Were you using the 2400 or the 2100?
Old Feb 20, 2012, 09:35 PM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
Maiden a success!!!but i need more power. this on a 3s 2200 mah 40c, 2400kv monster jet 7x6 prop. 2.6lb
150% F-22 (3 min 20 sec)
Old Feb 20, 2012, 09:56 PM
Joined May 2007
smkn951 - Mine is the 2200kv. Looks like yours flies great. I know I need more power too. I have more amps available so I'll play around with props.
Old Feb 20, 2012, 10:00 PM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
please post the best combination. it seems i always want more speed, then i want to built it bigger, then more speed....when does it end?
Old Feb 20, 2012, 10:11 PM
Joined May 2007
I don't think it ever does.
Old Feb 20, 2012, 10:20 PM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Smkn,
How on earth did you put it together so quick?!??Props friend!
And big congrts on maiden!!
Take care...................................Chris
Hover or die is offline Find More Posts by Hover or die
Old Feb 20, 2012, 11:36 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
http://www.youtube.com/watch?v=1L5i_...ature=youtu.be
Congrats, smkn! Man, those were some LOW fast passes for a maiden flight!
Old Feb 20, 2012, 11:51 PM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
Thanks Steve....but i think that low pass was unintentional.....puckered up really quick on that one...
one thing tho...gotta add another layer underneath, that landing put about an inch hole in the belly...it's only dollar tree foam. single sheet.and it's really soft.
hope to paint it this week.
Chris.....thanks for the props. i had about threee days on it from 0800 till about 2100 hrs for three days working on it.
Mini-Review F-15 Eagle Park Jet--Part 2 jetset44 Pusher Prop Jet Models 3661 Nov 24, 2015 06:17 AM
Video F/A-22 Raptor Park Jet jetset44 Electric Plane Talk 18 May 15, 2007 01:25 PM
Build Log F/A-22 Raptor Park Jet jetset44 Pusher Prop Jet Models 849 Jan 19, 2007 02:17 AM
F-22 Raptor Park Jet Claudius Electric Ducted Fan Jet Talk 38 Jan 26, 2005 08:05 PM
FS- NIB Wattage F-22 Raptor, Typhoon 6 Brushless w/contoller, and 2 new GWS bb servos Etonic Aircraft - Electric - Airplanes (FS/W) 3 Jan 27, 2004 07:46 PM
